Old 06-19-2000, 04:56 AM   #1
Flea
Member#: 1658
2013 Impreza Sport
Satin White Pearl
Have a Nice Day? Airbag light won't shut off...
A few weeks ago my airbag light refused to shutoff once I started driving...I finally brought it in to the dealer to get checked out. Since I'm over the 36,000 miles (I've got a '98 OBS) it's supposedly not covered under the warranty.
They plugged it into their computer and it came up with a couple of error codes-which basically told them there's something wrong- But they don't know what it is. Now they're saying they've got to spend 3-4 hours (at $65 per hour) to go through the wiring to figure out what might be wrong.
I've always taken it to the dealer for all tune-ups, so the service guy said he'd get ahold of the Subaru rep to see if they could find a way to get it covered...if not 100% maybe 50-50...
I'm just hoping they cover it 100%. If I get in an accident, and my airbag doesn't work...well, let's just say I'll be writing some letters if they don't cover it...
Has anyone else had any weird wiring things happen?
Flea is offline
Old 06-19-2000, 05:33 AM   #2
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
My little sister's VW is also having the same problems you just discribed. Car just out of warrenty and electrical problems including a lit air-bag light (started off with blowing the brake lights every month + the brake light fuse).
Someone recommended trying to reset the ECU, which might be sending the warning lights in error. I'm going to try that on the VW as soon as I figure out if the ECU reset procedure is the same as the Subaru.
Revision is offline
Old 06-19-2000, 06:13 AM   #3
wolve80
Member#: 1339
Have a Nice Day?
huh? I thought all safty devices were warrented for the life of the car.
wolve80 is offline
Old 06-19-2000, 06:30 AM   #4
Revision
Member#: 242
MY05 PSM GGA !STOCK
Post
So did I.
All I know is, this family is NEVER going to buy a VW again. They are too complex to work on and this one has been having too many problems.
Revision is offline
Old 06-19-2000, 06:31 AM   #5
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
Post
I believe safety stuff is covered for at least 6/60k or something (like the rust through warranty)
-mike
Paisan is offline
Old 06-19-2000, 06:34 AM   #6
Revision
Member#: 242
MY05 PSM GGA !STOCK
Post
Already been to the dealership.. Still talking to regional rep. And the Dealership service department has been exceptional, so it is not a problem with service.
Revision is offline
Old 06-19-2000, 06:38 AM   #7
Jay_UK
Member#: 296
Cool
Howdy,
They should be able to identify the problem.
The monitor/computer device will pinpoint faults down to individual sensors. It has a test faulty built in that allows them to test each part of the system.
The Air bag system actually has its own computer. Located in the centre console.
J.
Jay_UK is offline
Old 06-19-2000, 06:50 AM   #8
tulit
Member#: 338
09 STi
Post
I wouldnt be worried about it not going off during an accidient, but rather it going off while you're just driving around.
Any warnings related to safety equipment should be checked RIGHT AWAY. Not after a few weeks !
tulit is offline
Old 06-19-2000, 06:56 AM   #9
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Post
Yeah, this is real important. I would not be driving around in it with the light on.
And, I also think it is covered for at least 5yr/60k, or life.
Has the car ever been hit in the front/repaired before?
Paul G.
paultg is offline
Old 06-19-2000, 06:59 AM   #10
wolve80
Member#: 1339
Post
I'm gonna check my warrenty booklet in a few mins, I'll post up what it says about the SRS.
wolve80 is offline
Old 06-19-2000, 07:14 AM   #11
Jay_UK
Member#: 296
Post
Hi again,
If the light is on,
Then the air bag system will be disabled *normally*
J.
Jay_UK is offline
Old 06-19-2000, 09:17 AM   #12
Flea
Member#: 1658
2013 Impreza Sport
Satin White Pearl
Post
The service manager said that it wouldn't just go off as I'm driving around...that would be way too dangerous, but that it most likely wouldn't engage if I got in an accident.
When the problem first started to happen, the warning light would go off as normal, until I turned a corner or went up a hill...which led me to believe it was just a faulty sensor. That's why I waited to have it checked.
I've never been in an accident, that's why I believe that once they talk to the Sub rep, I'll probably not have a problem getting them to cover it.
I also was under the false impression that the airbag would be covered for the life of the car...but it doesn't appear to be the case.
