Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 10-26-2003, 06:01 AM   #1
FryRice
Member#: 38402
2004 WRX~vf34 SOLD
EVO MR
Default Where to get my tranmission oil change?
So my 04 is getting near 5000 miles........ anyone know where in SF to get it change? Which product to buy? need help
FryRice is offline   Reply With Quote
Old 10-26-2003, 07:04 AM   #2
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Try doing it yourself, its easier than even an oil change... Just unplug it and drain it, toss the plug back in and poor in the fluid!
Old 10-26-2003, 02:02 PM   #3
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
u can get it changed at any garage EASY, but isnt 5000 miles kinda early to change them? i usually change them every 15k miles.
as for the oil, i'd recommand Redline GL-5. anything u use, stay away from mobile 1.
ommmjido is offline   Reply With Quote
Old 10-26-2003, 05:52 PM   #4
blubaru
Member#: 13001
Motul Gear 300! I just switched from the Redline. Night and day difference.
blubaru is offline   Reply With Quote
Old 10-26-2003, 05:53 PM   #5
invisibleman
Member#: 8188
i personally use royal purple. There was a group meeting with seom tranny rebuilders and vendors and the subject came up and the responce was stay away from redline it eats the seals.
As for service contact sjwrx he'll prob do it for a small fee.
invisibleman is offline   Reply With Quote
Old 10-26-2003, 07:35 PM   #6
SJwrx
Member#: 14970
1997 GF8
multi
Hey John,
Thanks for telling people about me . Anyways, the tranny oil is SUPER DUPER WUPER easy...easier than engine oil. I can help you out whenever you need, or I could do it for you for the unbelievable price of McDonalds (plus tranny fluid).
Personally, I have only used Redline (with good results), but I will now be trying Motul at a later date.
Rich
SJwrx is offline   Reply With Quote
Old 10-26-2003, 07:36 PM   #7
FryRice
Member#: 38402
2004 WRX~vf34 SOLD
EVO MR
http://shop.store.yahoo.com/ltbmotorsport/gearoil.html which one and how many do i buy?
ummm as for oil change how much do i need?
Old 10-26-2003, 08:23 PM   #8
SJwrx
Member#: 14970
1997 GF8
multi
Gear 300 and 3.5qts is what you need.
Rich
Old 10-26-2003, 09:23 PM   #9
Daredevil
Member#: 33980
2003 WRX
MBP
wow
im at 18500 and haven't done that yet
blloops
doin that tomorrow
Daredevil is offline   Reply With Quote
Old 10-26-2003, 09:34 PM   #10
jskho
Member#: 11864
wow. how do you change the transmission oil.. i thought for the 5 speed manual, your transmission oil is the clutch fluid?? please tell me if im right or wrong. and pics on where the drain plug might be??
jskho is offline   Reply With Quote
Old 10-26-2003, 09:52 PM   #11
Daredevil
Member#: 33980
2003 WRX
MBP
ok so what am i gonna need
i have 5 speed manual
so what do i buy and how much
as far as the pic
the booklet you get with your car tells you, same section where it tells you how to change oil
Old 10-27-2003, 12:01 AM   #12
SJwrx
Member#: 14970
1997 GF8
multi
Subaru Recommends the service at 30K miles.
3.5qts of tranmission fluid are needed (manual transmission)
The drain bolt is the big on on the bottom of the transmission (22mm), and the fill-up neck is underneath (passanger side) intercooler (same place as where you check transmission fluid level)
Rich
Old 10-27-2003, 03:04 AM   #13
Daredevil
Member#: 33980
2003 WRX
MBP
any specific type of transmission fluid? i mean like how oil has 5w-30 and a million others
(this is my first car that i've actaually been doin everything my self on so im still learning, help out the noob thanks)
its funny, i've done up and down pipe install and im not sure about transmission fluid
Old 10-27-2003, 09:26 AM   #14
blubaru
Member#: 13001
Just back away from the car... before anyone gets hurt
Old 10-28-2003, 01:53 AM   #15
jskho
Member#: 11864
help out a noob here. i've change automatic tranny fluid but never a stick.
