Old 10-24-2003, 01:06 PM   #1
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Default ARP head stud final word in here
Just got off the phone with ARP direct. The application is for an aluminum block, so all of us EJ 2X users.
Maximum toque when using the supplied lube is 65ft lb final torque rating. Go 25-45-65. Hand tighten the rods in the block DO NOT TIGHTEN THE STUDS PAST THIS, STRIPPING MAY/WILL OCCUR
Maximum toque when using 30 weight oil is 80ft lb.
Please take note to this as the company that I purchased these from (crawford performance) told me to torque to 85ft lb. The ARP rep did not agree with this at all. 'Stripped heads for sure' is what they said word for word. I'm not sure who to listen to.
Also, I was told to do the factory bolt sequence but not suppose to back out 180 degrees, etc that the service manual shows.
I hope this information helps the masses. More to come once I put mine on.
Oh, and they wanted me to warm up teh car and then let it cool 100% off then retorque the studs. To bad that would require full engine removal.
IA Performance is offline   Reply With Quote
Old 10-24-2003, 01:15 PM   #2
2000vfr800
Member#: 15599
Oh, and they wanted me to warm up teh car and then let it cool 100% off then retorque the studs. To bad that would require full engine removal and I won't do that.
Yea...because what do they know...
2000vfr800 is offline   Reply With Quote
Old 10-24-2003, 01:20 PM   #3
IA Performance
Member#: 25194
Dark Gray
well, unless you want to help me do the added 20 hours of work to do so them feel free you have to pull the motor, pull the cams, and then stuff it all back.
In then end I may just use the stock studs since I hate being a guinea pig of sorts.
Old 10-24-2003, 01:22 PM   #4
mlambert
Member#: 13831
Maybe thats why Quirt said 85. How many motors has he built? More than cobb would be my guess.
mlambert is offline   Reply With Quote
Old 10-24-2003, 01:24 PM   #5
LargeOrangeFont
Member#: 28475
86 RX-7, 07 Yaris,
2010 CTS-V
Count me in for the install, deinstall, install 60 hour marathon meet.
LargeOrangeFont is offline   Reply With Quote
Old 10-24-2003, 01:38 PM   #6
2000vfr800
Member#: 15599
Just giving you a hard time...
There are multiple engines being built right now at Payn using ARP head studs so you aren't going to be the guinnea pig...
Old 10-24-2003, 01:43 PM   #7
IA Performance
Member#: 25194
Dark Gray
Shoot, times when I wish Sponaugle would reply to PMs and emails
The last thign I want to do is pull this girl back out of the car due to a leaking head gasket.
Old 10-24-2003, 01:55 PM   #8
Crawford Performance
Member#: 42075
I am sorry that ARP dose not agree with my torque specks.
I designed the studs three years ago, and back then did the R/D on the propper torque for my application.
I have installed these studs in over two hundred motors, and have come up with a pattern and torque that has been working for years.
I Freely gave you my "hard earned" information on the recomended torque and this is what I get in return. Thanks!
It seems that Jeff Sponaugle is having no problems with the studs that he purchased from me, using my recomended torque.
What was it that I did to you to deserve this slam?
And for those of you that are interested, I have never had a stud strip out.
Quirt Crawford
Crawford Performance is offline   Reply With Quote
Old 10-24-2003, 02:06 PM   #9
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
What slam? I don't see any slam at all.
jblaine is offline   Reply With Quote
Old 10-24-2003, 02:17 PM   #10
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Quirt Crawford
I am getting so damn tired of the internet and these forums. Vendors feel like we (consumers) owe them something. You have to tread lightly with them or they get pissed off. If you question something then thats a slam. This has to be the single worst form of communication on earth.
Quirt, With all due respect man... Who gives a crap who designed what and who gives a crap how your feelings play out in this. The guy purchased Bolts, He now has three sets of instructions for install, He spent ALOT of money on this motor and is worried and wondering which way to go.... All he needs is advice and reasurance...
Clark
AZScoobie is offline   Reply With Quote
Old 10-24-2003, 02:21 PM   #11
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
I know Quirt works very hard to supply people, including us, with accurate information. Hell, he works very hard all the time on anything. Perhaps he just took some comments to heart?
In any respect, Id trust Quirts information rather than some representative over the phone that probably has no where near the experience as Quirt does.
Chris
I-Speed USA
[email protected]
Crawford/I-Speed is offline   Reply With Quote
Old 10-24-2003, 02:22 PM   #12
IA Performance
Member#: 25194
Dark Gray
dang, no slam intended.
Ok, so I do the factory sequence but use your 20-40-65-85 specs? Is this with the ARP lube or with motor oil?
Please help me out as I am a customer that is tired of different information from 3 different solid sources.
Old 10-24-2003, 02:45 PM   #13
nmyeti
Member#: 4980
Clark
With all due respect you are not longer just a consumer. Id say that between your relationship with Dyno-comp and your weekend tuning trips youve moved past that.
The second you started tuning cars for money you became a vendor.
nmyeti is offline   Reply With Quote
Old 10-24-2003, 02:48 PM   #14
Member#: 42075
Sorry, I take what I do very serious.
