Vancouver Impreza Club
Old 10-23-2003, 03:28 AM   #1
swol3
Member#: 44785
02 sedan wrx
WRB COBB stage 2
Default a question for passing AIRCARE
ok i know if i have a uppipe, dp , catless mp, and exhaust i will not pass aircare.
my question is whats the least stock parts i have to put back on in order to pass aircare? (besides the taking off the race pipe)
thanks
swol3 is offline   Reply With Quote
Old 10-23-2003, 03:50 AM   #2
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
put back in all your cats and u should pass no problem.
Orbiter is offline   Reply With Quote
Old 10-23-2003, 05:15 AM   #3
swol3
Member#: 44785
02 sedan wrx
WRB COBB stage 2
ya i know that. but im too lazy to do that hehe . will i pass aircare with all the cats except the turboxs uppipe? because to uninstall/install the uppipe u need to take out the turbo, intercooler and u need to drain the coolant. thats hella too much work for me to do.
Old 10-23-2003, 05:26 AM   #4
aawen
Member#: 27167
2015 FXT
yap, that will work (correct me if i'm wrong)
aawen is offline   Reply With Quote
Old 10-23-2003, 05:55 AM   #5
bwco
Member#: 44137
try this >> keep revving constantly on your engine to 1500-2000 rpm for 5-10 minutes before you go in, don't let off the gas until you get off the car, the aircare guy will come to you and pick up your gas cap, I guess it's still ok to gas it around 2000 rpm, just keep it quiet when you cheat (ok! ) don't make it loud ! then, once they ask you to pull over to the wheeler thing, then stop doing that, get off the car, let them do the test....
I failed aircare before with my previous car with a bad O2 sensor, but I passed with an early pass showing on the machine.
Well, thats how I cheated, But make sure, you drive your car for a long distance before you aircare. Make sure it's warm. Drive normal, don't race it before aircare. Thats just some tips from my machanic before. good luck
bwco is offline   Reply With Quote
Old 10-23-2003, 09:49 AM   #6
Benjamin Tang
Member#: 4496
2009 Forester
red
yeah the uppipe can stay in since that cat is only good for cold starts. as long as u are not getting an egt-related CEL it should be okay.
the turbo has to come out? i thought cody at total said he can swap the uppipe/downpipe w/o having to remove it... maybe i was wrong
Benjamin Tang is offline   Reply With Quote
Old 10-23-2003, 12:37 PM   #7
tora
Member#: 5851
09 Forester XT
+ NA Miata
Just replace the cats from your down-pipe center pipe. It is a fairly basic swap and will get you through no problem. You DO NOT need your up-pipe cat. BUT, make sure the car is totally warmed up before you go in and make sure not to turn off your car while waiting.
As for installation of the up-pipe you do not need to remove the turbo or empty your coolant.
tora is offline   Reply With Quote
Old 10-23-2003, 01:41 PM   #8
Benjamin Tang
Member#: 4496
2009 Forester
red
how about running a bigger turbo with stock ecu and the last 2 cats?
Old 10-24-2003, 05:14 PM   #9
swol3
Member#: 44785
02 sedan wrx
WRB COBB stage 2
about the install its gonna be either take out the turbo or unbolt 1 of the engine mounts and jack the engine up 2-4 inches. hehe.
at least now i know that the uppipe install is a do it and forgot it. i was getting worried that i wouldnt pass aircare and would have to do the install every 2 yrs. but now jump for joy
thanks guys
I Passed Aircare With 1 Cat!!!!!!!!!!! pro2cer604 Vancouver Impreza Club Forum -- VIC 6 06-02-2005 12:07 PM
High Flow cat pass aircare?? Marty Gagnon Vancouver Impreza Club Forum -- VIC 16 02-17-2005 02:07 PM
Passing Aircare with intake and full exhaust ShawnRS Vancouver Impreza Club Forum -- VIC 18 03-26-2004 06:35 AM
Pass aircare deft Vancouver Impreza Club Forum -- VIC 2 11-09-2003 12:21 AM
Need help on passing aircare Hojai Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-13-2001 12:42 AM
