Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 10-27-2003, 12:13 AM   #1
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
98 Unicorn EVO Killer
Default Puttin a MY99 Motor into a MY98
Quick question, if i wanted to change a 2.5rs motor from a MY99 rs into a MY98RS would i need to change the computer/entire harness over ?............ thanks guys
PumpsGOTAWD is offline   Reply With Quote
Old 10-27-2003, 01:19 AM   #2
Snagtastic
Member#: 43809
Yep, the whole deal.
Snagtastic is offline   Reply With Quote
Old 10-27-2003, 08:36 AM   #3
czo79
Member#: 6752
I'm a little unsure of the engine dates for 2.5rs...
are you asking if you can put a phase II SOHC in place of the phase I DOHC? I would say yes. I have an phase II in my 97 legacy. I'm running phase I wiring ECU, etc....only problem is the EGR valve )or lack therof throwing a CEL every couple weeks or so.
Micum
czo79 is offline   Reply With Quote
Old 04-16-2004, 01:20 AM   #4
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
BUMP, i need more input.. thx guys.... quick over view its a 98RS with the DOHC i want to put a 99RS SOHC motor in it can i use the 98RS wireing and harness and ecu.. thanks...
paul
Old 04-16-2004, 01:50 AM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
im almost certain u can aside from like 2 sensors
Old 04-22-2004, 05:32 PM   #6
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
anybody else have an exact idea ?
scubydrew is offline   Reply With Quote
Old 04-22-2004, 06:28 PM   #7
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
As Miccum stated I know that the EGR sensor will be an issue. Phase II motors do/did not have an EGR.
Compressed is offline   Reply With Quote
Old 04-22-2004, 09:22 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Is just changing the bottom end and option for you? It would be a bit more work to do, but not more than an extra 5-6 hours onto the swap, and you would save at least that much time in wiring.
The other thing to remember is the '99's were the MAF year that has issues with intakes and whatnot. If you go to all that trouble, you might want to consider an '00 or '01 with a MAP...
Old 04-23-2004, 12:38 PM   #9
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
Matt, i sold the 98RS motor out of the car, so i have none of it left, and i have a 99RS motor that was from my old RS that i crashed i have the whole thing.... and what is the EGR valves signifigance ... is it important, keep in mind that the 99rs motor will only be in the car for a month at the max b4 it is replaced by a swap....
Old 04-23-2004, 02:18 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
got it. I didn't know the story. It sounds like Micum has made this work. I would shoot him an PM...
MY99 EJ25 into MY97 EJ22..idle control help Murray Subaru Conversions 8 11-09-2010 07:47 PM
Turbo motor into Porsche 914. Which motor to use and where to get it? pktzygt Subaru Conversions 18 11-08-2008 04:52 PM
06 STi Motor into and 04 STi, what problems will I run into? stillillmatic7 General Community 1 05-01-2007 06:52 PM
my99 ganzflow CAI on my98? ShortyDCT Normally Aspirated Powertrain 3 10-30-2001 01:14 AM
MY99+ tranny on a MY98? Strepto Normally Aspirated Powertrain 5 02-14-2001 10:06 AM
