Old 10-23-2003, 09:25 PM   #1
tux
Member#: 40949
2003 wrx
wr blue
Default spare harnesses under dash
does anyone know what exactly these are for?
thanks
andy
tux is offline   Reply With Quote
Old 10-23-2003, 09:31 PM   #2
gallstone
Member#: 9078
2006 STI
Gray
Probably the harness used to read you CEL's- they plug into each other and the CEL code is displayed.
gallstone is offline   Reply With Quote
Old 10-23-2003, 09:36 PM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
If you're talking about the green connectors, leave them unconnected. They are used by the factory during shipment and disconnected at the dealership. I don't remember what they're for, but do not reconnect them. If you're talking about the single connecter with a trapezoidal connector, that is the OBD-II connection. You need an OBD-II scanner to read the codes. Connecting the 2 green connectors will not do anything.
Calvin
cnk is offline   Reply With Quote
Old 10-23-2003, 09:55 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Connecting the green ones together will put the ECU into a diagnostic mode where various relays and solenoids will cycle (you'll notice the fans going on and off) and the CEL will flash continously.
There have been numerous instances where people posted that they suddenly had these "symptoms" and wanted to know what was wrong with their car, and it always turned out that they or someone else had just been working under the dash and saw those connectors hanging loose and plugged them together.
Wtb 2002 Wrx Wire Harness Under Dash turbopro Private 'Wanted' Classifieds 1 08-29-2004 08:21 PM
Spare tire under hood 2004STiGuy 'Old School' Subaru Forum 43 08-26-2004 11:11 PM
spare connectors in dash tux Electrical & Lighting 12 01-28-2004 05:59 PM
The Green Harness under the dash? BillJC Electrical & Lighting 3 02-15-2003 08:15 PM
A Few disconnected Harness Under the dash above the footrest mo168 General Community 8 10-11-2002 01:35 PM
Message Board Statistics All times are GMT -4. The time now is 04:21 AM.
