Old 01-13-2001, 03:01 PM   #1
beachbum
Member#: 457
---- Smells like
weed and rampage
Angry D'oh! I broke my radiator!
I decided to change my timing belt this weekend (1995, 1.8L, FWD). No biggie, right? Well, in trying to get the crank pulley off, I got a little carried away with the breaker bar and nailed one of the little tabs that the driver's side fan mounts to. Of course, it's a molded in part of the plastic top cap of the radiator, so I now have a nice big hole in my cooling system.
So, does anybody have any thoughts? It seems like I could CA (Super Glue) it back on, but I don't know if that would hold. A new radiator costs a ton, I'm sure, and I'd like to avoid that if possible. I need my car fixed by Monday, I'm in the middle of nowhere (Nebraska) and to top it off, we're in a winter storm watch, so driving to the nearest dealer (50 miles) is out of the question. So what do I do? Any tips would be greatly appreciated.
Josh Beach
World's Slowest Impreza Project
Now with new and improved setbacks!
[This message has been edited by beachbum (edited January 13, 2001).]
beachbum is offline
Old 01-13-2001, 03:08 PM   #2
ImprezaL
Member#: 1393
Lightbulb
Ouch, from one 1.8l owner to another- good luck man!
ImprezaL is offline
Old 01-13-2001, 03:12 PM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Check http://www.car-part.com/ or http://www.copartfinder.com for a radiator from a junked Impreza.
RidinLow is offline
Old 01-13-2001, 03:51 PM   #4
beachbum
Member#: 457
---- Smells like
weed and rampage
Post
Here's some pics. I'm thinking super glue and a splodge or two of epoxy of some sort will hold it. The cooling system isn't under that much pressure. Any further thoughts?
Josh
beachbum is offline
Old 01-13-2001, 04:12 PM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
That's a big hole! If it was small enough, then I would have suggested a pack of chewing gum. They work very well on leaky radiators, especially when the leak is from the top part of the radiator.. Go to a junk yard and see if they have any good radiators from the same vehicle.
tmat3 is offline
Old 01-13-2001, 04:19 PM   #6
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
Post
hell if i were you i would cut a coke can to fit a sheet over the hole and then take apoxy and paint over the aluminum and hold it down. wosre case senerio you just have to buy a new radiator like you have to now
bill harvey is offline
Old 01-13-2001, 06:33 PM   #7
SalKhan
Member#: 3437
2000 Contour SVT
Silvah
Post
What you really need to do Josh is get that rear diff working.
Hee hee... Sorry.
Sal "POS Ford" Khan
SalKhan is offline
Old 01-13-2001, 08:55 PM   #8
ARG
Member#: 386
1999 Impreza RS-S
Rally Blue & Supercharged
Thumbs up
J.B. Weld. The absolute best epoxy in the world. Go somewhere and find it. Clean off both pieces real well with carb cleaner, let dry and then apply liberal amounts of J.B. Weld. Yo will have to let it cure for about 24 hours, but it will hold.
ARG
ARG is offline
Old 01-13-2001, 09:51 PM   #9
dandbest
Member#: 1885
2015 Evo
Post
In my opinion, no ammount of glue will make this thing seal. I think for now you're sorta screwed. Try a local part store for a radiator if the dealer is too far away. You'd be surprised at the unusual things they have in stock.
Danny
dandbest is offline
Old 01-13-2001, 10:07 PM   #10
montgog
Member#: 911
2005 Sti
Post
Liberal amounts of JB weld will hold it. I have used that stuff on radiators in the past. Good stuff.
montgog is offline
Old 01-13-2001, 10:21 PM   #11
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
There is to much pressuer inside of a radiator for JB weld to hold that on. You are going t oneed a new radiator IMO..
Eric
Eric SS is offline
Old 01-13-2001, 10:24 PM   #12
GZoomer
Member#: 664
2003 Legacy GT
Post
You could try glueing it as a tempory fix but the correct way to fix it is to replace it. Unless of course you can just replace the whole plastice end piece. Anything else will sooner or later leave you stranded I fear.
GZoomer is offline
Old 01-13-2001, 11:32 PM   #13
ARG
Member#: 386
1999 Impreza RS-S
Thumbs up
Your radiator maxes out at 16psi. J.B.Weld will hold that no problem. Just make real sure that both mating surfaces have absolutely no antifreeze/coolant on them before applying the epoxy.
ARG
ARG is offline
Old 01-13-2001, 11:37 PM   #14
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Post
How good is JB weld on plastic?
Eric
Eric SS is offline
Old 01-13-2001, 11:42 PM   #15
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Post
Go with the JB Weld, don't push the car too hard, and once you get back, replace the radiator. The JB should be a good enough temperary fix, but I would get that thing replaced ASAP. Might be expensive, but sure beats having a warped block and heads!
HondaH8er is offline
Old 01-13-2001, 11:55 PM   #16
Snoopy
Member#: 700
99 Impreza RS
Silverthorn Metallic
Post
I heard duck tape fixes everthing.
Snoopy is offline
Old 01-14-2001, 12:13 AM   #17
ARG
Member#: 386
1999 Impreza RS-S
Cool
If you look at the pic of the broken piece, it has small "hairs", that means that it is fiberglass reinforced resin, not plastic. It is pretty tough stuff. I use J.B.Weld on a lot automotive applications. No problems yet. But still, a new radiator would be in order once you get the cash up. Or better yet, order a new all aluminum 3 row "Koyo" radiator from Summit Racing! Only $430.00!
ARG
ARG is offline
Old 01-14-2001, 12:19 AM   #18
WRX Pilot
Member#: 3487
Post
One other opption. if there is a motorcycle shop anywhere near you they can "plastic weld" it and it will be better than new....but you have to find a plastic welder? here in california radiator shop will have them sometimes.good luck
WRX Pilot is offline
Old 01-14-2001, 12:22 AM   #19
beachbum
Member#: 457
---- Smells like
weed and rampage
Post
Well, here's a little update. Good news is, the timing belt went on fine even though I could have used a third hand, and the car starts and idles good. I got a suggestion from a friend-of-a-friend (witness the power of the Internet! I was receiveing responses within a half hour of actually having the problem) earlier tonight and since I was a bit freaked out and in a hurry, I went with it. I used some high-strength epoxy (not JB Weld, but hopefully good enough) and laid several layers of fiberglass cloth around the break. It takes a long time to set up, so I'm going to try putting the fans back on tomorrow. I'll have some pics to show everyone then.
Thanks for the suggestions and encouragement you guys have given. The i-Club is a great place.
Oh, and a couple more things: I live in Nebraska, no "getting back" for me. Nice thought though.
And Sal... You really want to go there?
HondaH8er: Actually, the difference between a new radiator and a used engine with half the miles as mine from Dale Teague is only about $100! Surprising, eh?
Josh Beach
beachbum is offline
HTML code is On
Got my oil changed at Sears and the Tech broke my OBD2 adapter for my Accessport! seanforney AccessPort 12 09-21-2009 04:55 PM
I broke a plastic on my radiator that hose was hooked up to... elitescouter Newbies & FAQs 12 07-11-2009 04:47 PM
Somebody broke my wiper arms... broke off. sub_rho Off-Topic 50 11-11-2008 08:54 AM
Plastic Nipple broke on Radiator Pcp03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2006 08:16 PM
UPS! My seats! .... D'OH! Package for my wife. Siper2 Off-Topic 16 06-23-2004 11:39 AM
