Old 10-29-2003, 01:49 PM   #1
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
Default How can I remove rotor rust?
Hey, guys and girls
I don't know if its right forum but I need little help. I just replaced DBA4000 front rotors last week and I already got bad rust spots all over the place after few days rainning. I used brake cleaner and WD40 but it didn't come off. It looks so bad.
Anyone know how to clean up rust spots on rotors?
Thanks,
wrx2 is offline   Reply With Quote
Old 10-29-2003, 02:46 PM   #2
Zack
Member#: 41126
2000 Miata
Emrald Mica
If it's just on the contact area, the rust will come off when you hti the breaks. If you're tlaking about the whole rotor, then I don't know how to protect it..
Zack is offline   Reply With Quote
Old 10-29-2003, 03:27 PM   #3
WRX-U
Member#: 8555
Unhappy only way...
...I know how to protect from the rust would be to, sand, primer, and paint. Make sure you tape the brake surface area befor though!
My .02 ~B
WRX-U is offline   Reply With Quote
Old 10-29-2003, 05:42 PM   #4
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
Thanks for your inputs. The rusted area is non contact area including edge where the pads doesn't contact and center hub area.
Old 10-29-2003, 09:07 PM   #5
Akiata
Member#: 297
I think you can get them cadmium (or something like that) plated to protect against rust but I don't know if you can do it when they are already used and rusting.
p@
Akiata is offline   Reply With Quote
Old 10-29-2003, 11:08 PM   #6
That Guy
Member#: 23212
2002 Impreza RS
Best thing to do is pull the rotors off, clean them, paint them, then bake them. I'd say get some good high-temp exhaust header paint, good to over 1000 degrees. Paint the whole rotor, even the contact area. The paint won't stand a chance against your pads and the brakes hydraulics. New rotors come with a anti-rust coating that the pads take off quickly, so don't worry about your brakes not working.
That Guy is offline   Reply With Quote
Old 10-30-2003, 04:13 PM   #7
Kartoffel
Member#: 12976
grocery getter
It's safe to clean off the rotor and spray those areas with high temp paint. Make sure you use something that's rated to at least 1200F. Stove paint, manifold paint and BBQ grill paint should do the trick.
Kartoffel is offline   Reply With Quote
Old 10-30-2003, 05:19 PM   #8
Silver Bullet 02
Member#: 37486
Don't paint the contact area.
Silver Bullet 02 is offline   Reply With Quote
Old 10-30-2003, 06:55 PM   #9
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Hmmm you mean like this:
As above, no probs with painting the contact surfaces IMO. The pads clean it off nicely. That is VHT manifold paint BTW baked on at 600 degrees.
ss
subysouth is offline   Reply With Quote
Old 10-30-2003, 08:08 PM   #10
Kartoffel
Member#: 12976
grocery getter
it doesn't hurt to paint the contact area. just go for a quick drive after the paint sets and the pads will scrub it right off.
How do you remove rotors? 949 Brakes, Steering & Suspension 16 07-20-2005 01:29 PM
How can i remove the molding/glass from the wagon rear? ^jynx^ General Community 1 10-19-2003 03:54 PM
How can I remove a toenail without going to the doctor? HalfBaked Off-Topic 25 05-05-2003 07:05 AM
How can I remove or adjust the stock spoiler on MY00 RS? Robmat Service & Maintenance 3 02-14-2002 08:58 PM
How can I remove spray tint from my taillights? Ripper_AWD Interior & Exterior Modification 6 10-12-2001 11:01 AM
Message Board Statistics All times are GMT -4. The time now is 02:37 AM.
