Old 10-25-2003, 09:23 PM   #1
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
Default Autometer Electronic Oil press. gauge Fritzin out
The Oil Pressure needle is going haywire when ever the oil pressure drastically changes...i.e. when at a complete stop and accelerating at any rate.
The gauge is electronic and has a seperate bulb mechanism where the oil is actually sent and sends the reading to the gauge via wires.
has anyone ever had this problem?
Turbo9000 is offline   Reply With Quote
Old 10-26-2003, 01:04 AM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
How exactly did you install the sender unit? If it only has one wire running to it, perhaps there is a bad connection, or if you used lots of sealant on the threads when screwing it in, perhaps it did not make a good electrical connection with the block (ground).
Also, what exactly does "going haywire" look like, and when exactly does it happen, and when does it NOT happen?
Old 10-26-2003, 01:18 AM   #3
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
By haywire I mean that the needle will rapidly move and twitch when there is a fast fluxuation in oil pressure. It works fine when the oil pressure remains the same...like at idle or at crusing at a constant speed.
The sender has one red wire coming from the back...and it did look a bit dirty/oxidized. The sender and gauge set-up was on the car when I bought it and has worked fine until today. I'll clean up that red wire and see what happens.
edit: speling
Old 10-26-2003, 07:45 AM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Check the ground connection on the sender. Make sure that the sender is placed on metal surface to ground itself.
tmat3 is offline   Reply With Quote
Old 10-26-2003, 01:21 PM   #5
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
Thats gotta be it... the lip on the end of the sender touches a metal hose line...there is alot of dirt and grime built up around it...Ill clean it up and hopefully that'll do it.
Old 10-26-2003, 02:39 PM   #6
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I don't know how you grounded it, but if you grounded your light and sender grounds together then that might be what is giving you the problem. I had the same thing happening to my EGT guage. Just ground the signal ground seperate. I grounded mine to the strut tower.
Brent
scoobyimprza is offline   Reply With Quote
Old 10-26-2003, 02:49 PM   #7
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
I'll have to do some investigating...all the wireing was done by the previous owner.
But I can tell you...the gauge light doesn't blink or cut out while the gauge needle is twitching. Im not sure if that would be a sign of the two being wired togather.
Old 10-27-2003, 06:14 PM   #8
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
Thanks for all your help guys...I cleaned the grounds and now it works great.
FS-AR- C/F Autometer Mech Oil Press Gauge gotboost02 Interior/Dressup/Audio & Security 0 01-29-2008 07:55 PM
autometer cf egt, oil press gauges, fog covers, etc.... 1quiksoob Private 'For Sale' Classifieds 1 03-24-2005 02:09 PM
Autometer Phantom Oil Press. Gauge - Electric drunkguy Private 'For Sale' Classifieds 1 09-30-2004 11:12 AM
Autometer Oil Press gauge and oil leak...? Jsunn Electrical & Lighting 2 09-11-2004 08:34 PM
electronic oil press gauge mbwrx20 Electrical & Lighting 5 04-21-2003 11:04 PM
