Old 10-26-2003, 09:31 PM   #1
Peter.Lombardi
Member#: 46100
2004 TS 2.5 Wagon
Talking New guy w/ a few questions about his new '04 TS Wagon...
Hey there, well my name is Peter Lombardi and I'm a 22 year old Photo student currently residing in Santa Barbara, CA. And my newly acquired '04 TS Wagon is my first import.
I've mainly driven older cars and Jeeps up until now, my other car is a 1949 Oldsmobile kustom that I'm slowly working on. I got the Subaru bug when my little brother bought and started to modify his '02 RS. I recently moved to Santa Barbara, CA from Washington state, and I like to drive back to Washington every few months to visit family and friends. So I was in need of a new car, other than my '00 Jeep Cherokee. As I'm sure some of you know, gas prices are scary in California, and I was spending between 70-100 bucks a week on gas. Not a pretty sight for a very poor college student, so thankfully my parents jumped in and we worked out a deal for me to get this beautiful new car.
I hope that was enough of an intro, not sure whether you need to know more or not.
OK, so here are the questions I promised,
Springs, I have my brother's older RS springs, how much of a drop would I receive w/ these? I'm not sure about the '02 models, but with the '04 models there's a 1" to a 1 1/2" difference between the RS and the TS. Anybody have an idea?
Also, any difficulty in swapping out his old wheels and tires? It seems he had an upgraded set of them, as they are 17" wheels and the tires are about 3 1/2" tall, making them a total of about 24" tall, they are also wider than the stock tires on the TS. There’s not much wear on them and they look like new.
Almost done, please hang in here w/ me, and remember I'm a newby to these things.
Alright, how difficult is it to swap out the stock springs?! Will I need a spring compressor?! Should I just take it to somebody to swap them out, as I'm unfamiliar and uncertain about these new fangled modern automobiles?!
Also, what are the actual differences in suspension between my TS and an RS of the same year? Anything I should keep my eyes out for?
Thanks a lot people! Sorry if I didn't do a good enough intro,
-peter
http://www.rodnkustom.com
Peter.Lombardi is offline   Reply With Quote
Old 10-27-2003, 07:24 PM   #2
Malik
Member#: 29272
2002 WRX Wagon
Welcome.
Since the really smart people aren't chiming in, I'll offer up my two cents. I'd suggest an exhaustive search of the wheel and tire forum as well as the suspension forum. Somebody has probably done what you want to do, or didn't do it because of a problem. Either way, you will probably find enough information to get some of the basic issues worked out.
For what it's worth, 17 inch wheels will probably fit the TS (the tire rack has 205/45/17 listed as an option. I can't imagine the springs dropping the car enough to cause any problems, but you never know!
Cheers and enjoy your TS.
Malik
Malik is offline   Reply With Quote
Old 10-27-2003, 07:48 PM   #3
Peter.Lombardi
Member#: 46100
2004 TS 2.5 Wagon
Thanks for the reply man, I'll get over to cruising that wheel section of the board.
I don't get to pick up the car until tonight, I guess I'll try trial and error w/ the wheels.
-peter
Old 10-27-2003, 09:18 PM   #4
mr_yellow
Member#: 39983
2003 WRX Wagon
There seems to be an anti-newbie thing going on...
Regarding your suspension question:
Take a look on scoobymod.com If you take a look in the forums in the 02-04 suspension section, there is a thread with step by step instructions on replacing the spring/shocks with an STi set. I would assume the proceedure is exactly the same if you want to swap your shocks with something else.
mr_yellow is offline   Reply With Quote
Old 10-27-2003, 10:26 PM   #5
blueimpreza25rs
Member#: 21821
2008 Cadillac CTS4
Black Cherry
well im a noob myself........but i dont think you can swap the springs between 02 and 04 (at least the rear ones) you would have to take the rear upper strut mounts and replace them with 2002-2003 units.
if you want lowering springs you would have to buy them for 04 specifacly (sp) whoa i cant spell!
blueimpreza25rs is offline   Reply With Quote
Old 10-28-2003, 02:46 AM   #6
Peter.Lombardi
Member#: 46100
2004 TS 2.5 Wagon
Thanks guys, any sporty lowering springs you can recommend?!
