Old 10-24-2003, 05:17 AM   #1
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Question Old school Subaru Water-intercoolers...
Just curious, what are the good and bad things about the old school subie water-intercoolers? Im thinking if I do a turbo kit ill go with one cause I wont need a hoodscoop or a front mount or anything complitcated... Unless of course a water-intercooler is complicated
I presume they are limited to only a certain PSI too, and after that point would loose effectiveness... But thats the sort of info im after.
Old 10-24-2003, 10:19 AM   #2
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
PM the user (-ImportInvasion-), he's using an A/W intercooler on his JDM GC8 engine.
Brent
scoobyimprza is offline   Reply With Quote
Old 10-25-2003, 02:35 AM   #3
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Is he the only one? lol
Old 10-25-2003, 05:02 AM   #4
Unsung Boxer
Member#: 37196
Im really insterested to know what he says. I was not aware that Subaru made a Water-Intercooler. Please reply when you find out.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 10-25-2003, 11:10 AM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Well, I'll say what all I know about them, but I don't know if I know enough.
When you use the A/W intercooler, you need another radiator and an electric waterpump just for the intercooler. I was told a small motorcylce radiator would work. As far as tubing, I was told the Porsche or VW or someone like that had a hose that I could use from the turbo to the intercooler. I'm not sure about a BOV though, since there is no mounting spot.
I did have an idea though, that would eliminate the seperate waterpump and radiator. On my WRX waterpump, there were two extra holes that I had to plug that I didn't have on my first waterpump. My idea is to run the feed and return lines off of there to the intercooler. Maybe that'd work, I'm just theorizing though.
I hope this helped some.
Brent
Old 10-25-2003, 12:13 PM   #6
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
Brent
If I understand what you're proposing, you're suggesting running coolant from the engine through the intercooler. You don't want to cool an air/water intercooler with the same coolant that's running through your engine. It's far too hot - 200+ degrees (F) once the engine's warmed up. Unless you're running fairly high boost pressure, that would mean the water would be hotter then the air you're trying to "cool". Plus, when you're off boost, you'd always be heating the air up to near the temperature of the engine.
Perhaps I didn't follow you though. Please elaborate if I've misunderstood you.
_Jeff
Portly is offline   Reply With Quote
Old 10-25-2003, 12:25 PM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Yeah, you understood me correctly. I didn't even think about the coolant being too hot. Yeah, you're right.
Yeah, so you'll need an electric pump and a small radiator then.
Brent
Old 10-25-2003, 01:47 PM   #8
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
STEALTH-WRX is has one... but he made it himself.
I think the only problem with them is once the water gets hot you SOL...
On the intake pipe... between the compresser and the TB
Old 10-25-2003, 05:19 PM   #9
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
I dont think the water will get that hot, its rather insulated... And if its that complicated with radiators and such, which I dont think it is cause the Legacy doesnt have anything like that, then it would be an awefully big hassle...
Im only gunning for 5-6psi anyways, so I dont need much in the way of an intercooler...
Old 10-25-2003, 05:46 PM   #10
totoherbs
Member#: 7321
.... 122 IggPoints
Old 10-25-2003, 10:44 PM   #11
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
tons of info in the conversions forum. we have covered it and killed it.
subiekid is offline   Reply With Quote
Old 10-26-2003, 06:42 AM   #12
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Just read through alot of posts about it... Seems like the best thing for me would just be the stock Legacy setup including the pump and radiator... However, thats quite a bit extra weight... But it will be far more cost effective for me as I wont have to buy/paint a new hood or get a FMIC.
Im wondering, does anyone just run the pump to a manual/auto switch? Like so you can turn it off sometimes, because I would think having the pump constantly flowing would actually heat up the water at times... I did read that the legacy pump had two speeds, which might address this.
Old 10-26-2003, 07:03 AM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
I dont think thats a good idea... then you would have heat soked the water which would lower its effectiveness. Old school trubo celicas had a set up like that... They change the pump to run all the time and not just underload.
Do you have a link?
Old 10-27-2003, 01:09 AM   #14
FJP
Member#: 43852
GC8 2.5RST
They really are not very effective. Front mounts are not that more expensive than top mounts, and way more effective.
