Old 10-21-2003, 08:50 PM   #1
lightsurge
Member#: 45482
2002 Modded REX
Default Intake on a 98 2.5 RS HELP!!
Ok...I have a question, one of the techs at my work ( i work at a Subaru dealership ) said that with an intake, if the MAF isnt mounted to the engine compartment (or some immovable non vibrating structure) that it will break fast and easy....and some other people told me it would be ok...seeings how Injen designed this particular intake FOR the 2.5 rs 98..dunno anyone know the truth? anyone HAVE a setup similar to this? ANY and all help is appreciated...thanks guys!!
lightsurge is offline   Reply With Quote
Old 10-21-2003, 08:56 PM   #2
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
The MAF sensor on the early RS's are very susceptible to damage. Even if it is mounted and installed properly, you can still blow the MAF. Its a risk you take with aftermarket intakes.
lotusTT is offline   Reply With Quote
Old 10-21-2003, 09:06 PM   #3
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
legacy turbo has the aluminum maf, it was not mounted to a solid surface for about 15k and did ok. and the oem on my n/a 2.2 was not mounted to the body for 30k and did fine.
i dont need a maf any more, so i willl not haev any more millage testings.
subiekid is offline   Reply With Quote
Old 10-22-2003, 05:55 PM   #4
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
I believe it was the MAF in the '99's that was very fragile. The hot-wire style MAF used in the '98's was considerably more robust, apparently.
_Jeff
Portly is offline   Reply With Quote
Old 10-22-2003, 06:16 PM   #5
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
I happen to have a MY98 - and up untill about a month and a half ago (when i started my trurbo project) it had a Injen Intake on it. I had it on for about 20K miles without a problem. Being that its a cold air intake....when it went into the fender it held the MAF pretty firm. I did eventually modify the intake to make it a short ram as I was having issues with the filter getting wet, but that was because I have the 99-01 style front bumper and my splash guards don't fit right. I think if you have the stock 98 front end you will be fine with the Injen CAI - If your not satisfied you can always just get a piece of metal and make a bracket that mounts to the strut tower and the Intake/MAF
Kyle
Any question PM me - I have made such a bracket in all of about 5 minutes
Andursun0013 is offline   Reply With Quote
Old 10-22-2003, 11:48 PM   #6
AirKnight
Member#: 23269
1998 Impreza Outback
Red
I heard of problem with aftermarket intake on MAF equipped Impreza too. What exactly is the problem? Just vibration? If so, I can just use a bracket can't I?
AirKnight is offline   Reply With Quote
Old 11-14-2003, 01:42 AM   #7
AirKnight
Member#: 23269
Red
ttt
WRX parts, 2.5 RS parts and 98 2.5 RS coupe (PA) 69subaru360 Tri-State Area Private Classifieds 13 11-03-2010 12:04 AM
Can you put 2002 WRX fog lights on a 98 2.5 RS?? Jin_WRX Electrical & Lighting 1 06-25-2008 11:22 AM
red line on a 98 2.5 RS jedz123 Normally Aspirated Powertrain 1 01-25-2007 12:39 AM
water pump replacement on a 98 2.5 RS scoobysouth Service & Maintenance 5 02-08-2005 02:03 AM
Magnusson s/c on a 98 2.5 RS scoobysouth Normally Aspirated with bolt-on Forced Induction Powertrain 4 02-04-2005 10:39 AM
