Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 10-22-2003, 11:13 AM   #1
Member#: 45747
2005 Saabaru (9-2X)
Default Removing Rear Wiper
Can anyone advise me on the procedure for removing the rear wiper arm from a Legacy Wagon (in my case, a '91)? It is rusty, and I would like to refinish it, but cannot remove it, even after removing the 10 mm spindle nut.
Thanks for any and all help.
Joe Fillip
Swarthmore, PA
lanciat is offline   Reply With Quote
Old 10-22-2003, 12:00 PM   #2
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
I would like to know this for a '98, too. I'm assuming it's the same, but you never know.
Mine is 7 years newer and it's rusty too
ws6fiero is offline   Reply With Quote
Old 10-22-2003, 12:09 PM   #3
Member#: 5039
2007 Outback XT
Grey 5-speed
After my attempts at removing said wiper on my wagon I would suggest this, get a small gear or bearing puller. They are available from Autozone as loaner tools. The wiper arm gets so corroded to the shaft that you are likely to break the shaft trying anything else.
I got the wiper off my 94 using this approach. On my 97 however the nut was so corroded to the shaft, it broke the end of the shaft off when I tried to loosen it. I left it alone at that point cause the corrosion is all that is holding it on. That was about a year ago. I masked off the whole back area of the car and painted the wiper arm anyway.
subysouth is offline   Reply With Quote
Old 10-22-2003, 10:22 PM   #4
Member#: 19681
1998 Legacy Wagon GT
You'd probably be better off just replacing the thing. The spring will likely be rusted too, and you won't get as good of tension.
New, I think they are about $20.
Speedwagon is offline   Reply With Quote
wagon rear wiper arm removal Smity Subaru Newbies & FAQs 1 08-24-2009 12:18 PM
Removal of rear wiper? dntouch Interior & Exterior Modification 24 02-29-2008 01:31 PM
How to remove rear wiper from wagon? triguy Southern California Impreza Club Forum -- SCIC 24 01-19-2007 02:18 AM
04 Wagon Rear Wiper removal.. sloppy_seconds Interior & Exterior Modification 6 03-17-2005 10:38 PM
How to remove rear wiper from wagon? triguy Interior & Exterior Modification 0 08-21-2004 01:54 PM
