Old 10-24-2003, 05:29 PM   #1
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Default 3" of clutch free play = very bad?
So I got a new clutch and flywheel installed at a dealer last week, and as I drove off I noticed there was 3" of free play in the clutch pedal. It was kinda fun to drive around that way, biting point close to the floor and everything, and I didn't think much about how it could be a bad thing - after all, many cars have biting points close to the floor, right?
Well anyway, today I take it in to another shop and by chance the mechanic said that 3" of free play is extremely bad. Searching around the forums here, I've come to the same conclusion too - thinking back on it, it was kind of hard to shift into 5th gear at times.
Plus, for the last 8 days there would be this weird smell coming from the clutch/transmission every time I drove - I thought that was just something that new clutches do - but now I should have caught on that something went wrong!
jey is offline   Reply With Quote
Old 10-25-2003, 01:13 AM   #2
VOLTIS5
Member#: 2353
98' LegOver GT
dark whiteish pearly red
IIRC, average free play is about 1". If the free play is excessive, the clutch may not release completely. This can cause hard shifting, gear clash and damage to the gear teeth.
VOLTIS5 is offline   Reply With Quote
Old 10-25-2003, 04:49 PM   #3
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Ok, so the auto mechanic didn't do it right - he adjusted it to very little free play - so little, in fact, that the clutch started chirping when it was engaged! I drove around that way for about a day.
Doing a little research, I discovered that meant the throwout bearing is pushing just slightly on the on the clutch release fingers. Doh! I went back and adjusted it to 1", but the clutch still chirps a little when I push it down to the 1" point, obviously. Is that bad?
Also, my old clutch had the chirping problem, and soon after the clutch started to get really worn. Don't tell me all I had to do was adjust the free play and therefore prevent my clutch from eating itself...
Old 10-25-2003, 09:23 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I am assuming a stock clutch?
I went with an ACT clutch and it engages very near the floor, but a stock one should be a lot higher.
Old 10-26-2003, 03:23 AM   #5
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Yes, it's a stock clutch with a Fidanza flywheel.
Adjusting free play of the clutch pedal? o2sys Transmission (AT/MT) & Driveline 1 10-06-2005 08:54 PM
How much free play should be in 05 sti clutch popnfresh Transmission (AT/MT) & Driveline 1 04-15-2005 03:50 PM
question about a very bad clutch sleek Off-Topic 8 12-02-2004 10:18 PM
The free-play on my clutch keeps on changing! tmat3 Transmission (AT/MT) & Driveline 10 08-22-2003 12:45 PM
where is the clutch free play adjusted? dave_the_driver Service & Maintenance 1 12-13-2002 03:19 AM
