Old 09-23-2007, 12:38 AM   #301
poon warrior
Member#: 92520
UF Alum '09
After owning my car for two years, finally went to the drag strip for the first time! I was very, very nervous my first run as I didn't really know what to expect, I ended up over-staging and just giving it an 80% go. Only got in 2 more runs because it was bracket racing and not a test and tune, but got my best time of the night on my last run.
Was wondering if y'all could point me in the right direction about improving, I know experience is the big key, but it's obvious my 60' isn't great, and neither is my RT. I don't know the exact conditions, but I'm in central Florida, so very hot, and very humid as they were calling for rain, so the conditions were about as bad as they could be. My car is an '05 WRX, totally stock, I removed the spare tire and jack. I wanted to put up a competitive run, but not totally kill my clutch, as I drive it every day and it's obviously not going to be turned into a drag car . Any tips, pointers, whatever would be helpful!
Car 30 btw
poon warrior is offline   Reply With Quote
Old 09-23-2007, 09:36 PM   #302
Teh Legacy
Member#: 9853
to keep your mouth
shut.
(US)Jonathan Street - Andrewtech built motor, T3/T04S, supporting mods. No meth, nitrous, etc. All boost.
60' - 1.836
330' - 4.962
1/8 - 7.475
MPH - 95.67
1000' - 9.657
1/4 - 11.469
MPH - 126.16
As you can see from the 60' and 1/8th mile time, there's way more in the car, and a lot of that has to do with the stock suspension, 05 gearset, the REALLY crappy all-season tires on there right now, and me driving. I think it has an 11.2 if not a hair faster in it as it sets right now other than better tires.
Teh Legacy is offline   Reply With Quote
Old 09-24-2007, 11:59 PM   #303
shatteringstar
Member#: 149604
2006 Limited WRX
my first time at the track...
The Numbers:
Passes: 18
Solo Passes: 6
Best R/T: .330
Best 60': 1.958
Best MPH: 97.57
BEST PASS:
R/T: .573
60': 2.138
1/8: 9.166 @ 78.42
1/4: 14.205 @ 97.57
06 w/ SPT power pack and cobb stage 1
shatteringstar is offline   Reply With Quote
Old 09-27-2007, 02:07 AM   #304
snovvbrdr
Member#: 121063
2006 WRX Stg. II
Steel Gray
Default new england dragway
only got to make two passes lost a slip and this was a mis-shift back into second but not a horrible pass
60' - 1.858
330' - 5.726
1/8 - 8.998
MPH - 75.30
1000' - 11.753
1/4 - 14.192
MPH - 87.33
snovvbrdr is offline   Reply With Quote
Old 10-09-2007, 07:54 AM   #305
HDMLNIUM
Member#: 147769
2009 STI
07 STI Cosworth shortblock, cams, FMIC, protuned by XXtuning
60'...1.753
330'...4.923
1/8...7.432
mph...96.25
1000'..9.566
1/4....11.400
mph...122.20
HDMLNIUM is offline   Reply With Quote
Old 10-15-2007, 11:15 PM   #306
vtboost
Member#: 155580
2002 w/ 04 front end
& STi drivetrain
i'm car # 163 and all i've got is a short ram intake, cat-back, and a ecu road tune with enginuity and this was my first time at the track. my next step is to get rid of those 3 cats
vtboost is offline   Reply With Quote
Old 10-21-2007, 09:17 PM   #307
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
First time racing a manny tranny at the track (let alone an AWD). I was in the left lane.
[/IMG]
Mods:
Gabedude's Stage 1 Flash (R29)
Prodrive Axleback
K & N drop in filter
COBB short shifter w/Kartboy f&r bushings
flimflamman is offline   Reply With Quote
Old 10-25-2007, 11:26 AM   #308
s0n1c
Member#: 161318
2005 WRX
...My car is an '05 WRX, totally stock, I removed the spare tire and jack. I wanted to put up a competitive run, but not totally kill my clutch, as I drive it every day and it's obviously not going to be turned into a drag car . Any tips, pointers, whatever would be helpful!
You have the exact same car as I do, and my very first run was 15.7 with MAJOR bog down at the line. My best run that night was 14.97 (after 3 runs). The next week I got 8 runs, and I worked my time down to 14.6. I didn't bother removing my spare tire or jack, or even my subwoofer and amp. The weather on my passes was in the 50's and humidity was pretty low, so the cool evening air really helped. The humidity could be some of why you're running a little slower, but from what I've discovered, it's all about the launch. It's a delicate balance of slip/dump from the line. I bounced my revs a little bit between 3500 and 4500 while waiting for green. As far as RT goes, my friends who drag all the time suggested this: As soon as you see the 3rd amber, GO! By the time you actually start moving, the green will be there. My RT's are usually under .200 all the time, and you see my best run below has RT of .095, my best being 0.002 (in a 07 scion tC manual)
DIAL - 14.61
R/T - .095
60' - 2.102
330 - 6.043
1/8 - 9.355
MPH - 74.40
1000 - 12.190
1/4 - 14.607
MPH - 92.16
Considering the car is 100% stock, I'm not complaining about 14.6, since C&D says 14.4...
