Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 10-23-2003, 02:06 AM   #1
3BadHabbits
Member#: 38011
2005 05FXT-RICE!!!
Silver RICE!!!
Thumbs down 2000 RS Clutch and Wheel bearing issues
Anyone have or having wheel bearing issues in their GC8? Im starting to hear something from the front end on deceleration when cornering and going staight. Also the bearing seem real loud in the front at higher speeds (65). Iheard that these bearings are not sealed. They use the legacy bearings or something?
The second issue is the clutch. Anyone have the clutch chatter problem in their GC8. Feels the same way as my WRX did before I had it replaced 3 times.
The car goes in monday and only has 25K miles.
Anyone know how much I could get for this car if I wanted to sell it? Silver, 5speed, every option, NO dents, 25K miles
Thanks Nick
3BadHabbits is offline   Reply With Quote
Old 10-23-2003, 08:24 AM   #2
balajc
Member#: 15393
MY00 2.5RS Coupe 5MT
Silverthorn Metallic
I just went through the same thing like you
You can get a TSB clutch replacement done for no cost seeing you are under 5/60 warranty.
Although you only have 25k miles, you might be out of 3 years warranty. If so, you will have to pay for the wheel bearing replacement. I had my right rear done last week, I was out of 3/36 and paid $100 deductible due to extended warranty from the previous owner.
BTW, they only do the wheeling bearing that is bad.
MAKE SURE they use the legacy bearings
balajc is offline   Reply With Quote
Old 10-23-2003, 05:09 PM   #3
3BadHabbits
Member#: 38011
2005 05FXT-RICE!!!
Silver RICE!!!
Thanks Man,
Yeah they'll replace everything for free...I used to work there
This bearing sounds like it is coming from the front. i think its actually both of them. They should repalce it under the 5/60 because they are considered part of the drive train.
Which year legacy bearings??
Thanks Nick
Old 10-23-2003, 05:30 PM   #4
balajc
Member#: 15393
I thought the wheel bearing is only covered under the 3/36 warranty...if what you said is true, my dealer just made off with $100!
I think it is 99 and prior for the legacy bearing MY, I will post the part number when I get home
Old 10-23-2003, 05:54 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
wheel bearings are not drivetrain.
but to be sure you would have to look in yoru warranty and maintnence book, it describes everything covered under the powertrain warranty.
I have 2000 book sitting here, and wheel bearings are not covered.
bad tires (cupped/worn/etc) can also sound like a bad wheel bearing.
there are no TSBs I know of for front brearings.
Clutch shudder, there is a clutch shudder TSB and it would be covered under yoru 3/36 warranty.
Old 10-23-2003, 05:58 PM   #6
Fat Tits
Member#: 27046
IIRC there was a wheel bearing recall, dont quote me but i think so..for 00-01 models. I had the shudder with my stock clutch, and it was 9769787975x worse when it got cold, sometimes i even had to pull the pedal back up with my foot... that sucked.. just sell it on a warm day and after its warmed up
selling it, Why? hum.. you got a sweet deal on it so im sure you could get what you paid if not close.
_b
edit: i type too slow.. lol
Fat Tits is offline   Reply With Quote
Old 10-23-2003, 06:00 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
TSB on the wheel bearings, not a recall.
Jay
Old 10-24-2003, 05:50 PM   #8
3BadHabbits
Member#: 38011
2005 05FXT-RICE!!!
Silver RICE!!!
I know the clutch is covered under the 5/60, it was done on my WRX 3 times. Im sure me and "!@#$%" dealer can work out someting with the bearings.
By the way the "IIRC" and "TSB" abreviations that you write, I have no friggin idea what the hell that means
Nick
Old 10-24-2003, 06:01 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
IIRC, = If I Remember Correctly
TSB = Technical Service Bulletin.
the WRX wear item warranty is different than the RS.
Im sure the dealer can let you know whats up.
Jay
got my ACT clutch and throwout bearing.put the bearing in pressure plate.cant remove! stiboost04 Transmission (AT/MT) & Driveline 2 04-27-2010 08:47 AM
WTB: N/A 2.5 Block or FS: 2000 RS Coupe - Spun Rod Bearing `04AlpineWhite RMIC Private Classifieds 0 09-12-2006 02:14 PM
Wheel Bearing issue and slight clunking sound? jigga Transmission (AT/MT) & Driveline 5 06-20-2005 09:12 PM
fs locally: either a 2000 rs 6 spoke wheels or a 99 rs 5 spoke silver wheels Rattles New England Impreza Club Forum -- NESIC 28 08-06-2004 09:19 PM
Rear Wheel Bearing Issue minx Normally Aspirated Powertrain 20 05-01-2002 03:24 PM
