Welcome to the North American Subaru Impreza Owners Club Tuesday July 22, 2014
Old 01-14-2001, 06:57 PM   #1
J-Spec
Member#: 3277
Question Q: Should a Factory Turbo have Factory Guages? (Rex Question)
Reason I ask this is because, if I get the WRX and buy aftermarket guages would that screw up my warranty? I mean if an aftermarket boost gauges tells me I'm running 16 PSI when I'm running 22, I'm screwed.... But the way I see it is if it's a FACTORY installed Turbo, then I should get factory gauges so I can blame it on them and still be in warrenty if the gauges fail.... Is my thinking skewed or what?
J-Spec is offline
Old 01-14-2001, 07:28 PM   #2
T-WRX
Member#: 2468
08 RS4
05 STi
Post
That is why the dealers will make a killing with the dealer installed gauge pack. How could you live without it?
T-WRX is offline
Old 01-14-2001, 08:18 PM   #3
AKGC8
Member#: 1305
2000 Impreza
Post
The only reason you'd need a boost guage is if you were upping the boost right. In that case, I think your waranty would have been void long before the aftermarket boost guage failed. A factory warranted guage wouldn't make any difference. Upping the boost would basically void the warranty for the entire powertrain.
AKGC8 is offline
Old 01-14-2001, 08:22 PM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
Yeah, if you don't mess with the Turbo and the gauge is wrong, It's not your fault. If you do play with the boost, you are at your own risk
Eric
Eric SS is offline
Old 01-14-2001, 08:35 PM   #5
J-Spec
Member#: 3277
Post
I was under the assumption that any fuel/air mods to a turbo'ed car would change the gauges... like headers/exhaust/gutting the cats... whatever....
J-Spec is offline
Old 01-15-2001, 07:40 AM   #6
stewartg2000
Member#: 1570
2009 Impreza WRX
WR Blue
Post
a/f mods will give more boost, and a crappy factory guage would read wrong. but those mods would not cause the turbo to fail, and there is nothing wrong with adding a aftermarket guage as far as warranty is concerned.
stewartg2000 is offline
HTML code is On
Swapped factory turbo for factory turbo (by dealer) now I'm overheating digitalseance Factory 2.5L Turbo Powertrain 13 06-20-2007 11:26 PM
Should I get Turbo-Timer and Turbo Guage? raptor Factory 2.0L Turbo Powertrain 7 12-04-2003 04:33 PM
what should stock boost be(Mpa) on factory guage? ezatnova Factory 2.0L Turbo Powertrain 27 02-04-2002 10:01 AM