Old 10-28-2003, 09:06 AM   #16
Acadian
Member#: 31541
2016 WRX Limited
Dark Gray Metallic
I would also like to know the precise steps to change Transmission oil. Don't you have to do the Rear Diff?
What is the stock transmission oil in WRX's?
thanks.
Acadian is offline   Reply With Quote
Old 10-28-2003, 11:16 AM   #17
Egan
Member#: 12670
01 M Coupe,
05 Legacy GT, 05 Titan
Originally posted by Acadian
I would also like to know the precise steps to change Transmission oil...
thanks.
Here's the write-up I did when I changed mine. It is (as has been said) just as easy as changing the engine oil:
http://mikeegan.stormpages.com/GearOil.html
Egan is offline   Reply With Quote
Old 10-28-2003, 02:02 PM   #18
invisibleman
Member#: 8188
sjwrx don't give away your secrets man i think you can make some good change of these guys bring it over i'll supply the tranny fluid.
By the way i was talking to my buddy who sat in one of them discussions of tranny builders and they complained that redline ate the seals.
Old 10-29-2003, 12:27 AM   #19
jskho
Member#: 11864
so the transmission and the rear diff. use the same oil????
Old 10-29-2003, 12:46 AM   #20
SJwrx
Member#: 14970
1997 GF8
multi
No...the transmission has a open differential in the front, and WRX (and other models?) have LSD's in the back... so the fluid has to contour to the needs of the whirling metal.
Thanks for the info John (truthfully) , I'll let you know when the seals go bad on tranny #1... tranny #2 will be all Motul baby!
Rich
Just letting people know... if they need it done for them, I will be happy to help (always free) /do it for then (for lunch snackies)
Old 10-29-2003, 02:43 AM   #21
FryRice
Member#: 38402
2004 WRX~vf34 SOLD
EVO MR
you do it in a shop or you do it with normal car jacks...... how long does it take to change this?
Old 10-29-2003, 03:14 AM   #22
SJwrx
Member#: 14970
1997 GF8
multi
I do my own with a jack and a few support stands, aswell as others.
Draining is the thing that takes the longest... you can let it trickle overnight (like I did last time), or just for 30mins (most of everything is out by then) for the transmission. Now while thats draining the rear differential is the next thing. That takes about 15-30 mins (with draintime, cleaning, filling, etc.)
Leave 1.5-2 hoursfor everything and you'll be ok.
Rich
Additional Recommended Products:
a can of carb cleaner
blue threadlock (neccessity)
rubber gloves
shower afterwards (MANDATORY)
Old 10-29-2003, 05:30 AM   #23
jskho
Member#: 11864
hmm cuz the website you mention is is 75w90 gl-5 gear oil. that is the same stuff i found that is recommend for the rear different. i got a bottle of 75w90 gl-5 mobil 1 synthetic for the rear diff. how are they different.. im assuming the transmission fluid is the same for both the auto and manual??
Old 10-29-2003, 05:37 AM   #24
FryRice
Member#: 38402
2004 WRX~vf34 SOLD
EVO MR
So you need to change both tranny and rear diff.???!?!? or they both the same
Old 10-29-2003, 08:54 AM   #25
Acadian
Member#: 31541
2016 WRX Limited
Dark Gray Metallic
Rich
if you do it for me...I might just buy you lunch AND brews!
Where to get my clutch changed? mls1 Texas Impreza Club Forum -- TXIC 25 07-16-2009 09:34 AM
so i go to get my tranny oil changed... again... God North West Impreza Club Forum -- NWIC 22 07-17-2008 03:08 PM
Recommendations: Where to get my oil and trans. fluid changed? SR-71WRX Southern California Impreza Club Forum -- SCIC 5 01-27-2005 12:51 PM
So while I was getting my free oil change.... plunk10 Off-Topic 3 10-28-2004 03:29 PM
When should I get my first oil change? wrexsta Transmission (AT/MT) & Driveline 10 02-28-2003 11:00 AM
