Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 10-21-2003, 07:43 PM   #1
Member#: 5914
2010 Legacy 3.6R
Default D2S bulb into Morette?
Does it fit? I'm looking to retro fit an OEM HID kit to my WRX (I want 4300k ) I had read that the CATZ HID kit didn't quite sit right in the housing (too long i think), and just want to check that an OEM setup will fit before i drop the cash
Ikonosin is offline   Reply With Quote
Old 10-21-2003, 07:58 PM   #2
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No. The bulb has to be modified with an H7 base which is what you get with an aftermarket retrofit kit. A standard D2S bulb won't fit properly. If you try to "make it fit" the physical/optical alignment of the bulb in the housing will most likely be off and as a result the light dispersion won't be right.
I haven't seen the CATZ kit so I can't comment on that, but I have D2S bulbs manufactured with H7-compatible bases and they fit fine.
Clips for D2S bulbs into '06/'07 projectors 2007_2.5i Electrical & Lighting 5 07-11-2007 04:50 PM
Questions about installing D2S bulbs into Morettes. NodeSpyder Electrical & Lighting 5 10-17-2006 02:14 PM
phillips HID d2s bulbs [freeman] Private 'For Sale' Classifieds 20 11-18-2003 06:33 PM
fs: Toronto: new hid hella/philips ballast and d2s bulbs etam Canada Region Forum 2 11-07-2002 10:23 PM
