Old 10-21-2003, 11:40 PM   #1
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
Default 2.5 RS engine idleing not so good
hey iwas looking at a 2000 Impreza 2.5 RS with 41,000 miles on it, i almost bought it but the engine when it was idleing at low revs, it was sputtering and didnt sound good at all, almost stalled out, is this just a problem that can be fixed with a good ole tune up? (spark plugs changed, etc..) or is it a major problem, im thinkin it might be a burned valve but is this thing common with the subie engines? cause i talked to a dealer and the guy said he had the same thing on his outback sport and said that it could be the valves and stuff but i dunno, just curius
2.5 Blue Roo is offline   Reply With Quote
Old 10-22-2003, 12:21 AM   #2
atabert
Member#: 45107
1992 Legacy L
Green
Default valves
come on now,i ve never heard anything bad about the valves,before you start condeming an internal engine problem, look for some more obvious things like plugs,fuel filter and or ****ty gas, it could have a burnt coil or a bad plug wire, look for basic stuff, to me it sounds like you got a miss somewhere, does the check engine light come on?
atabert is offline   Reply With Quote
Old 10-22-2003, 09:03 AM   #3
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Start with the little stuff...
If you haven't had a tune up in a while that can certainly cause your car to run poorly. It's pretty much the first step I recomend to everyone who's car just isn't running right...
AO
m750 is offline   Reply With Quote
Old 10-22-2003, 01:13 PM   #4
dcoty
Member#: 3149
01 V7 GC/R32 sky
Maybe an O2 sensor, it sounds like that to me. Check all the connections on you spark wires, make sure it isnt dirty or corroded.
Dan
dcoty is offline   Reply With Quote
Old 10-22-2003, 02:01 PM   #5
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
Reset the ECU and see ifit goes away.
Stealthbmbr is offline   Reply With Quote
Old 10-22-2003, 03:34 PM   #6
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
thanks guys ill check all the little stuff out first, and im not condemning the engine im just scared that it might be something like that =(
Old 10-22-2003, 05:50 PM   #7
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
I can almost guarentee you it is a bad o2 sensor. I got the 40,000 miles and guess what? After $250, and a rip-off auto repair place, I took it to subaru, and they confirmed my last suspician. Bad o2 sensor. even though it was not throwing the code for it. But in the 3 months I drove it like that, it threw every other code in the book. check here:
http://forums.nasioc.com/forums/show...hreadid=422964
It will confirm it for you. $80 shipped from www.subaruparts.com.
$100 from the dealer and around $80-130 for them to install it. Took me 20 minutes and 1 wrench. (and some anti-sieze)
ChosenWon is offline   Reply With Quote
Old 10-22-2003, 09:23 PM   #8
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
it could also be something as simple as a loose, or disconnected vacuum hose. Mine have come off before.
twizzstyle is offline   Reply With Quote
Old 10-22-2003, 09:40 PM   #9
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I wouldn't garentee anything...
symptoms can appear differently to different people, and describing them is a whole different ball game. Do you have a CEL?
AO
Swap 1999 2.5 RS engine for 2001 2.5 RS engine c0mrade Subaru Conversions 5 06-15-2006 09:19 PM
WTB: Phase 1 or 2 2.5 RS engine keirnna Private 'Wanted' Classifieds 3 06-02-2005 05:18 PM
Engine sounding not so good during warm up. Teh Legacy Legacy Forum 12 05-15-2005 10:10 PM
2.5 rs--engine using oil PerformanceAutoSolutions General Forum Archive 11 11-15-2000 05:04 PM
2.5 RS Engine/Drivetrain for Sale CoByRS General Forum Archive 1 05-28-2000 06:01 PM