s0n1c is offline   Reply With Quote
Old 11-19-2007, 09:53 AM   #309
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
The attach feature is off
DJIMPREZA is offline   Reply With Quote
Old 11-23-2007, 11:07 AM   #310
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Old 11-26-2007, 06:59 PM   #311
burnin4
Member#: 59764
10 sec STi
10 sec Z06
forgot about this thread, here's my 10 sec pass
burnin4 is offline   Reply With Quote
Old 12-06-2007, 03:39 PM   #312
aznburn210
Member#: 84062
2005 WRX
CGM on Bronze Work's
heres mine i ran last night.. on the stock potenza re92's..
xpt stage 2 flash
invidia tbe
kartboy ss w/ bushings
sti uppipe
btw im #74...
aznburn210 is offline   Reply With Quote
Old 02-25-2008, 08:57 AM   #313
XTrooper
Member#: 172293
2006 Baja Sport
Brilliant Silver
Some of you fellas have some frigging FAST Subies!
I have a '06 Baja Sport and have owned three previous Subarus, but never thought of them as performance cars, more as versatile, reliable transportation.
I'm impressed!
Here's my go fast toy.
Good video, crappy run: 12.065 Run
Crappy video, good run: 11.478 Run
XTrooper is offline   Reply With Quote
Old 02-25-2008, 02:58 PM   #314
mjjantz
Member#: 82385
2007 07sti ptunestg2
pearl WHITe
I'm impressed!
good runs...what mods do you have to that vette...sounds good..is that tranny stock?
mjjantz is offline   Reply With Quote
Old 02-25-2008, 04:00 PM   #315
XTrooper
Member#: 172293
2006 Baja Sport
Brilliant Silver
The tranny is the only thing left in the drivetrain that is stock. Knock on wood, it's held up fine so far. I have a list of the major mods and some pics on my web site.
Old 02-25-2008, 06:27 PM   #316
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
I have an 07 STi with an invidia DP and a TOPSpeed stage 2 tune.
Running on 93 octane pump gas.
R/T - .4029
60' - 1.7961
330 - 5.4252
1/8 - 7.923
MPH - 80.20
and
R/T - .6819
60' - 1.8101
330 - 5.4202
1/8 - 7.9181
MPH - 77.84
reaction times are bad but end result was good. lmk thoughts improvemnts
noonagon is offline   Reply With Quote
Old 03-01-2008, 08:12 AM   #317
paolino
Member#: 148852
2007 WRX TR
Obsidian Black Pearl
Smile
[/IMG]
Mods:
Prodrive Axleback
That's awesome. I just went to the track here in Montgomery last night and the best time I pulled was also a 13.8. I was not expecting to break into the 13's with just the gabedude Stage 1 (r29) and an axle back. I was Pleasantly surprised.
paolino is offline   Reply With Quote
Old 03-06-2008, 08:51 PM   #318
IMWITHNOODLES
Member#: 172445
06 WRX TR
Ran my 06 TR last Friday at the track for the first time. It is stock except for a Cobb stage 1 map. I have no way to scan the slip but I ran a 13.95 @ 96.06, 8.87 1/8 with a 1.96 60' on my first pass. Ran a few more 13.9X runs and finally got my 60' down to a 1.88 on my last run but missed a gear so probably would have got the 13.8 that I wanted, but oh well. Stage 2 next week anyway so who cares. I just need more practice.
IMWITHNOODLES is offline   Reply With Quote
Old 03-07-2008, 10:00 AM   #319
paolino
Member#: 148852
2007 WRX TR
"Stage 2 next week anyway so who cares."
^^ LOL
Old 03-08-2008, 11:19 AM   #320
IMWITHNOODLES
Member#: 172445
06 WRX TR
^^ LOL
Get a life.
Old 03-15-2008, 11:38 AM   #321
makofoto
Member#: 25243
2006 Legacy Outback
What should a stock '08 STI do 1/8th mile in?
makofoto is offline   Reply With Quote
Old 03-30-2008, 04:00 PM   #322
SKUNK2.5
Member#: 172935
1998 RSTi 2.5
black gold
SKUNK2.5 is offline   Reply With Quote
Old 03-30-2008, 04:02 PM   #323
SKUNK2.5
Member#: 172935
1998 RSTi 2.5
black gold
Old 03-30-2008, 05:19 PM   #324
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Right lane...
def
dug-e-fresh is offline   Reply With Quote
Old 03-31-2008, 12:40 AM   #325
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
TDO4 steaming at around 20 psi, just AP and mbc no tune
Str8Gone is offline   Reply With Quote
Happy Birthday cassieswrx your inappropriate pics here car_cursed Rocky Mountains Impreza Club Forum -- RMIC 11 07-11-2008 02:23 AM
Add Your Timeslip Today! Nick Proven Power Bragging 29 07-20-2004 10:06 AM
get your Hatorade pics here! RidinLow Tri-State Area Forum 16 10-16-2002 11:24 PM
Post your leather pics here! Fernely Interior & Exterior Modification 12 10-30-2001 10:15 AM