I am available to answer your questions, but only if you ask!
I use the lube that I supplyed with the studs.
If you ask three different people the same question, you are bound to get different answers. That is human nature. Add performance to the equation and our egos seem to take over.
This is the exact process that I use.
First I make sure that nothing is at the bottom of the stud hole in the block. Do NOT use a tap to chase / clean the threads.
Then I put some oil on the bottom threds of the studs.
I then run them in untill they bottom out in the block, "they must bottom out".
Install the gasket and head.
Put the lube on the studs so that when you put the washers on there will be lube between the head and washer. Look at the washer and put the rounded outside edge against the head.
Put more lube on the studs, then install the nuts. Extra lube is better than not enough.
Torque to 20 ft lbs.
Torque to 40 ft lbs.
Torque to 60 ft lbs.
Torque to 85 ft lbs.
I let the motor sit for an hour or so and then retorque at 85.
If you are anal, retorque after running the motor.
I have checked the torque after running on the dyno and during tear down, the only time I see a change is when the motor has been overheated.
Good luck,
Quirt Crawford
Old 10-24-2003, 02:54 PM   #15
Thomas Ruble
Member#: 12694
02 WRX/JDM EJ207RA
Unabomber Eeee-thug
Quirt, thank you.
Tom
Thomas Ruble is offline   Reply With Quote
Old 10-24-2003, 03:04 PM   #16
IA Performance
Member#: 25194
Dark Gray
Thank you for the very complete write up. I appreciate your help and will install these later on tonight.
Quirt, for the $10,000 question, does anything change if I use a cometic head gasket that is 2mm thick specific for the sti 2.5L?
Old 10-24-2003, 03:19 PM   #17
Member#: 42075
As for your $10,000 question, If the gasket bites into the head and block then I would recomend that you torque the head then loosen the nuts and then re-torque. Otherwise nothing will change.
Quirt
Old 10-24-2003, 03:21 PM   #18
mustardrex
Member#: 34103
08 STI
I've never had to retorque the head studs on any of the motors i've built, be it subaru, ford, etc.. i wouldn't worry bout it.
As for the labor involved, last time i pulled one of my heads, i didn't need to remove the motor, and only took 6 hours from removal to reinstallation (for one side anyways), so it wouldn't be THAT bad.
mustardrex is offline   Reply With Quote
Old 10-24-2003, 03:37 PM   #19
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I installed my heads onto the 2.5 block last week sometime, with ARP studs, I thought it was all pretty self-explanatory...
Old 10-24-2003, 03:47 PM   #20
IA Performance
Member#: 25194
Dark Gray
:P
Call me paranoid after reading a thread where a guy stripped his block.
Old 10-24-2003, 03:53 PM   #21
AZScoobie
Member#: 8785
netcom.com
Nice.. Following me around on the forums Nathan? Come on man.... Dont hold a grudge because I used another turbo builder man.. Its not that big of a deal dude.
That "second" happend in 1994 when I started operating a Dyno. I do not sell anything on the forums, I dont sell parts, I dont post advertisements and never offer to tune anyones car in posts. People come to me via email to request my services. Mainly due to word of mouth. I meet the requirements of this sites policy.
Q, Thanks for the Post man. I am going to copy that into a File and save it. Full of information. Sorry to post like that on this thread but thats what you should have responded with in the first place. Thanks!
ECS, Please do me a favor, Dont use my $19 trq wrench to trq these heads down. I think this calls for a real wrench that is calibrated :P
Clark
Old 10-24-2003, 03:57 PM   #22
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
Originally posted by East Coast Scooby
:P
Its really easy to miscalibrate a torque wrench....maybe thats what happened.
STR8OUT is offline   Reply With Quote
Old 10-24-2003, 04:19 PM   #23
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Look at it this way... the very worst that can happen is that you blow a head gasket (if you don't overtorque and pop the threads... which I have NO idea how that guy did it).
Old 10-24-2003, 04:26 PM   #24
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
Was gonna say 'bark!' to all the controversy..
Anyway, why not use a tap to clean, de-bur. In the past I did this. Was recommended on other engine builds. I am only an amateur and mean no disrespect and am really curious why this is a no no.
As for a re-torque after a cool down. Seems to make sense but mabye not worth the effort if you have to remove the motor. Especially if you are careful about the initial build.
tolnep is offline   Reply With Quote
Old 10-24-2003, 04:34 PM   #25
IA Performance
Member#: 25194
Dark Gray
I just opend the box up an the cometic HP are a crush style and the service rep recommended not to back off the bolts when using them. In fact, they suggested not to use these gaskets if you are using the stock studs since you need to back them off.
ARP head studs V's OEM sti head bolts bugeyes Built Motor Discussion 88 04-24-2016 06:40 PM
JDM V7 heads and ARP Head Studs r0n Engine/Power/Exhaust 20 01-05-2010 03:35 PM
***Innovative Tuning crate engines, head work, NEW ARP Head Stud Kits, and MORE!!!*** Innovative Tuning Engine/Power/Exhaust 17 07-22-2008 03:33 PM
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 12:05 PM
ARP Head Stud Install Question -- Urgent seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 14 05-21-2003 04:57 PM
