Old 10-27-2003, 01:38 PM   #1
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Default Timing belt installation for a PE belt?
I need to know the number of teeth to count off to mark this belt correctly and then fit it. Anyone have that info handy? The PE belt comes unmarked.
IA Performance is offline   Reply With Quote
Old 10-27-2003, 01:51 PM   #2
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Default Re: Timing belt installation for a PE belt?
I got the CD now... I can look this up for you. Its at home I think...
Clark
AZScoobie is offline   Reply With Quote
Old 10-27-2003, 01:59 PM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
Hope this is what you're looking for:
Calvin
cnk is offline   Reply With Quote
Old 10-27-2003, 03:54 PM   #4
IA Performance
Member#: 25194
Dark Gray
clark, I just got my CD too, but it just tells you to line up the marks.
cnk, I believe that is what I needed. I'll save teh pic and study it a bit later on today.
Thanx all. If anyone has additional comments please feel free to post away.
PE rates this belt good for 200,000KM and 10years on stock motor. 100,000KM and a few less years on highly modified ones. Plus it is cheaper than a new one at the dealer and does not stretch out over time.
Old 10-27-2003, 04:37 PM   #5
IA Performance
Member#: 25194
Dark Gray
Ok, so when marking the distance of #2 I am assuming I am to count the 51 teeth and then make my hash mark. Kind of like in this picture.
Old 10-27-2003, 04:41 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
If you count 51 flats, or 51 toothlengths, then you'll get where they want it.
I'm not sure if they count the start location as 1 or 0, though. I would assume 0, but you know how crazy these Japanese technical writers have gotten in these manuals.
Old 10-27-2003, 04:41 PM   #7
cnk
Member#: 10757
That's how I would interpret it. If you have access to the service manuals, I pulled the pic from the DOHC Engine section, page ME(DOHC Turbo)-049.
Calvin
Old 10-27-2003, 04:44 PM   #8
cnk
Member#: 10757
Originally posted by 8Complex
No, you just marked the 50th tooth.
My interpretation, is that he marked the tooth location in his pic correctly, but he has to put the hash mark in the valley between the 51st and 52nd teeth on the belt as indicated in the pic. This is because you're starting between teeth from point Z1.
Calvin
Old 10-27-2003, 04:45 PM   #9
IA Performance
Member#: 25194
Dark Gray
thanx againk, the belt is marked and ready to go. Now I just wish I had my passenger side timing belt cover handy to bolt on Off to phx tomorrow to drop off the motor for custom up pipe work and a little down pipe work. This turbo is HUGE to say the least.
Old 10-27-2003, 04:45 PM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Edited my post above.
Guess I should learn my lesson from re-editing replies in very active threads.
Help! Timing Belt Install, stuck on the... you know, install RS-Flyboy Normally Aspirated Powertrain 11 07-09-2009 02:03 PM
Where is belt tensioner for the AC belt Stover954rr Service & Maintenance 3 06-17-2006 03:15 PM
Timing belt install CpnNeeda Service & Maintenance 11 07-03-2005 03:37 PM
Timing belt install?? AK'S REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-15-2004 01:18 PM
02 WRX timing belt install after crash cky211 Service & Maintenance 1 12-29-2002 12:25 AM
