Old 10-23-2003, 01:06 AM   #1
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
Default Need a grommet....please help me.
I need a grommet...basically i need to be able to get the head of a ballast (31mmx33mm) into the rear cap of a set of STI lights....then be able to seal it up so no moisture gets in.
The wire diameter is 3/8
A heat shrink grommet would be ideal (if they even make those?)...or something rubbery that has an outer diameter of like 1.5 inch and an inner of 3/8s.
Thanks in advance.
Kwyjibo is offline   Reply With Quote
Old 10-23-2003, 04:00 AM   #2
MK19
Member#: 21977
Bear s like food
time to head to autozone...
MK19 is offline   Reply With Quote
Old 10-23-2003, 01:36 PM   #3
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
Man, i wish it was that easy...i've probably looked in about 10 places already
Old 10-24-2003, 10:21 AM   #4
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
I bought some grommets from www.mcmaster.com
I'm not sure if they have the right size for you, but they have a list of different sizes and cross section shapes (some with rounded edges, some with square/prismatic edges).
There are also blind plugs that you can punch holes if you can't find a matching grommet there.
Good luck
satrya is offline   Reply With Quote
Old 10-24-2003, 12:41 PM   #5
kbcr3
Member#: 44170
2010 Forester XT
05 and 09 honda ruckus
I had a similar question. I am going to go to home depot later and am going to get some type of waterproof, high heat epoxy to fill it with. You could always go to home depot and explain you dilemna and see what they suggest.
kbcr3 is offline   Reply With Quote
Old 10-24-2003, 01:21 PM   #6
Edvig
Member#: 16147
no more turbo
05 Legacy, 11 Outback
I picked up a firewall grommet from a dealer last year for this exact purpose. I think I have the part number. I'll check later and post it.
-Edvig
Edvig is offline   Reply With Quote
Old 10-24-2003, 01:51 PM   #7
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
That's probably less expensive for a one-time use like this. The grommets I bought were in a bag of 100, so they are less expensive per piece, but unless you plan on using a lot of grommets, it may not be the best way to go.
Old 10-24-2003, 08:23 PM   #8
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
Well, go something going...
Went to autozone..they have that section with all the HELP stuff.
Got a large grommet from a GM. Large enough for the plug of the ballast to go through. Then a GM master cylinder cap.
The grommet seals up the edged of the hole. Then i made a samll hole in the master cylinder cap, and cut a slit into it. This slides over the cable, and seals up fairly well with the grommet.
Then i used automotive Goop to seal it all up...hopefully it holds, and is waterproof....
Old 10-24-2003, 10:29 PM   #9
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
here is a pic...
Urgent: HELP Needed! Brembo Owners Please Help Me Out. soulska Southern California Impreza Club Forum -- SCIC 16 02-05-2010 09:01 PM
JDM 3B ECU, I need pinouts, someone please help me 00boostedRS Pre-2002 Factory Turbo Powertrain 0 02-29-2008 12:30 AM
I need an MP3... please help me... Texas25RS Texas Impreza Club Forum -- TXIC 1 07-04-2004 03:25 AM
Please help me!! need help!! DarkLite Technical Forum Archive 3 08-25-2000 11:52 PM
