Old 10-24-2003, 10:28 AM   #1
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Default JDM V7 vs. V8, AVCS hookup questions
Ok so we finally got around to putting more stuff together on my new engine (2.5L STI block, V8 RA heads). I bought a V7 STI engine harness from AV Sport awhile back. It's pretty much identical to the US WRX harness only it has connectors for the AVCS solenoids and additional cam sensors and no TGV plugs.
We got to test fitting the engine harness yesterday and it turns out the AVCS solenoid plugs are the same, however the sensor plugs are not. The sensors are still magnetic pickup sensors but I don't know what else might be different about them. I knew the V8 engine harness and ECU were different from the V7, I guess this is one of the differences.
My first question is does anyone know the exact differences between the V7/V8 sensors? That being highly doubtful, does anyone know what some of the electrical outputs are for the V7 sensors, at idle or while the engine is running? It's just a 2-wire plug so it should be easy to measure.
How do most guys run the wiring for the AVCS stuff? I was thinking theoretically you could just run the 8 wires from the sensors/solenoids directly to the ECU and wouldn't even need the engine harness with the plugs on it. Otherwise where do pick up the right wire for the ECU, at the ECU harness in the car? Here is a picture of the right-hand head which has only the rear sensor for the AVCS, it's a male plug. The harness I have also has a male plug...
Also, I have a V7 STI ECU that I'll be using.
Thanks.
Old 10-24-2003, 02:44 PM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
bump.
Old 10-24-2003, 06:25 PM   #3
downshift1
Member#: 15607
I'm not the type
to make angry
Phil-
Do you have the little white connector or the grey connector?
If all you have is the whit connector you need the little jumper wire.
-Dylan
downshift1 is offline   Reply With Quote
Old 10-25-2003, 02:58 AM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Just the white connectors.
Old 10-25-2003, 03:43 AM   #5
EMS
Member#: 14116
Dylan is right, you need a short jumper wire which is between the little white connector and the sensor!
Mark.
EMS is offline   Reply With Quote
Old 10-25-2003, 01:59 PM   #6
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Ok so there is an extension of some sort between the two I take it. I'll talk to [email protected], I'm sure he has some around.
Old 10-25-2003, 03:26 PM   #7
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Try talking to Clark (AZScoobie) or Ron @ Axis. Im sure they could provide you wiht some more info.
Need4Boost is offline   Reply With Quote
FS local: JDM V7 Heads/V8 Valvetrain, Raw EJ22T block & crank, other random stuff jpmarotta New England Impreza Club Forum -- NESIC 8 04-21-2005 07:01 PM
Any difference between STi JDM V7 and V8 seats? projectrally Interior & Exterior Modification 4 08-31-2004 10:50 AM
V7 vs V8 questions?? 2000wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-30-2004 07:51 AM
JDM V7 vs V8 Suspension Dong9mong Brakes, Steering & Suspension 7 07-08-2004 12:47 PM
WTB: JDM V7 or V8 suspension takeoffs, complete heffergm Private 'Wanted' Classifieds 2 04-13-2004 09:25 PM