-peter
Old 10-28-2003, 08:25 AM   #7
QfactorRS
Member#: 30495
eiback pro-kit are known to be performant and still provide a level of comfort.
H&R are stiffer, thus less confortable.
Tein S springs have good reviews too.
you should be able to fit a 215/45/17 in there.
Q
QfactorRS is offline   Reply With Quote
Old 10-28-2003, 09:29 AM   #8
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Well, the Prodrive springs were designed to work with the OEM WRX strut damping rates, so they should match your struts *fairly* well. Yes, I do believe the rear springs are not compatible between MY02-03 and MY04, sorry.
What size tires are on your brother's 17"s? It should be printed right on the sidewall of the tire.
FWIW, I have Eibach Pro Kit springs on my wagon and love them. Another "bang for the buck" initial mod is to find someone with a used stock WRX sedan rear sway bar and install that.
Welcome to the club and good luck.
- Trent
peepshow is offline   Reply With Quote
Old 10-28-2003, 11:27 AM   #9
Peter.Lombardi
Member#: 46100
2004 TS 2.5 Wagon
Well it looks like Eibach is the way to go, I'll go price it out today.
But it looks like I was wrong about the wheels, their only 16", I was trying to read the measurement w/o any available light source,
The tire size is P205/55R16. Thanks for the tire size Q, and peep, that's a bummer, but I figured something would be wrong w/ the easy situation.
But you know, anything is better than the skinny stocker 15's on my TS now.
Thanks again guys,
-peter
Old 10-28-2003, 02:54 PM   #10
Peter.Lombardi
Member#: 46100
2004 TS 2.5 Wagon
Also, what about alignment? Does anybody make a camber kit? The Eibach is in development, and won't be out until who know's when.
I also have a question about coilovers, who makes them for my ride? And what's good.
Should I post this in the suspension section? I think I'll do that as well....
-peter
Old 10-28-2003, 05:51 PM   #11
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Just one thing I would suggest: since you're getting a brand new car, I would drive it unmodded for 6-12k miles (6 months or a year) to "shake it down" and make sure nothing is wrong with it. once you start modding, you start running into the possibility of being denied coverage under warranty for systems related/affected by whatever you modded. Another advantage is that you'll get a good feel for what the unmodded car drives like, so you'll be able to feel better how each mod affects handling once you do it.
(If warranty isn't an issue for you, ignore my first argument).
Old 10-28-2003, 06:03 PM   #12
outback_97
Member#: 30874
0897 OUTBACKS
and 2003 TS wagon
Congrats on the TS, you'll enjoy it. We put WRX wheels on our '03, and this improved the handling and looks over stock. BUT... the rolling circumference is a few inches larger, so if you go this route you're changing the gearing and speedometer / odometer slightly... only about 2%, but it is some difference.
TS 15" = 195/60/15, WRX 16" = 205/55/16, IIRC. A 50 series tire on the WRX wheel would be closer to TS stock.
Steve
outback_97 is offline   Reply With Quote
New here with a few questions BC-SE Newbies & FAQs 5 10-29-2007 08:41 PM
Possible New Owner with a few questions. MovingFromHonda Newbies & FAQs 29 04-16-2007 11:20 PM
Hi guys... Just a few questions about the car buying... JTAM128 Newbies & FAQs 6 01-11-2004 02:18 AM
New guy with a few questions. M///Scooby Newbies & FAQs 14 11-22-2002 10:37 AM
Im new here with a few questions. LuvMyAWD Newbies & FAQs 3 08-20-2002 12:35 AM
Message Board Statistics All times are GMT -4. The time now is 02:52 PM.
