Old 10-23-2003, 05:24 PM   #1
compton
Member#: 10646
02 sti bugeye
still filthy
Default working on changing 02 wrx clutch need help!!!!
how do you seperate the engine from the transmission???!!!:
compton is offline   Reply With Quote
Old 10-23-2003, 08:02 PM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
1. Seriously shake the transmission.
2. Using a big flathead screwdriver and a hammer, punch the area where the transmission meets and engine.
3. Use 2 floorjacks. Work with them. Try lifting up transmission and lower the engine and vice versal.
4. Call and bring another helper or 2.
One of the reasons why it's stuck is because there are 2 alignment pins that maybe little rusted / oxidized. Spray them with wd-40 as well.
tmat3 is offline   Reply With Quote
Old 10-24-2003, 10:06 AM   #3
compton
Member#: 10646
02 sti bugeye
still filthy
Thanks for the info. We had a feeling those pins could be holding up because of corosion. We wanted to make sure we were not skiping some secret step. This transmission is very tight because we have been pulling on it like crazy. We'll keep trying.
Old 10-24-2003, 04:52 PM   #4
Kha0S
Member#: 8808
2011 WRX
DGM 5D
INCORRECT.
You're holding up because you probably failed to remove the release fork pivot rod from the case. Read your manuals again. Remove the pivot rod cover, screw a 10mm bolt into the hole, and pull the rod out. Pull up on the fork to release it from the release bearing, then pull the engine and tranny apart.
Search if you want more details.
/Andrew
Kha0S is offline   Reply With Quote
Old 10-27-2003, 10:15 AM   #5
compton
Member#: 10646
02 sti bugeye
still filthy
The release fork was out but that doesn't matter because the tranny is out so is the clutch CORRECT!! wd-40 on the steel alignment pins did help with the seperation
will a 04-05 wrx tranny work on my 02 wrx? wrxguy02 Newbies & FAQs 3 04-20-2008 02:19 PM
Deciding on wheels for my 02 WRX wagon....need help TurkWRX General Community 3 01-25-2008 12:58 AM
will an 05 sti front sway bar work on an 02 wrx crossmember? irishhockeypimp Brakes, Steering & Suspension 5 06-07-2006 11:53 AM
Will a 05 wrx MAF sensor work on a 02 wrx eddie1982 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-11-2006 04:42 AM
Will an 03 WRX rear diff work on an 02 WRX? zroom tsuchiya Transmission (AT/MT) & Driveline 3 03-17-2004 06:41 PM
