Old 10-27-2003, 08:58 PM   #1
03WRXMA
Member#: 35081
2012 WRX
Default Remote turn on wire for Basslink, where to tap it?
Where from the stock HU should I tap the remote turn on lead for the Basslink? Thanks in advance.
-Dave
03WRXMA is offline   Reply With Quote
Old 10-27-2003, 09:09 PM   #2
paul25RS
Member#: 42209
2004 2.5RS
SQC #158 Silver
if you are using the stock HU, then u are probably using speaker level inputs meaning you do not need a remote lead.
paul25RS is offline   Reply With Quote
Old 10-27-2003, 09:18 PM   #3
03WRXMA
Member#: 35081
2012 WRX
How about when using an LOC?
Thanks!
Old 10-27-2003, 11:20 PM   #4
paul25RS
Member#: 42209
2004 2.5RS
SQC #158 Silver
hmm. when using a line out converter, i guess you could use the wire for the power antenna? im not 100% sure about this one but it should work.
Old 10-27-2003, 11:31 PM   #5
Brad B.
Member#: 10292
2002 WRX Sedan
Wouldn't you be better off NOT using a LOC? I mean, if you are going to convert to Line Level, why not do it as late as possible. Speaker level won't pick up any noise. Are you also hooking up an external amp?
Brad B. is offline   Reply With Quote
Old 10-28-2003, 01:57 PM   #6
03WRXMA
Member#: 35081
2012 WRX
I am only using the Basslink's internal amp.
After reading many threads, it seems the general consensus is use of a LOC improves the sound of the basslink.
I will link to some threads later and you can tell me what you think about it.
Thanks!
-Dave
Old 10-28-2003, 03:43 PM   #7
strohausii
Member#: 26770
'02 WRX
midnight black
you don't need a remote turn on, you will if you get a LOC w/ interconnecting rcas. On the panel for the Basslink is a switch for auto on/off, that is used with speaker wires. It is supposed to turn off after 5 minutes, until then, it's just idle on. I have not used this function, but some people have problems with it not shutting off tho.
strohausii is offline   Reply With Quote
Old 10-28-2003, 03:45 PM   #8
strohausii
Member#: 26770
'02 WRX
midnight black
is this true? i always thought it would be better to tap as close to the source as possible (i don't know the difference although what you said does make alotta sense).
Old 10-28-2003, 05:56 PM   #9
03WRXMA
Member#: 35081
2012 WRX
http://forums.nasioc.com/forums/show...light=Basslink
Above is a link from a guy with a Basslink who tried the speaker level inputs, then switched to the LOC...
Enjoy!
-Dave
Old 10-28-2003, 05:57 PM   #10
Brad B.
Member#: 10292
2002 WRX Sedan
I havn't read those other threads, but for the basslink to amplify your speaker level inputs, it needs to convert them to Line Level first. Line level is more likely to pick up noise (from other electronics in your car) especially if it's a long run (as in running from the front of you car to the rear). Most home audio guys would balk at the thought of a RCA cable longer than 6 feet! That is why you have to be careful where you run your RCAs in a traditional car audio install but you can run your speaker level wires anywhere you'd like.
So, it would seem better to let the basslink do the converting because it would be done the moment before it was amplified. The only reason I can see not to do this is if the aftermarket line level convertor was of superior quality AND you were very careful where you ran you RCA's AND you bought high quality RCA wires.
Again, I did not read the other treads, so maybe there is some other factor here that I'm not aware of (such as the Basslink convertor being a bad design).
Old 10-28-2003, 06:05 PM   #11
03WRXMA
Member#: 35081
2012 WRX
Good info, but PLEASE read the above thread (linked) its very short and compares a before LOC to an after LOC install with the Basslink.
Cheers!
-Dave
Old 10-29-2003, 06:39 PM   #12
Brad B.
Member#: 10292
2002 WRX Sedan
Dave, that thread IS very short! It's one post by one guy. But I'm not doubting his results. Like I said, my Basslink is not hooked up via speaker level connectors, so I can only guess. I would send that guy a PM and ask him.
Old 10-29-2003, 06:46 PM   #13
03WRXMA
Member#: 35081
2012 WRX
Thanks for taking a look!
So you DO use a LOC?
-Dave
Old 10-29-2003, 08:26 PM   #14
Brad B.
Member#: 10292
2002 WRX Sedan
I'm using an aftermarket headunit with RCA outputs built in.
Old 10-29-2003, 09:07 PM   #15
03WRXMA
Member#: 35081
2012 WRX
Doh! The only other option
Long day, still at work...... -Dave
Remote turn-on wire and stock HU markadopolus Car Audio, Video & Security 3 06-03-2006 06:40 AM
How to check HU remote turn on wire? flyingmachine Car Audio, Video & Security 8 02-15-2005 06:36 PM
Remote turn-on wire Glamdring Car Audio, Video & Security 9 04-28-2004 07:25 AM
Stupid question... remote turn on wire... Si2WRX Car Audio, Video & Security 9 11-26-2003 05:48 PM
remote turn-on wire to stock wrx HU question garie Car Audio, Video & Security 5 08-02-2003 12:37 AM
