Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 10-22-2003, 01:39 AM   #1
Member#: 45735
2002 Impreza WRX
Question Underdrive Pulleys/Lightweight Pulleys
I was wondering about how and why pulley kits work.
I've noticed 2 different kinds of kits, underdrive and lightweight. From what I understand, underdrive kits use SMALLER pulleys to reduce the amount of power needed to spin the accessory belts, but don't power them to their normal levels. Lightweight pulleys are the same diameter, but milled out and made out of lighter materials??
I run quite a bit of stereo in my trunk, so I'm worried that an underdrive pulley system might be a really bad idea. My biggest question is: Do lightweight pulleys have the same "underdrive" effects, and, are they worth the money?
UGotBoost? is offline   Reply With Quote
Old 10-22-2003, 08:34 AM   #2
Member#: 33354
98 Supra TT
If I'm not mistaken, the terms "Underdrive pulley" and "Lightweight pulley" are two terms for the same thing. The term "Underdrive pulley" from my understanding, refers to the crank, alternator, and a/c compressor pullies, sometimes the power steering pump pulley as well.
Almost any aftermarket pulley kit you get will come with smaller and lighter pullies than the factory units.
For the WRX, most pulley kits only come with the crank pulley and the alternator pulley. I just picked up a GFB set for myself yesterday.
Please, someone correct me if I'm wrong.
Reverend is offline   Reply With Quote
Old 10-22-2003, 08:54 AM   #3
Member#: 42297
2003 WRX
Underdrive pulleys are smaller in diameter (and usually lighter) than the stock pulley, lightweight pulleys are the same size as stock but are beneficial because they are much much lighter.
I have the Perrin pulley and it is the same diameter but weighs <20% of the OEM pulley. Great bang for the buck mod, not for power but for throttle response.
dnichols is offline   Reply With Quote
Old 10-22-2003, 10:32 AM   #4
Member#: 9369
F#ck U & Your Stance
Default Light Weight Pullies....
I am running Airborne Motorsports Lightened pullies on my Stg 2 WRX with no problems. It makes throttle response alot better and make rev matching a little quicker.
I have a extra set of silver Lightened Pullies that I need to unload, let me know if you are interested.
More info on the pullies can be found here:
RALLYT-WRX is offline   Reply With Quote
Lightweight crank pulley + Lightweight Flywheel. OK or Not ? jobxiii Built Motor Discussion 39 05-20-2009 05:25 PM
Under pulley VS Lightweight Pulley Siphoyn North West Impreza Club Forum -- NWIC 16 11-10-2008 05:52 PM
Perrin lightweight pulley VS Cobb pulley? Fab's STI Newbies & FAQs 29 09-25-2007 02:15 PM
where to find a lightweight pulley...NOT UNDERDRIVE IllNastyImpreza Normally Aspirated Powertrain 69 03-23-2006 02:54 AM
WTB/WTT: Underdrive Alternator pulley (&belt?) or lightweight pulley trade tooocool49723 Private 'Wanted' Classifieds 1 01-06-2005 05:25 PM
