Old 10-27-2003, 12:50 AM   #1
collegedropout
Member#: 42569
adds to the douchery
level round' here...
Question Driving Light Mounts
I was wondering if anyone knows where to get a bracket to mount driving lights in front of the bumper or bottom grill? Im looking for functionality on the backroads at night.
And/Or could ppl post pics of different driving light setup?
collegedropout is offline   Reply With Quote
Old 10-27-2003, 11:23 AM   #2
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
If by "driving lights" you mean the pencil beam pattern lights, iirc, PIAA makes a compact (and expensive) projector pencil beams.
But if you meant lighting up the sides of backroads better, then perhaps a god foglight would work for you. Projector fogs would make a good backroad aux lighting, if you're not concerned about improving the long range lighting. They're also compact, which makes the issue of mounting easier. The heavier reflectors would take more space and require a more rigid mounting setup compared to the projector fogs imho.
Hella Optilux 1182 Projectors are small enough to be mounted inside the grille side pieces, that is if you're willing to drill the grille side pieces. (You can always get a replica off eBay if you're not willing to modify the oem pieces)
http://forums.nasioc.com/forums/show...hreadid=310838
Here is the lighting (the left unit was a little tilted when I took the picture):
http://forums.nasioc.com/forums/show...hreadid=426555
satrya is offline   Reply With Quote
Old 10-27-2003, 11:14 PM   #3
KKL
Member#: 10220
2010 STI
World Rally Blue Pearl
Default How's this?
I use this setup for TSD rally. The light bar consists of about $40 in parts from Home Depot. I've got it set up so I can put on or pull off the whole assembly in about 10 minutes. As a side note, the lights do not appear to impede cooling at all.
Front View
Above View
Behind View
Side View
Square Tube Mounts
Close Up of Left Tube (Bumper skin has a ridge that we removed with a Dremel to allow the tubes to sit flush)
Existing Holes in Bumper (You will need needle nose pliers to get a nut underneath the bumper skin, it'll be obvious when you check your bumper)
Edited: More pictures
KKL is offline   Reply With Quote
Old 10-28-2003, 02:42 AM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
are there instructions for that light bar?
subiekid is offline   Reply With Quote
Old 10-28-2003, 10:55 AM   #5
KKL
Member#: 10220
2010 STI
Nope, it was just something that my navigator and I cobbled together one day. The light bar happens to be on the car right now since I worked a TSD rally on the weekend. I can take some close up pictures of the various pieces and how it's mounted when I pull it off later today and post those if you want to build your own.
The nice thing about this solution is that you only need to do a slight modification to your bumper and you can put your car back to stock very easily.
Old 10-28-2003, 11:30 AM   #6
XMEDIC
Member#: 16171
2002 WRX Wagon
Race car blue/Gold wheels
KKL,
How is the vibration on the lights? I'm looking into fabricating a light bar soon for mounting a pair of FF1000's (deer spotters) in front of my grill. I drive a lot of gravel roads and don't want to have the shakes from the light show...
Jefe'
XMEDIC is offline   Reply With Quote
Old 10-28-2003, 12:06 PM   #7
collegedropout
Member#: 42569
Thats more of what i need KKL, it would be much appericiated if you could include some more in depth photos of the bar and mounts.
Old 10-28-2003, 12:29 PM   #8
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
I will be going with these guys:
http://www.rallyinnovations.com/main.htm
RR
Rapid_Roo is offline   Reply With Quote
Old 10-28-2003, 01:00 PM   #9
KKL
Member#: 10220
2010 STI
Originally posted by XMEDIC
KKL,
Jefe'
I originally had two lights on the bar and they hardly vibrated at all. However, when I went to 4 lights (two weren't enough for night rallying) things changed a bit. The outside lights are very solid, but the inside lights vibrate a bit on really bad washboard. I think it's due to the aluminum L-bar flexing from the extra lights being close to the center of the bar. The vibration can be cured by either replacing the L-bar with square tubing or extra bracing.
Old 10-29-2003, 10:48 AM   #10
KKL
Member#: 10220
2010 STI
I added more pictures to my original post above.
I used a 1 1/4" x 1 1/4" aluminum L-bar, a 1" x 1" square aluminum tube, and a 1" galvanized flat steel bar. Both were readily available at Home Depot and pretty inexpensive. Of course you'll need assorted nults, bolts, and washers as well.