I'll keep you all posted on what happens!
Flea is offline
Old 06-19-2000, 09:47 AM   #13
wolve80
Member#: 1339
Question
it's a tough call on the warrenty, here in the manual it says "SEAT BELT COVERAGE lasts for the useful life of the vehicle and includes seat belts and related components which fail to function properly."
The Airbag is an SRS and is only ment to be used in conjuction with the seat belts, this would lead me to belive that the SRS is covered by the seat belt warrenty. Call up SOA and ask them.
wolve80 is offline
Old 06-19-2000, 08:08 PM   #14
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Exclamation
Do your horn and cruise work? If not, I'd bet it's the combination switch. I just had mine replaced (under warranty) in my 1999 2.5RS. I originally noticed only the AIRBAG light but then later realized the cruise and horn didn't work (since I don't use either that often).
Shane "Warp3" Warren
1999 Subaru Impreza 2.5RS
http://jump.to/warpthree
Warp3 is offline
Old 06-19-2000, 08:35 PM   #15
Revision
Member#: 242
MY05 PSM GGA !STOCK
Post
The VW airbag light was fixed for free, even though it was 1000 miles out of warrenty. Now that is customer service.
Still ticked off at the car though.
Revision is offline
Old 06-27-2000, 12:49 AM   #16
Flea
Member#: 1658
2013 Impreza Sport
Satin White Pearl
Post
Well,
here's the latest! (by the way, my horn does still work...)
The dealer contacted their SOA rep, and the diagnostic (the 3-4 hours it's going to take for them to figure it out...) is going to be covered by them. Even though I'm well over the warranty (43,000) Once they've had it all day (I hate to leave my car!) they'll talk to the rep again to see if the repair will be covered too. I'm keeping my fingers crossed.
Either way 3-4 hours at $65 an hour...I'm glad they're helping out on that front!
I'll keep you posted on what exactly is the problem!
Flea is offline
Old 06-27-2000, 12:54 AM   #17
BryanH
Member#: 993
Post
FWIW, seat belts and other mandatory safety equipment(airbags) are covered for the life of the car under federal law.
I know this because my moms 1992 Buick just got the seatbelts replaced and this is what the service manager told me when I went to go pick it up for her.
BryanH is offline
Old 06-27-2000, 05:17 AM   #18
Flea
Member#: 1658
2013 Impreza Sport
Satin White Pearl
Post
They're claiming it's an "electrical" problem...so I'm not sure if it falls under that law or not. Either way-I'm hoping not to have to pay a dime!
Flea is offline
Old 06-28-2000, 01:26 PM   #19
direwlf
Member#: 1479
1999 Impreza 2.5RS
Silverthorn Metallic
Post
This is probably a bad roll connector in the steering column. Mine dropped dead after about 10k kilometres. Replaced under warranty by dealer, but took several weeks to get the parts. If you horn and cruise don't work also, this is likely the problem.
direwlf is offline
Old 06-30-2000, 09:46 AM   #20
Flea
Member#: 1658
2013 Impreza Sport
Satin White Pearl
Thumbs up
Well, just talked to the dealer.They've had my car in there all morning trying to figure out the problem. They've found that it's the "Airbag Controller" it costs about $1200, but after they talked to their Sub. rep, Subaru is paying for it.
I'm really pleased so far with how this has turned out. Let's just hope that once the part comes in, and it's installed, that's what the actual problem is!
Either way, no money out of my pocket yet!
Flea is offline
Old 06-30-2000, 09:49 AM   #21
Jay_UK
Member#: 296
Cool
cool
thats great news..
I just wished Subaru UK (IM) was so good..
there again I dont care.. I drive an import... haha
J.
Jay_UK is offline
HTML code is On
Dome light Won't Shut OFF!! djerickd Electrical & Lighting 20 07-12-2011 12:46 PM
Airbag light won't turn off ace1234 Electrical & Lighting 1 12-26-2009 12:09 AM
Hazard lights won't shut off!! 3crows Newbies & FAQs 2 02-11-2008 02:38 AM
Parking lights won't shut off Kraziken Legacy Forum 23 05-05-2004 10:39 PM
my driving lights won't shut off what should I do? Jerry Seagreaves Electrical & Lighting 5 05-20-2003 11:33 AM
