Old 10-22-2003, 12:39 AM   #1
left footed whooten
Member#: 44652
06 WRX
16 Colorado Duramax comin
Default Need a tach for my Brighton
Want to put a tach from a suitable Impreza into my tach-less Brighton Impreza. Does my car have pickups and wiring already, or, on such transplants do i need the whole shebang? Hoping I can just grab a donor gauge from the salvage and drop it in without having to run wire & such. Appreciate the input.
left footed whooten is offline   Reply With Quote
Old 10-22-2003, 07:13 PM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I believe you can tap an aftermarket tach (such as Autometer tach) into ECU's engine speed signal wire even though you don't have a tach. The ECU still needs to know the current engine RPM.
If you can't find one, then you can tap into ignition module. I don't have a clue on which wire.
tmat3 is offline   Reply With Quote
Old 10-22-2003, 09:44 PM   #3
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
should be able to just tap the wire that goes into the ecu.
subiekid is offline   Reply With Quote
Old 10-22-2003, 09:56 PM   #4
avk
Member#: 17252
'06 WX8
59E
You can remove the blank plate and install a tachometer. It's the same p/n for all 1993-96. The electrical connection is through the mounting screws and the signal wire is already connected to the circuit board on the back.
avk is offline   Reply With Quote
new jdm bumper for my brighton tn 96 impreza Subaru Conversions 7 08-06-2007 11:01 AM
I need parts!!!...not for my WRX, for my skateboard! NJwrbT-WRX Tri-State Area Forum 23 09-16-2003 06:08 PM
Need service advice for my area rktwgn South East Region Forum 3 06-06-2001 06:20 AM
need replacement stickers for my Volks....please help MI members!! subywan-kenobi Mid West Subaru Owners Club Forum -- MWSOC 12 04-29-2001 05:50 PM
Need a fix for my bra (4 my car silly!!) wieger54 Interior & Exterior Modification 9 03-27-2001 11:34 PM
