Old 10-23-2003, 09:24 AM   #1
TopKatz
Member#: 36793
04 WRX
Default oil change - now oil spot in parking spot?
I just had my oil changed in my 04 the other day. I noticed an oil spot on the ground. I checked my oil and the levels look fine. Is this in any way normal? Im woried the hacks over at speedy dorked my drain plug now....
TopKatz is offline   Reply With Quote
Old 10-23-2003, 10:08 AM   #2
mlambert
Member#: 13831
they probably didnt install a new crush washer, you really should do it yourself.
mlambert is offline   Reply With Quote
Old 10-23-2003, 10:29 AM   #3
Slowpoke
Member#: 19879
2004 WRX
Java Black
Several possibilities come to mind:
The first is that oil spot was always there (perhaps from your old car or from another car before you), and that you are just paranoid since you've just had your oil changed.
The second possibility is that wherever you got your oil changed, they didn't remove the plastic guard from under the engine. In the 04 WRX it is pretty much impossible to remove the old oil filter without spilling oil on the guard. So the oil spot may be due to some of your old oil, which got left on the guard.
I don't really think the crush washer is the problem.
Park your car overnight with a newspaper or piece of cardboard under your car to see if your car is really leaking oil. If it is, take it back to where you got your oil changed and have them tighten everything up.
Slowpoke is offline   Reply With Quote
Old 10-23-2003, 10:31 AM   #4
TopKatz
Member#: 36793
04 WRX
I had a truck befor the WRX, which did not fit in my garage, so this is defenitly from my scooby.
Ill put a catch pan of some sort under it and see if it persists....
thanks for the input guys....
Old 10-23-2003, 01:34 PM   #5
pjcoregon
Member#: 15384
if you don't put the crush washer back on with the oil change (I never have replaced mine) it will leak oil... you can check this very easily... the drain plug is easily accessible... see if their is oil around the plug.
pjcoregon is offline   Reply With Quote
Old 10-23-2003, 01:59 PM   #6
VipersEatLotus
Member#: 21007
i had a very tiny drip in my oil after my oil change....i hadn't changed the crush washer yet (up to 25k miles) and decided it was tim to do that...and fixed.....start with the easiest solutions first....then work up......
big dave
VipersEatLotus is offline   Reply With Quote
Old 10-23-2003, 02:27 PM   #7
WRXMikeH
Member#: 30577
2003 WRX
I've never changed the crush washer, and I've never had a leak. Go figure.
WRXMikeH is offline   Reply With Quote
Old 10-23-2003, 03:49 PM   #8
ascott
Member#: 6545
Rally Blue Pearl
Re-using the regular Subaru supplied crush washer WILL result in a leak. Been there, done that.
I have not tried substituting a copper washer, though I've re-used those on other cars for dozens of oil changes.
Just remember to get the washer when you get the filter. If you don't buy your filters from Subaru (shame, shame), order a bunch of the washers from a dealer and keep them around.
ascott is offline   Reply With Quote
Old 10-23-2003, 04:01 PM   #9
Porkchop-WRX
Member#: 33293
2011 4-door STi
Plasma Blue
Another vote for the crush washer. Although one time (first time) when I changed my oil the rubber seal that normally comes off with the filter stayed stuck around that metal where the filter screws in. Needless to say I put the new one on and tightened it up. Started the car and pow I had like 2-3 quarts of oil on my driveway. Turned the car off right away. Pulled the seal off, re drained the oil and repeated process. PITA So make sure that when you do it yourself that something so simple doesn't get overlooked.
Porkchop-WRX is offline   Reply With Quote
Old 10-23-2003, 06:20 PM   #10
elsanto
Member#: 34832
1989 M3
another nod to the drain plug washer.. when i buy my filters from the dealer they allways throw one in the box.. subtle? nah but they wouldnt do it if it wasnt necessary.
elsanto is offline   Reply With Quote
Old 10-24-2003, 06:54 AM   #11
Rut-Ro
Member#: 45662
2002 WRX Sedan
Interesting…Every time I get an oil change I have a small drop on the garage floor over the next two or three days. Also, I smell oil during that period…..then it all goes away. I check my oil every time I fill up…no problem. I wonder why it would only do it for a couple of days?….spillage?,…. etc
Rut-Ro is offline   Reply With Quote
Old 10-24-2003, 10:01 AM   #12
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
I can get two oil changes per crush washer, so I just started changing it everytime.
Crush washer.
pegdrgr is offline   Reply With Quote
Old 10-24-2003, 10:25 AM   #13
elsanto
Member#: 34832
1989 M3
rut-ro do you do it yourself? If you do just make sure to wipe everything off when you are doing (oil pan & filter) If its leaking even the slightest bit it will be blatantly obvious if you look under there and check for dirt or oil you'll know if your leaking.
Old 10-24-2003, 05:14 PM   #14
Slowpoke
Member#: 19879
2004 WRX
Java Black
On my old car, I changed the crush washer probably once every 4 or 5 changes. Never got any leaks.
On the WRX I change it every time, just in case
Old 10-24-2003, 05:19 PM   #15
gbwrx
Member#: 39768
2013 WRX
Did you check the oil filter? Sometimes they don't put them on tight enough.
gbwrx is offline   Reply With Quote
Old 10-24-2003, 07:36 PM   #16
Rut-Ro
Member#: 45662
2002 WRX Sedan
No...I go to this Pennzoil shop here in Sudbury....very nice people; you could eat off the floor. The owner is a real car nut, I go for the conversation too... I'm going to get the washer changed net time....see what happens.
Oil Change -> Oil Temp and Oil Pressure gauge malfunction??? hostile silence Electrical & Lighting 3 04-18-2009 11:41 PM
oil change now REQUIRED at every 3,750 miles for turbos rsholland News & Rumors 81 10-12-2007 09:10 PM
Just did my first oil change/gear oil change since i got my car ayobreezie Newbies & FAQs 12 07-19-2006 08:29 AM
Mobil-One oil change, now rough idle blackdog Newbies & FAQs 22 10-29-2003 01:06 PM
10k Mi, Oil change....now what? Daven Texas Impreza Club Forum -- TXIC 7 06-25-2002 06:00 PM
