Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 10-27-2003, 12:18 AM   #1
Sub_Speed_Guy
Member#: 25007
2004 WRX
OEM +
Default How did u make your intake?
I need idea's on why my homemade intake is messin my car up. I have the hotwire style MAFS. I mated a 3in PVC 90degree elbow to it and slapped a K&N on the end and she runs, but chugs and sputters a bit after 3500 rpms. Any ideas?
Sub_Speed_Guy is offline   Reply With Quote
Old 10-27-2003, 11:06 AM   #2
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Re: How did u make your intake?
A picture is worth a thousand words. On another note, my finger points to the gasket between your MAF sensor and the air filter itself. For some reason, I think either that connection or the connection of your intake piping to your throttle body isn't sealed properly. Are your vacuum lines tightened enough?
I'm a novice here so maybe some of the old schooler owners can help.
Kevin Thomas is offline   Reply With Quote
Old 10-27-2003, 04:44 PM   #3
Sub_Speed_Guy
Member#: 25007
2004 WRX
OEM +
Thumbs up Re: How did u make your intake?
I'll check the gasket. I wish I could post pics, but have no digital camera.
Old 10-29-2003, 10:30 PM   #4
AdamNDJ
Member#: 39830
1984 GL Turbo
Lightning Silver
Do you have any joints in the PVC? Like where a straight piece goes into an elbow? These can leak unless you glue them up pretty good. ABS (the black stuff) is actually a little better for intakes and such, as it can handle higher temps that are common under the hood than PVC can. Lotsa luck.
AdamNDJ is offline   Reply With Quote
Old 10-30-2003, 12:00 AM   #5
Sub_Speed_Guy
Member#: 25007
2004 WRX
OEM +
I am getting indications from people that the sharp angle at which I have made to the MAFS, is causeing the ir to be "turbulent" and there for screwing with my readings.
Old 10-30-2003, 08:04 PM   #6
Kevin Thomas
Member#: 110
1989 1989 XT6
Default Hey
Does the angle that you have your intake going into the MAF look similar to this?
I found another pic with a guy using a 'smoother' bend at the same spot.
This guy (2nd pic) eventually changed his intake setup to look like this.
Sorry for all the big pics but it helps with understanding. It's turbocharged but maybe you can adapt what you see to your setup. I asked the guy how he hooked up his air filter tubing to the Maf sensor and here is the reply I got: "The tubing is all a combination of Lowes (hardware store) and schucks. Same goes for the piece that connects the air filter to the MAF, or so the previous owner MikeW told me, he's the one that did the original CAI setup, i just reused that piece." His username is 'SubaruTex' at the USMB site.
The reason I posted the last pic and the posters response was because usually, when a cold air intake filter (like the K&N unit you see) is used, there is a type of funnel inside of it that helps with straightening the turbulent air before it goes through the MAF. I thought that might help solve your problem somewhat.
Hope this helps!
Old 10-30-2003, 11:20 PM   #7
Sub_Speed_Guy
Member#: 25007
2004 WRX
OEM +
Mine is most similar to the first pic? What kind of thing can I put into the pipe to smooth out the air flow?
Old 10-30-2003, 11:23 PM   #8
Sub_Speed_Guy
Member#: 25007
2004 WRX
OEM +
Also, can anyone make me an intake. I would be willing to pay for shiping and all the good stuff, cause my intake just insant working out.
Old 11-01-2003, 12:34 PM   #9
aRSe
Member#: 6112
too many
to list
Default mine
The top pict (thanks Kevin) is my old setup, ran it for thousands of miles with no problems.
I'd look else where for your problem.
you can see my new system on the left here
Have you changed the fuel filter lately, does the A/F meter go lean when it chuggs?
aRSe is offline   Reply With Quote
What color did you paint your intake manifold? 2slofouru Interior & Exterior Modification 82 05-30-2011 02:43 AM
How did you find your therapist/counselor/person to help you? TRH_legacy2k Off-Topic 24 06-25-2008 07:19 PM
how did you get your hands on your first car? Matt K Off-Topic 38 01-30-2006 02:39 AM
where did you work/how did you make money in college BigWrecKs Off-Topic 38 01-12-2006 04:03 PM
how did you make out? WRBlue5spd New England Impreza Club Forum -- NESIC 6 03-25-2003 10:37 AM
