Old 10-21-2003, 11:14 PM   #1
d0gsoup
Member#: 33842
02 wrx
blaze yellowww
Default i got a problem with my jdm STI headlights o.O
yea well i just put in my jdm STI headlights with mcculloh HIDs in 6000k .. and well for some reason the lights turn off and on 1 by 1 once in a while mostly when i'm standing still i'm not sure why
the guy i bought my bulbs from said it's probably the fuse and when i looked i have a 30 fuse and a 15 in the headlights would that be the problem? he said a 20 will fix it so would that be accurate?
thanks for the help in advance
Dennis
d0gsoup is offline   Reply With Quote
Old 10-21-2003, 11:22 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
A fuse is either blown or good. If they didn't blow as soon as you turned the lights on the first time then you should not have to use higher rated ones.
Now, as to your problem-
How are the HIDs wired? Are they connected to the OEM headlight plugs? If so that may be your problem. Try moving the negative connection for the ballasts from the plug connection to a direct chassis or battery ground and see if the lights are more stable.
Feel free to PM me for further help, everyone else does
Old 10-21-2003, 11:24 PM   #3
d0gsoup
Member#: 33842
02 wrx
blaze yellowww
thanks =]
Old 10-21-2003, 11:44 PM   #4
d0gsoup
Member#: 33842
02 wrx
blaze yellowww
the HIDs were wired by plug and play with the stock harness
wait i might be talking about hte JDMs i'm sorry i'm a newb with wires and electronic **** lol
Old 10-22-2003, 08:40 PM   #5
d0gsoup
Member#: 33842
02 wrx
blaze yellowww
yea well i put in 2 20 fuses in the headlights and it still turns off and on... =/
i don't know whats going on but it doesn't happen when i'm on hte highway or anything mostly when i'm like in traffic or when i'm stopped
can someone help?
Old 10-22-2003, 09:36 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What did I say about fuses in my first reply?
If they weren't blown changing the fuse size makes zero difference.
Your problem apparently has to do with insufficient voltage getting to the lights. That's my guess based on what you've posted although I can't actually look at your car. Most likely what is happening is the voltage drop on the ground side is causing the voltage at the ballasts to be marginal at lower alternator output such as when stopped and idling.
Follow my advice above and directly ground the ballasts. If you have no idea what I am talking about then get someone with electrical knowledge to help you, show them this thread and if they have any questions PM me.
Old 10-22-2003, 10:10 PM   #7
d0gsoup
Member#: 33842
02 wrx
blaze yellowww
o thanks
but i changed the fuses because originally someone changed them 1 of them was a 30 and 1 was a 15 so 1 of my friends said something i forgot waht he said exactly but he was tellin gme to switch the fuses too =/
i guess the grounding wire could be it too i'll try to find out thanks for the help though
Old 10-22-2003, 10:18 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I think you'll find that once you move the grounds it will work much better. Again, post or PM if you need any more help.
Help with my JDM GD8 headlights down_for_the_scooby Electrical & Lighting 9 07-17-2005 01:51 PM
i got a problem with my 04 sti can anyone help? gotmilk2001 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 02-02-2005 10:33 AM
strange problem with my LHD STi headlights Imprezanator Electrical & Lighting 1 08-17-2004 11:06 AM
Got a problem with my morettes rochyrex Interior & Exterior Modification 2 08-23-2002 10:23 PM
Okay Texas, I've got a problem with my car.... Bohanan @ work Texas Impreza Club Forum -- TXIC 16 05-10-2001 11:27 AM
