Old 10-28-2003, 03:28 PM   #1
1stonscene
Member#: 22916
2002 WRX wagon
Default Omori EGT guage: problems
I've had the guage in for about a month, and have noticed that whenever it's wet out, the guage temp drops dramatically--sometimes almost not even reading. When it dries up outside, no more problems--the guage seems to read and respond normally. Any suggestions as to the cause, or even better, how to fix this? Thanks,
Pat
1stonscene is offline   Reply With Quote
Old 10-28-2003, 06:37 PM   #2
jjunior887
Member#: 16738
2015 WRX Limited
CWP
Same problem here but only if I hit large puddles to get the wire/sensor wet. I have just gotton used to it.
jjunior887 is offline   Reply With Quote
Old 11-10-2003, 05:51 PM   #3
DriftnWRX
Member#: 44653
2002 WRX sedan MBP
2004 FXT JBP 5 speed
hey, where did you guys mount your EGT probe? I just got my Omori gauges and am trying to figure out what is going to be involved in getting this to work.
DriftnWRX is offline   Reply With Quote
Old 11-10-2003, 05:58 PM   #4
1stonscene
Member#: 22916
2002 WRX wagon
Not sure exactly where... I had a friend of mine do the work, and he tapped the manifold on the driver's side. Hope this helps.
Old 11-10-2003, 06:16 PM   #5
jjunior887
Member#: 16738
2015 WRX Limited
CWP
Mine is on the Passenger side manifold on the casting button right where the two cylinders come together. I had to take it apart to replace my uppipe gasket anyway so I put it there, I've heard the drivers side is a little easier if that's all you're doing. -James
Old 11-11-2003, 03:46 PM   #6
DriftnWRX
Member#: 44653
2002 WRX sedan MBP
how difficult is it to tap the manifold?? I would rather do it myself then pay for someone to do it. But I also dont want to mess anything up.
Old 11-11-2003, 03:55 PM   #7
jjunior887
Member#: 16738
2015 WRX Limited
CWP
I think it was harder getting it off and back on than tapping it. You just drill a hole then use the tapping bit back and forth about a half a turn at a time until it's through. I would do a search on the web for the correct procedure but it's not that hard, just make sure you keep it straight.
Omori EGT problem? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-28-2005 02:24 PM
Anyone able to fix OMORI EGT craizyness problem?? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-11-2005 12:42 AM
Omori EGT gauge problem (long) BluSuby Electrical & Lighting 10 07-15-2005 02:13 PM
Omori EGT Problem! Leonardo Electrical & Lighting 12 05-28-2004 02:15 PM
Omori EGT gauge problem... mturmel Electrical & Lighting 9 05-10-2003 11:58 PM
