Old 10-23-2003, 02:48 AM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Default problems with jdm hid projector install
fuse keeps blowing
jdm hid headlights on friend's 02 wrx. ballasts fire up and the lights go on, but then the fuse blows and everything dies. change fuse and restart... fuse blows again. everything is checked against my install (works fine with stock fuse) and can't find fault. even bought a second set of ballasts with same results.
what is going wrong?
Benjamin Tang is offline   Reply With Quote
Old 10-23-2003, 06:48 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Are your installations identical, same ballasts and all? Some ballasts will draw enough current on startup to blow the stock 15A fuse, some won't. If you have an ammeter that can measure that much current hook it up and see how much the ballast is drawing.
It is generally safe to replace the fuses with 20A ones if this is happening, although if the ballasts are actually drawing that much current it would be even better to install relays to get power directly from the battery.
Old 10-23-2003, 11:03 AM   #3
Benjamin Tang
Member#: 4496
2009 Forester
red
i spoke to my friend last night and he's basically given up. he has sold the headlights themselves separately, and would like to know what is the going rate for used sti hid ballasts?
HELP WITH JDM HID projectors sp99ling Private 'Wanted' Classifieds 7 04-14-2009 04:38 AM
Problem with JDM HID... txl146 Electrical & Lighting 17 11-10-2008 11:33 AM
post jdm hid projector install help Gr8wall Electrical & Lighting 6 09-26-2005 10:07 AM
Problem with JDM Hids, help!! Cerum Interior & Exterior Modification 1 03-02-2003 03:00 PM
JDM/EDM Projector install with HID kit...Please help Yungimoto Interior & Exterior Modification 4 01-04-2003 05:50 PM