FJP is offline   Reply With Quote
Old 10-27-2003, 01:12 AM   #15
totoherbs
Member#: 7321
.... 122 IggPoints
I think they are effective... but for a limited time. As the water heats up it becomes useless and theres no way to get cold water in there.
Old 10-27-2003, 05:32 AM   #16
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Like I said though, im not looking for VERY effective... Heck, at the PSI I will probably run I could go without an intercooler, but seeing as I can get a air-water as easy as I can get a top mount (I cant afford a front mount) which would actually just end up being an old Saab top mount intercooler cause I dont need much or need to try and squeeze in a WRX intercooler. But I just dont have a hood scoop, and any hood + repaint job will equate to costing 75% of my total turbo kit budget which is not an option.
Old 10-27-2003, 09:25 AM   #17
djplegacy
Member#: 33367
2008 Legacy GT Limit
QSM
I understand your problem, I am in the same boat. 2000 Legacy (no scoop) with Ludespeed kit. I have contacted an Austrailian wrecking yard (Shore City Engines) about the old style Air/Water and they replied that they can send one for about $300 plus $50 shipping. The only thing I am hesitant about is the pipe from the turbo to the IC, this would have to be customized.
David.
djplegacy is online now   Reply With Quote
Old 10-27-2003, 04:55 PM   #18
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
David.
Thats why im thinking of using all the old Legacy turbo piping that I can get as well along with the intercooler, so that hopefully everything will bolt up relativly fine... I havent decided if a crossmember swap is a good idea though, as it might be just as easy to have a uppipe made.
Old 10-27-2003, 07:19 PM   #19
FJP
Member#: 43852
GC8 2.5RST
Better get the intake manifold too!
Old 10-27-2003, 08:14 PM   #20
wawazat
Member#: 13793
2007 specB, 03 Ram
'92 SVX-5 speed
That's the reason for the secondary heat exchanger. The water absorbs the heat from the compressed air, the pump circulates it to the secondary heat exchanger which then releases it to the atmosphere. Sizing is the key. Water has a much higher specific heat than ar so it can absorb much more energy. Pumping it through the secondary heat exchanger, in my case a 2.5 RS radiator core, is where it is cooled and circulated back to the system. I'm nowhere near implementing my system, but it can be done effectively.
wawazat is offline   Reply With Quote
Old 10-27-2003, 10:00 PM   #21
totoherbs
Member#: 7321
.... 122 IggPoints
I agree... after seeing stealths in real life I was sold, I was just refering to the stock....
I see where you might want the old school subaru one... but it seems ify to me... good luck and keep us informed on how it works out.
Old 10-28-2003, 01:38 PM   #22
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
I am running this setup on my car right now, I have a Subaru Liberty air water intercooler, with a johnson pump, a litlle radiator from a motorcycle and a custom made reservoir for water so i can pour some ice in it whenever I want to. Ill try to post some pictures so you can have an idea of it. Im also using a switch to turn the pump on anf off.
Santo Domingo 2.5 RS is offline   Reply With Quote
Old 10-28-2003, 08:37 PM   #23
Rabidbyte
Member#: 36039
2001 Impreza 2.5RS
Santo, a diagram of your setup would be cool. Even better a DIY Howto would awsome........
Rabidbyte is offline   Reply With Quote
Old 10-29-2003, 05:19 AM   #24
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Post Air/Water Intercooler
Here is some information about air/water intercoolers.
Legacy BBS
I was/am interested in this as well.
Kevin Thomas is offline   Reply With Quote
Old 10-29-2003, 06:02 AM   #25
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Default Re: Air/Water Intercooler
Legacy BBS
Ya, read that one, good info.
Lots of Old School Subaru Manauls for sale on eBay DoDO Brown 'Old School' Subaru Forum 0 11-20-2004 10:13 PM
Old-School Subaru Door-Chimes Warface Car Audio, Video & Security 0 07-22-2003 09:55 PM
links to old school Subaru boards please. Dealer Xing Tri-State Area Forum 4 12-15-2002 04:18 PM
Old School Subaru wheel conversion (4x140 to 5x100) riddler Brakes, Steering & Suspension 0 03-29-2002 11:00 PM
('93-'01) Old, Old School. Subaru Loyale GPZ Impreza Forum 12 03-01-2002 10:16 AM
