Old 10-21-2003, 09:01 PM   #1
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
Default Of that 3 plug bulb connector, which one is high, and which one is for low beam?
I have an 03 WRX. I'm trying to put HIDs into my STI lights.
I got some ballasts, and a wiring harness from suvlights.
I assume that in that three plug connector that comes on the stock lights, one is for high, one is for low, and the other is a shared ground.
Which wire is for the high, and which is for the low?
thanks guys.
Kwyjibo is offline   Reply With Quote
Old 10-21-2003, 09:07 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This should help you-
The Subaru headlight system is common positive, switched ground. The wiring of the headlight connectors in the car is as follows-
Driver side- common positive = red/light blue (center terminal on connector)
low beam switched ground = yellow/red
high beam switched ground = red
Passenger side- common positive = light blue/white
I recommend you do not connect the negative side of the ballasts to the switched grounds but ground them directly to either a good chassis ground or the battery negative terminal. You can use the common positive for power.
Which side of the car is left and which i right?? ScoobySnacker Newbies & FAQs 9 09-25-2008 05:34 PM
Tired of searching, Can someone tell me which cylinder is 1 and which is 4? crowbar Off-Topic 4 10-24-2006 03:47 PM
H1 for low beam, 9005 for high beam right? got_WRX? Electrical & Lighting 17 08-27-2005 06:30 AM
what size bulb for low beam HIDS? M3toWRXin3seconds Electrical & Lighting 6 07-16-2004 02:48 AM
Fogs For Low Beam 86B Interior & Exterior Modification 4 11-06-2002 12:28 AM
