Old 10-22-2003, 06:13 PM   #1
SDEWYZ
Member#: 31352
98 RS
Black....for now
Default Going head gasket rate??
Whats the going rate for a complete head gasket job for a 98 DOHC?? All parts and labor included. If someone has avg. dealer cost and time length of repair that would be great. Thanks
Caleb
SDEWYZ is offline   Reply With Quote
Old 10-23-2003, 12:11 PM   #2
m750
Member#: 2278
8Sti | 07 allez
White | Comp
depends on wether or not the heads were warped from over heating after the gasket went... if the heads are bad, think mucho dinero
m750 is offline   Reply With Quote
Old 10-23-2003, 12:26 PM   #3
SDEWYZ
Member#: 31352
98 RS
Black....for now
no head warpage.......
Old 10-23-2003, 03:22 PM   #4
Farfrumwork
Member#: 10202
'07 Spec B
'85 EJ25 Syncro Westy
Not a dealer... but a local guy had his done (DOHC 2.5 though, if it makes any difference) for ~$1300. That included all the front seals, oil pump seal, H2O pump, and timing belt job
I bet it would be almost 2x at a stealership
Farfrumwork is offline   Reply With Quote
Old 10-23-2003, 09:00 PM   #5
leondal
Member#: 43114
1998 Legacy GT Turbo
Green
I've seen it done for $400 per side at a local dealership.
leondal is offline   Reply With Quote
Old 10-24-2003, 08:32 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I was recently quoted $1300 and $1000 by different places to have my new head installed, which is basically the same operation...
Someone correct me if I am wrong, but it can be done without removing the engine, but most places will pull it. That might account for the huge price difference...
Old 10-26-2003, 09:33 AM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Matt is correct.
It "can" be done in the car, but most pull the engine.
If they pull it, ask to have the front and rear crank seals done, and check the oil seperator plate as well. If it is plastic, replace it.
Head gasket, water pump & timing belt work - shop rate? vdiddy93 New England Impreza Club Forum -- NESIC 33 01-13-2010 08:49 AM
Heater core noises = head gasket going?!? magicstop Newbies & FAQs 8 10-02-2009 10:14 AM
Head Gasket Job Rate/Cost? JamesWilson2 Service & Maintenance 23 08-12-2009 10:22 PM
Help! FAST! Do I need to use gasket sealer, when replaceing my head gaskets?! wighti Tri-State Area Forum 5 10-05-2003 10:19 PM
Leaky Head Gasket & Water Pump Gasket - MY00 Forester lark6 Normally Aspirated Powertrain 20 11-10-2001 10:22 PM