First step is to pop out the grill, press on the plastic clips with a screwdriver to release it. There are four along the top and one on each side about half way down. Then pop out the two outermost bumper skin retainers, voila!, two mounting holes.
We shaved a bit of plastic off the bumper skin to allow the mounting tubes to sit flush. It's that ridge that runs long in front of the bumper skin retainers. We used a Dremel tool and it was quick and easy to do.
Mount a 2-3 inch piece of square tube to each bumper hole. The length will depend on the size of your lights. Bigger lights mean longer tubes so the lights will clear your hood. However, longer tubes mean more vibration, so it's a trade off.
Getting the nuts underneath the top of the bumper is a bit of a challenge, but it can be done with a pair of needle nose pliers and a lot of patience. Just try not to drop them, I think I've got two rattling around inside my bumper somewhere. You'll need to temporarily remove the horn from the driver's side to be able to get the nut in on that side. Stubby wrenches will also help here, otherwise you may dent your radiator (like my navigator did in the pictures).
Measure and cut the L-bar to fit. The length will depend on how many lights you want to use.
Next mount the lights to the L-bar. You won't have enough room to mount the lights if you install the L-bar.
Cut and bend two pieces of 1" the flat metal bar to bolt the L-bar to the top radiator mounting bolts. I only used two and I think it's why I get some vibration. There's a convenient bolt on the air intake which could be used for a third mounting pount.
It took us about three hours to fabricate this and most of that was working out the mounting points and how to piece it together. You should be able to slap this together in about an hour.
Old 10-30-2003, 12:05 PM   #11
stivancouver
Member#: 39379
2004 WRX STI
Default STI setup with driving light pics?
Does anyone have a picture of a 2004 STI with driving lamps attached externally?
Cheers.
stivancouver is offline   Reply With Quote
Old 10-31-2003, 03:52 PM   #12
brunetmj
Member#: 8023
2004 2.5 RS
Just thought I would throw this in as a smaller alternative.
I cut holes in an old grill and mounted some PIAA micro lamps.
brunetmj is offline   Reply With Quote
Old 10-31-2003, 10:34 PM   #13
glepko
Member#: 19651
Thanks for the picture. I've been wondering how this looks, as that's where driving lamps belong! There's all kinds of room UNDER the bumper, where the fog lights belong.
glepko is offline   Reply With Quote
Old 11-20-2003, 02:14 PM   #14
Nambo
Member#: 27734
1999 2.5 RS
Anyone know where to find the Rally Innovations rally light bar?
I've got a blue 99' 2.5 RS and have been considering setting it up with that.
Any idea how much the bar costs?
Thanks,
Nambo
Nambo is offline   Reply With Quote
Old 01-21-2004, 02:32 AM   #15
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
i know this post is old, but, brunetmj, were those PIAAs pretty bright? did they shine further than the low beam lights?
i'm looking for somedriving lights to act as high beams since i have an HID kit. thanks.
AK_2002_WRX is offline   Reply With Quote
Old 01-21-2004, 10:59 AM   #16
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
like i said in the other thread i have PIAA 520's in the driving pattern ion crystal.....they are very bright kind of a narrow beam , but it goes a great distance.
ATX25RS is offline   Reply With Quote
Old 01-21-2004, 12:03 PM   #17
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
I did the same thing that brunetmj did with some PIAA 004X's for the purposes of 'replicating' high beams. They worked out well. I tied them (as well as my Hella 500s) in with the high beam trigger on the control stalk.
Tell ya what 480w of extra light get peoples attention when you flash to pass
RR
Old 01-21-2004, 12:05 PM   #18
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
Thanks,
Nambo
Try Here:
http://forums.nasioc.com/forums/show...hreadid=481979
'02-'03 WRX Hella driving light mounts pinkrobe Canada Region Forum 4 01-31-2005 03:44 PM
Anyone have driving lights mounted in a WRX airdam. . ? wrxsvt Electrical & Lighting 5 01-23-2003 02:09 AM
Driving light mounting? JC Interior & Exterior Modification 0 05-30-2001 02:45 PM
Driving light mounting suggestions? ttoversteer Interior & Exterior Modification 13 02-28-2001 10:22 AM
HELLA 500 driving lights mounting Q IMPBOY Technical Forum Archive 11 08-26-2000 12:19 AM
