Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 10-22-2003, 10:24 AM   #1
cloudbrk
Member#: 44557
05 Legacy OB Wagon
Willow Green Opal
Default Transmission Swap....Is it Possible?
I have a 98 Lecacy Outback and I want to do a transmission swap. I want my automatic to be manual transmission. I am so over not being able to shift on my own!!!!!!! I miss it.
Will the transmission swap right out? I know I will need a different center console. WIll I need a different flywheel and a different starter too?
Anyone know where I can get a good used manual transmission?
cloudbrk is offline   Reply With Quote
Old 10-22-2003, 11:43 AM   #2
simpreza2
Member#: 20381
04 Forester X
93 240sx
Used trannys
or
E-Bay but all they have right now is autos but i would check back every few days
Jon
simpreza2 is offline   Reply With Quote
Old 10-22-2003, 07:21 PM   #3
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
I really don't know much. But it should bolt on to the existing mounts. The hard part are the things you need to change between the tranny input and engine/flywheel (not limited to), where quite a few things need to be changed/converted (clutch, throw-outs, etc.). Then you also have the wiring...
Please correct me if I'm wrong.
Unless you really want to keep the car, I would just get another car or scoob with an MT. Especially if your having someone work on it. The cost to make the conversion can possilby (and very likely) to exceed the actual value of the car itself.
-paK +31
Pakin is offline   Reply With Quote
Is it possible to do an 06 to 05 front end swap? mobilezen Interior & Exterior Modification 20 11-30-2013 06:13 PM
is it possible to swap a front end from a saab?? bereda Interior & Exterior Modification 31 12-05-2008 07:56 AM
WRX 2.0T to 2.5T swap is it possible???? stusha Subaru Conversions 6 07-10-2008 11:13 PM
4EAT to 6MT swap. Is it possible? Vostok 7 Transmission (AT/MT) & Driveline 1 09-29-2004 01:47 PM
Is it possible, front end swap? jbell Interior & Exterior Modification 23 07-11-2004 05:58 PM
