Old 10-22-2003, 09:10 PM   #1
970subaru
Member#: 45703
Default legacy suspension
what are my options for improving the suspension on my 1991 legacy wagon?? Tried searching but found nothing. I want to lower it about an inch, and get better handling. I have a few questions.
1. I have heard the top spring buckets in rear are different than later legacies, Is this true?
2. If so, can mine be converted to the later style? Is it worth it?
3. can springs intended for a WRX or similar be used with said later top caps? I am looking for as little lowering as possible.
4. are there any stock subaru springs I can use that will give me a stiffer rate?
thanks for any info.
970subaru is offline   Reply With Quote
Old 10-23-2003, 01:09 AM   #2
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
1) I don't know what they are officially called but I think we are talking about the same thing, but yeah the top mount rubber/plastic/urethane thing is different. The rear springs on 90-91 are tapered so the top mounts are different.
2) You can convert them by getting new top mounts, the Sti's are recomended as they are harder and so flex less. I think only the gc8 93-01 impreza style will fit that, not 100% sure on that though.
3) As long as you get the new topmounts you can use any non-tapered spring that will fit any bc/bf or gc8 impreza for sure. Others might fit but again I don't know for sure.
You really ought to check out bbs.legacycentral.org tons of info on the bc-bf legacy.
THAWA is offline   Reply With Quote
Old 10-23-2003, 02:12 AM   #3
970subaru
Member#: 45703
cool, thanks man.
Old 10-23-2003, 04:26 PM   #4
HomeSlice
Member#: 6081
MY93 Legacy
Sonora Sand ej22t
dont sleep on it bbs.legacycentral.org
JOIN US
HomeSlice is offline   Reply With Quote
Old 10-24-2003, 04:45 AM   #5
970subaru
Member#: 45703
just did, cool site.
2008 Impreza Suspension vs. Legacy suspension vs. Tribeca suspension Kostamojen Brakes, Steering & Suspension 70 08-09-2007 01:18 PM
FS OR: 02/03 wrx suspension 99 legacy suspension spdracr00 Suspension/Brakes/Handling 0 06-13-2007 12:48 PM
2000 legacy suspension crAZ_L Brakes, Steering & Suspension 3 11-13-2000 11:33 PM
Legacy suspension improvements Mx5racer Legacy Forum 23 10-18-2000 04:34 PM
90-91 Legacy Suspension Upgrades Naz53 Legacy Forum 7 02-22-2000 11:21 PM
