Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 10-27-2003, 03:26 PM   #1
KnightWRX
Member#: 41664
black
Default disable the DRL's? Can you pull a fuse?
I dont want my DRL's to be on in the middle of the day...looks retarded.
I can control my parking lights but the only way I know of to turn off the drl's is to pull up the e-brake one knotch when Im driving. Is there a fuse to pull to disable them? If so, which one?
Thanks,
Michael
KnightWRX is offline   Reply With Quote
Old 10-27-2003, 03:30 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
You can disconnect the DRL module located between the glove box and passenger side door. You need to remove the glove box in order to gain access to the unit.
Calvin
cnk is offline   Reply With Quote
Old 10-27-2003, 03:32 PM   #3
KnightWRX
Member#: 41664
black
thanks
Old 10-27-2003, 04:46 PM   #4
bmorton
Member#: 43528
2004 Outback Sport
Removing the glove box probably gives you much better access to the connector, but if you know which module you want to unplug you can also do it by reaching up under the dash, as the module is accessible from below. Depends on the size of your hands, I suppose, but I was able to do this without much difficulty.
bmorton is offline   Reply With Quote
Old 10-28-2003, 07:57 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I un-plugged the module on the passengers strut tower.
Old 10-28-2003, 08:02 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The module on the strut tower is a dropping resistor and not the actual DRL control module. If your lights are stock and you don't plan on modifying them, then disconnecting the resistor is sufficient. However if you plan on installing HIDs you must disconnect the main module by the glovebox. If you're replacing your headlights with Morettes, STi lights etc. it's best to do this as well. There really isn't much extra effort required to unplug the main module, and once this is done the DRLs are totally disabled.
Can you pull a CEL code if the light isn't lit? Mrhappy Mid Atlantic Impreza Club -- MAIC 2 01-02-2009 01:07 PM
How do you disable the DRL's? e8w117 Electrical & Lighting 2 11-11-2004 11:18 AM
05 Legacy GT--anyone know how to disable the DRL's??????? mhelouin Legacy Forum 5 07-16-2004 07:52 PM
Can you pull a code tonight?? mexicanpizza Bay Area Impreza Club Forum -- BAIC 7 01-09-2004 10:03 PM
is this still the easiest/best way to disable the DRL's? Frank_M Interior & Exterior Modification 1 06-06-2001 11:39 PM
