Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > General Forum Archive
Old 01-15-2001, 09:18 PM   #1
Bumsarama
Member#: 3137
2005 STi
WRB Nukabe/Cusco/Carbotec
Question Need help with hp increase!!!!!!!
I am pondering whether or not to go Turbo. Supercharging would also be an option. What kind of turbos do you guys have. Any preference between turbo and supercharger?? What kind of CONFIRMED 0-60 times/Quarter-mile times. Is stage one turbo reasonable enough or is stage two necessary. What kind of Confirmed horsepower readings. Is a ECM necessary. How fast did Sport Compact Car get their Sube to go?? Most of all, how realiable is it???? Any one with blown engine stories?? Need major input. Any help appreciated. Sorry to bombard you guys with all these questions. On a side-note, please make the effort guys to make it to the big Sube meet in KC.
Bumsarama is offline
Old 01-15-2001, 11:22 PM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
Lot's questions, too tired to answer all Q's, but too friendly to simply say do a search
I have a small IHI turbo (like the one on the old legacy turbo) with 5 psi, and just an AFC and rising rate fuel pressure regulator for tuning. I have a 6x18 intercooler, so I believe I am stage II.
Gtech qtr mile times before were 16.7 @ 84 with intake only, at 6000 feet above sea-level. Afterwards the times dropped to 14.65 @ 97.5 (really 95 at 6,000 rpm 4th gear). O-60 dropped from 8.98 sec stock to 8.4 with intake only, to 6.22 with turbo.
We estimate from the qtr mile times that HP at the wheels is at least 175 at 6,000 feet above sea-level, vs 95 hp stock at this altitude. This is vs 128hp at near (but slightly above) sea-level for a stock car.
You can do a stage I with no intercooler and ECM if you have a rising rate fuel pressure regulator, but will get more power with at least a colder intake charge using an intercooler. As for reliability, they do pretty well - with low power turbo kits the clutch seems to hold up well, as do the head gaskets, etc... My clutch had a lot of hard launches when stock, and died three days after the kit was installed.
Larry www.ImprezaRS.com
ImprezaRS dot com is offline
Old 01-15-2001, 11:26 PM   #3
rsquire
Member#: 265
1998 22B Blue
1986 Ford RS200 White
Post
Simple really
Supercharger around these neck of the woods = frigging disaster. Well except for ARG's
Turbo has been on my car for more than 21000 miles with no problems
Richard
rsquire is offline
Old 01-15-2001, 11:27 PM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
For being tired that is quite a post Larry!
Yeah, you can find all you need to do by doing a search for "Turbo" and "What for more horsepower"
Eric
Eric SS is offline
Old 01-16-2001, 12:58 AM   #5
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
Nice thing about turbos is that once you get one on, big gains are much easier. Im putting on a stage 1, non ic kit at 5psi. I expect 200-220 hp out of it. (being much closer to sea level in chicago, Im betting I get similar times to larry though I wont have a IC) Addind a IC will give you noticable more power, adding a better exhaust will give you more power(much more than NA) etc, etc. IMHO a low pressure turbo wont really shorter the life of your engine much.
Midwayman is offline
Old 01-16-2001, 02:19 AM   #6
WRX Pilot
Member#: 3487
Post
If your interested in 1/4 mile and 0-60 and want cheap and dependable, go with NOS.
WRX Pilot is offline
Old 01-16-2001, 04:05 AM   #7
Buckbomb
Member#: 2573
Post
True but NOS is also (in most applications)really hard on an engine. Especialy if you haven't upgraded to more durable parts. IMHO a small turbo with an IC would be the best for a street car, especialy a daily-driver. Just my .02.
Buckbomb is offline
HTML code is On
HP Web Jet Admin noob- need help with discovering Domain printers MK19_ Off-Topic 5 03-22-2007 12:23 PM
Need help with Dyno Conversion of hp Sti"izzle" Proven Power Bragging 14 01-17-2007 05:23 PM
need help with BIG HP APPS.... dubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-02-2003 02:46 AM
I need help determining HP for MY00!!!!!! Rubasu General Forum Archive 4 01-18-2001 12:00 AM
Need help with HP increase!! Bumsarama Normally Aspirated Powertrain 2 01-15-2001 09:53 PM
