Old 10-27-2003, 05:56 PM   #1
Pre-diddy
Member#: 26837
04 STi - Sold! :(
Default 04 STi HID
Question about HID for the STi...thousgh it may be relevant to all HID, I don't know. Thats why I'm asking.
My friend told me not to turn the car off with the HID's on. Something about when the car is tunned on and they are drawing current from the battery briefly in "ACC" with the key. Like the flicker and the power surge is bad for them. Its better to turn them off untill the car is started, then turn them on? Will leaving them on actually hurt them? Is there any merit to this?
Thanks.
Pre-diddy is offline   Reply With Quote
Old 10-27-2003, 06:37 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Ideally it's best to turn them on and off with the car still running. It probably isn't that bad to accidentally leave them on and shut the car off as long as you then turn the switch off. Starting the car with them turned on would be more potentially harmful because they would come on when the key is first turned to run, then go off as the engine is cranked, then come on again when back in run. You'd be putting them through two startup cycles in a very short time which isn't good. It's also not good for the car's electrical system because of the high current the HIDs draw when they are first turned on.
04 WRX to 04 STi HID conversion mygreenbird007 Electrical & Lighting 2 12-20-2007 12:23 PM
APS DP, STi TMIC, Stock 04 STi HID Headlights Edwin7 South East Region Private Classifieds 10 10-14-2007 10:42 PM
04 Sti Hid --> 04 Wrx Drive4Ever Electrical & Lighting 5 02-02-2007 03:50 PM
USDM 04+ STi HID kit usable in the 04+ JDM Housings? paperchasin Electrical & Lighting 5 02-16-2005 05:26 PM
04 sti hid onto a 04 wrx??? squidney Electrical & Lighting 3 10-22-2004 10:50 AM
Message Board Statistics All times are GMT -4. The time now is 02:36 PM.
