Old 10-25-2003, 04:36 PM   #1
scottdunsmuir
Member#: 46022
1996 Legacy 2.2L
Green
Unhappy Overheating 96 Legacy
I've changed Headgaskets, Water Pump, Timing Belt, Thermostat, Hoses, Flushed Radiator, Replaced Radiator Cap, & the the car still pump all the fluid into the overflow when driving then eventually starts overheating. The Cooling Fans both work. When inspecting the heads when gaskets were changed no warpage or visual cracks. No water in oil or loss of power. Haven't pressure checked. I'm throwing up my hands any ideas?
scottdunsmuir is offline   Reply With Quote
Old 10-26-2003, 09:19 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Get a leakdown test done. You may have a crack which is overpressurizing the coolant system.
Also a compression test (not as good as a leakdown test).
How did you check for head/block warpage? The tolerance is pretty small and could have been missed if you don't know what you are doing.
Old 10-27-2003, 04:15 PM   #3
eVoMotion
Member#: 44524
2005 OBXT Wagon
Check out this thread about overheating.
http://forums.nasioc.com/forums/show...hreadid=184026
eVoMotion is offline   Reply With Quote
Overheating problems Legacy 91 manual Paul V Normally Aspirated Powertrain 12 11-18-2005 09:30 AM
97 OBS vs. 96 Legacy L? wtedgecliff Newbies & FAQs 3 06-28-2002 10:18 AM
96 Legacy L Wagon Questions! vice Legacy Forum 2 11-07-2001 02:27 PM
99 Legacy wheel on a 96 Legacy? nuburu2 Legacy Forum 23 12-30-2000 09:27 AM
Trailer Hitch for 96 Legacy Sedan? dtrayers Legacy Forum 1 10-26-2000 06:30 AM
