Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 10-26-2003, 12:59 PM   #1
Wheels
Member#: 5410
2013 BMW X1+335XI
Blue and Black
Default Taking my Subaru off the road for 6 month!
Should I do anything else besides disconect the battery?
Taking it off so I don't need to insure it. We only realy use one car and with my insurance going up 300% we might as well remove one till my two(my-fault claims) come off in April. Then either put it back on the road or sell it with even lower than average miles on it.
Wheels is offline   Reply With Quote
Old 10-26-2003, 07:04 PM   #2
X1_SRT
Member#: 31323
02 RS
midnight
i did the same thing with my car when i was sick, and out of work. but the best thing to do is to get storage insurance. i think mine was $40ish for 2 months. this way its still protected if something should happen to it (i.e. tree falls on it, garage burns down...)
-PJ
X1_SRT is offline   Reply With Quote
Old 10-26-2003, 07:08 PM   #3
2wheelsx2
Member#: 44045
2004 Impreza WRX
Fuel stabilizer, change the oil and filter. Lube everything (hinges, etc.) Thoroughly clean, dry and wax the car. Put tires up to max. pressure, or better yet, put the car up on blocks and store the tires on their sides if you can covered up away from ozone or UV.
2wheelsx2 is offline   Reply With Quote
Old 10-26-2003, 07:09 PM   #4
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
6 months, no drivin?
-Jack up car, put blocks (or jack stands) under Frame, and remove wheels (saves your shocks/struts)
-Get a "Fogging spray" (auto zone) and Fog the engine like it tells you on the side of the can
-Put some fuel stabilizer in the tank (preserves fuel)
-Remove battery from car, store in a cool, dry place, and charge it about once a month
-Try to get you car inside, but if not possibe invest in a GOOD exterior cover, or at the very least, some blankets and a Waterproof tarp.
Best to drain fuel tank but if not fill to top to reduce air in tank. Air has water which condences as air cools this is heavier than gas and goes to bottom of tank. Layer of gas over water prevents evaporation. Drain tank or fill it to very top.
that should just about do it...I've heard people removing the spark plugs, but that's just hearsay...not sure myself.
If you don't want to go through all that, make sure the gas tank is full to the very top, remove battery, and then plug in the battery once a month and start her up...
happy winter
//marcus
marcus12 is offline   Reply With Quote
Old 10-26-2003, 09:20 PM   #5
nosoupforyou
Member#: 45621
04 STI
Black/Silver
How about in a heated garage environment? I'm going to be parking the STI for the winter, however it will be in heated storage. What would you all recommended doing for that? I've never parked a car for a season, so I'm unsure.
nosoupforyou is offline   Reply With Quote
Old 10-26-2003, 09:31 PM   #6
Snowphun
Member#: 1800
WRX /Cooper S/Miata
awd/fwd/rwd
Temperature has little to do with any of those precautions. Fuel will go off over time, tires may develop flat spots. Rodents and wildlife may be more of an issue in winter.
FWIW, I leave a car covered in my driveway for 5+ months every winter (so far it's been a 944 for 3 winters, a Miata for 2), with nothing more than a tarp. I drive it around the block a few times over the winter, but otherwise have not had issues.
Paul
Snowphun is offline   Reply With Quote
Old 10-26-2003, 09:49 PM   #7
doppelganger
Member#: 23007
These cars are JUST Subaru's.
Am I missing something?
I know people who collect some seriously valuable cars. One single car is easily worth MORE than 10 new STi's COMBINED. They do nothing to prep the car for this. Just start it up once every 5-6 weeks or so.
Up on blocks? Total overkill.
doppelganger is offline   Reply With Quote
Old 10-26-2003, 09:55 PM   #8
nosoupforyou
Member#: 45621
04 STI
Black/Silver
The only reason I'm parking my STI for the winter, is I figure it will run me 1,400 or so to put winter wheels/tires on it, and I can get a great dependable car from a friend of mine for that price.
So, I figured it just made sense to park the STI, keep the winter wear and tear off of it seeing how buying my buddies car would cost the same as putting wheels/tires for the winter.
Old 10-26-2003, 10:52 PM   #9
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Yes the car might cost the same as the tires, but what about all the other stuff. Maintence on the other car, insurance/registration for it, storage costs for it over the summer, storage costs for the STi over the winter...I'm doubting it will be cheaper to have a second car.
lotusTT is offline   Reply With Quote
Old 10-26-2003, 11:13 PM   #10
nosoupforyou
Member#: 45621
04 STI
Black/Silver
Well, the owner of the car is a mechanic, mechanically the car is perfect, the car only needs to run 4 or so months out of the year, heated storage for the STI during the winter is free (friend owns a mall, and stores classic cars in a room underneath it) Storage for the winter car I would buy during the summer is also free. Insurance will cost me nearly nothing. Plus, should I ever need the car for something rather than the winter, I'll have it, rather than having a set of wheels.
Its not this easy for everyone I'm sure, for me its not bad. I figure the little amount I spend on insurance will surely be repaid in keeping the milage, and wear and tear of winter off the car when I decide to sell it or trade it.
Old 10-27-2003, 02:38 AM   #11
Wheels
Member#: 5410
2013 BMW X1+335XI
Blue and Black
Car will be stored in a none heated garage. The wheels will be removed. The tank will be full.
now to decide if I should sell it or store it
Old 10-27-2003, 07:55 AM   #12
Siper2
Member#: 1134
2007 BMW 328xi wagon
Cool
Wheels,
Just give me the car for the winter. I'll take care of it for you.
-S2-
(turbo envy)
Siper2 is offline   Reply With Quote
Old 10-27-2003, 08:05 AM   #13
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
That's as far as I'd take things personally, along with making sure the fluids are all topped off (gas, etc..) likes folks have suggested.
When I was ready to get the car back on the road I'd probably change the oil.
Insurance is important though, especially if the car has a lien on it. Most lenders require a certain amount of insurance.
Paul G.
paultg is offline   Reply With Quote
Old 10-27-2003, 08:09 AM   #14
Jack ffr1846
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
Wheels, if your plan is to sell it after this 6 month period, you may want to rethink. Depreciation is eating away at the value of the car, even if mileage depreciation is not. If your plan is to sell it, do it now. Your cost to store it (it will cost you something) plus whatever insurance and (biggest cost) depreciation will make it very unworthwhile in the spring, when you put it up for sale. Sell it now and pay off some loans or buy US Savings bonds or something. Figure on losing about $300 a month (average) for every month you store the car, just on time depreciation.
then, of course....you'll have money to buy my old S4 wheels to go on your A6
jack
Jack ffr1846 is offline   Reply With Quote
If your states starts doing inspections.. can they just take your car off the road?? tdc17 General Community 28 12-21-2009 12:04 PM
My WRX has been off the road for a year, what kind of work should I have done? Pika's WRX General Community 4 05-14-2009 05:26 PM
Suby's off the road for a little Suby1128 South East Region Forum 1 03-26-2003 07:50 PM
tekkgod ran my mamma off the road!! metoo Texas Impreza Club Forum -- TXIC 17 04-15-2002 08:53 PM
Message Board Statistics All times are GMT -4. The time now is 02:05 AM.
