Old 01-14-2001, 01:21 PM   #1
S_rangeBrew
Member#: 3506
Have a Nice Day? WRX has too many cat. converters!
http://www.imprezars.com/images/2001...w/DCP00511.JPG
I see 3(!) damn catalytic converters!
That's nuts! You know how much HP that is removing off the engine! The first thing that should be done by new owners is to remove those damn things! (only if you are
racing, of course. Wink Wink.
S_rangeBrew is offline
Old 01-14-2001, 01:28 PM   #2
S_rangeBrew
Member#: 3506
Smile
The good news is the IC looks really thick from that angle. Good job Subaru!
Old 01-14-2001, 01:35 PM   #3
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Angry
You complain on how the WRX has too many cats...thank GOD Subaru brought it here for us to drool over. They could have just said (like they did in the past) "oh it's too expensive to bring the WRX to NA because of all the emissions/dot regulations"
Be thankful not whiney about the new WRX...
sorry for venting...
-myk
mykrrrr is offline
Old 01-14-2001, 01:47 PM   #4
S_rangeBrew
Member#: 3506
Unhappy
Sorry you took it the wrong way! I'm insanely happy the WRX is here and it gets 227 hp with three (3!) friggen cats choking it, thanks to the U.S. Govt.!!!
What makes me even more happy is the fact that by removing them, the car will probably gain 30hp!!!
I'm not bitching, I'm pointing out a tuning oppertunity!!
-SBrew
Old 01-14-2001, 01:54 PM   #5
skibaru
Member#: 727
Question
O.K. senior members, how many horsepower can we expect through removal (for racing purposes only) of the cats? Can they be removed? What about the tumble valve? Can you remove any of them and still expect to pass emissions?
skibaru is offline
Old 01-14-2001, 02:02 PM   #6
Jeff 2.5RS
Member#: 1590
2004 Rx8
Post
Modern Catalytic converters aren't as restrictive as you might think anymore, while removing them will provide some extra horsepower (and maybe removing the one before the turbo make it spool up faster) it's not going to be anything groundbreaking. Plus you're going to have to find a way to get around the ECU if planning on moving those cats.
[This message has been edited by Jeff 2.5RS (edited January 15, 2001).]
Jeff 2.5RS is offline
Old 01-14-2001, 03:03 PM   #7
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Post
The ECU will not be as hard as some think. Coming from the honda world I have faced this problem when OBD2 first came out. The ECus can be reprogrammed to ignour one lambada, both, or recode the ECU to behave when a cat is gone and the reading changes.
Or you could just get an apexi Power FC or Link, when it is available here.
DeliciouSpeed is offline
Old 01-14-2001, 03:03 PM   #8
uncleho
Member#: 1905
Post
I know you jest, but we Americans must really learn to be more protective of our environment.
Not to sound like some fanatical environmentalists, but it only makes sense, because this earth isn't as big as most people think anymore. We take it for granted, because we have it so good.
There are countries and cities that don't regard good breathing too much and it shows. If you had to breath in a city like Mexico city for a day, you'd demand converters on lawn mowers!
Tune on!
uncleho is offline
Old 01-14-2001, 03:04 PM   #9
KC
Member#: 442
16 SS
00 S2000
Post
OK...looking at the cats...do all three have o2 sensors? If not, you can eliminate some.
--KC
KC is online now
Old 01-14-2001, 03:09 PM   #10
jackwei
Member#: 233
Post
didn't someone say that the ECU will run FUNNY (not just "check engine" light funny) without the cats?
jackwei is offline
Old 01-14-2001, 06:33 PM   #11
Prog
Member#: 1473
2005 Legacy GT 5MT
Satin White Pearl
Post
I really do agree with you..but...would a WRX with no cats have worse emissions than most SUVs out there?! which are excempt from EPA regulations? Or at least theyre not as stringent?
Prog is offline
Old 01-14-2001, 06:46 PM   #12
Julian
Member#: 1182
MY00 RS
BRP
Post
I'm not a SUV lover by any means, but with that said, I must point out that SUVs are indeed regulated for emissions just like us. Ford will even have their models meet LEV status (as applies in Cali). Emissions are different from mileage of course. For the most part cars these days are clean (or, 98% clean compared to unregulated cars). The UK didn't even luck out as much as we have. I'll take a three-cat WRX over nothing every time...
Julian
Julian is offline
Old 01-14-2001, 06:52 PM   #13
AKGC8
Member#: 1305
2000 Impreza
Post
Jeff 2.5RS is right. Modern catalytic converters are generally no more restrictive than the stock exhaust. The only way you will get gains is by removing the cats and upgrading the rest of the exhaust system as well. Of course if you are removing the cats you would have probably already upgraded the exhaust. Oh, and if you are considering this, look into high flow cats. They are less restrictive, and help the environment as well.
AKGC8 is offline
Old 01-14-2001, 07:24 PM   #14
XT6Wagon
Member#: 524
04 STi
Post
While I plan of getting rid of the pre-cat in the crossover if(when?) I get a WRX, I will at a minimum leave one 3 way cat in the system. Cats are cheap, serve as a muffler, and saves you that several thousand dollar fine you get if you are cought running without a Cat.
On review of the pic, my FIRST mods would be to toss the stock crossover, POS turbo, down pipe, and exaust. A used VF-28 is cheap, and I like the IHI relaiblity. The Downpipe would end near the same place, then a bolt in cat section with a 3 way cat, then the rest of the exaust. The crossover would simply have the cat, and turbo flange changed to a straight pipe and flange for the IHI. The bolt in cat section is incase it ever sees racing duty where continious high RPM operation can burn it out.
XT6Wagon is offline
HTML code is On
Picked up 09 wrx today...too many miles? luckyjoe General Community 63 06-19-2009 05:48 PM
State report says Texas has too many reports SkirtBoy Off-Topic 5 10-29-2007 04:00 PM
guy has too many cars, must sell 88conquestTSI Off-Topic 14 02-18-2006 11:09 PM
Auto Car Wash joint near me has too many accidents. Snoopy Off-Topic 7 06-20-2005 10:46 AM
Oh Noess!!11!!!!one!! Teh Krispy Kreme has too many carbs! CandyO Off-Topic 25 05-26-2004 09:35 PM
