Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 01-13-2001, 05:32 PM   #1
Member#: 498
1981 jdm swapped gc
Unhappy rattle from rear pasenger Strut!!
after i installed my springs i have a rattle come from the rear strut when i hit a bump it is a rattle pretty loud and anoying, could it be the actual strut bolt that i took of to put the spring on? could it be loose?
GregBolby is offline
Old 01-13-2001, 06:23 PM   #2
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
This could be the spring coming unseated from the strut. I would take it back to the place that did the work.
Tkacik is offline
Old 01-13-2001, 08:27 PM   #3
Member#: 355
08' VW Touareg II
Alaska Grey
Chances are you’re right about the top strut nut being loose. After installing KYB-AGX's my right front loosened up after a few days of hard driving. It drove me nuts until I figured out the cause of the noise. A couple of good yanks with a wrench solved it.
DonA is offline
Old 01-14-2001, 01:24 AM   #4
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Did you use new locknuts for the top nut and the 3 small nuts that secure the strut to the body, following the manufacturer's service procedure?
Didn't think so. Tighten that top nut to something like 43 ft*lb (making sure the strut shaft doesn't turn by holding it with a hex key).
Necromancer is offline
Old 01-15-2001, 01:49 AM   #5
Sam Kaufman
Member#: 3135
98 2.5 rs
Was it more like a really load creak? I had this problem for about two weeks when ever I came into my driveway or on slow turns and slow speed bumps. It went away for the most part. You got me thinking that I should look into it a bit more.
Sam Kaufman is offline
Old 01-15-2001, 07:34 AM   #6
Member#: 791
1998 Impreza RS
Brilliant Red
The clunk is most likely a strut top nut.
The creak is most likely the plate atop the spring that wasn't aligned properly when installed.
Chuck is offline
Old 01-15-2001, 03:10 PM   #7
Homicidal Maniac
Member#: 1612
2008 STI
I have had this problem since I did my suspension install. It was fine at first, then it began to rattle. I later found out it was the strut mount bolt, and tightening it resolved the problem. The rattle is back, not not like the strut rattling around. It now seems like the strut mount cap is rattling against the strut mount on the frame (read: the strut mount cap is flexing into the frame). I plan on replacing the strut mount caps with Grp N caps, in hopes that it resolves the flex. My kybs are rather stiff at 2f/7r with tein s-tech springs.
stimpy is offline
HTML code is On
Rattle from front drivers strut milehighwrx Brakes, Steering & Suspension 4 02-25-2013 02:35 PM
Metallic rattle from rear drivers side?? jroberts Service & Maintenance 4 07-28-2003 01:28 PM
Small rattle from rear passenger side seatbelt? RWagner STi Forum Archive 4 06-10-2003 08:03 PM
Rattle from rear door (passanger side) blueimpreza25rs Service & Maintenance 2 10-01-2002 09:33 AM
Rattle from rear driver side wheel...how do i fix it? CanadianWRB-WRX Brakes, Steering & Suspension 2 05-04-2002 12:07 PM
