Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 10-27-2003, 12:36 AM   #1
303
Member#: 21323
2003 Impreza WRX
Exclamation hids causing highbeam indicator to be on?
ever since i installed my hids in my sti projectors(03 wrx) i have had the high beam indicator flickering on and off randomly. sometimes it also lights but dimly, and then for no apparent reason it will go away and come back. everything seems to be working properly, its just getting annoying seeing that blue indicator in the dash. does anyone know what may be causing this?
303 is offline   Reply With Quote
Old 10-27-2003, 07:41 AM   #2
Damien
Member#: 25234
2016 DGM WRX Premium
287 Igg-Points just `cuz
Loose Wire, Loose Connection/Splice, Poor Ground?
-Damien
Damien is offline   Reply With Quote
Old 10-27-2003, 04:13 PM   #3
303
Member#: 21323
2003 Impreza WRX
yeah thats kinda what i figured. ill go check it out and let you know what happens. thanks
Old 10-27-2003, 05:38 PM   #4
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
-Damien
I second this.
JewPac42 is offline   Reply With Quote
Old 10-27-2003, 07:31 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Have you disabled your DRLs by disconnecting the main module by the glovebox, and have you done the fog light mod? Both of these can help solve post-HID install problems like you are having.
How are your HIDs wired? If the negative side of the ballasts are connected to the OEM switched grounds this may cause problems also. Try moving them to a direct chassis or battery ground and leave the low beam switched grounds open.
OT: Pick a gun for me to carry in public, cause it's about to be ON! -=C=- Off-Topic 401 05-12-2010 08:08 PM
Could intake elbow/snorkus delete cause rain water to be sucked in to airbox? lotarg General Community 11 05-05-2010 11:10 PM
Turbo Timer Causing Car Alarm to be set off WhiteTurbo13 Car Audio, Video & Security 2 11-07-2007 04:59 PM
What causes the CEL to come on relative to temp? 83Rabbit Normally Aspirated Powertrain 5 11-05-2006 01:09 AM
What would cause Steering Wheel to be pretty stiff to Turn? ProdriveRex Brakes, Steering & Suspension 13 07-21-2006 02:33 AM
