Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 10-30-2003, 12:57 AM   #1
Member#: 46367
Default subaru repair in northern california
Hello I live in sebastopol. I have a 2000 2.5 rs impreza. Recently the starter seems be spinning freely and not starting the engine.
Can anyone recomend a mechanic in Northern California?
thanks!
dan walton
dan@infinitedata.net is offline   Reply With Quote
Old 10-30-2003, 03:06 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Does it happen if the car is sitting around for a little while after you drive it? Does it crank for awhile like that, but always start if you keep cranking it?
Old 10-30-2003, 12:23 PM   #3
Member#: 46367
Default starter problem
no, it drives fine. its almost like the starter isn't engaging the engine. it spins freely, and makes some nasty noises as it does so.
Old 10-30-2003, 12:34 PM   #4
platypus
Member#: 11774
Car 334
I recommend MPJ Performance if you need to have the car looked at.
platypus is offline   Reply With Quote
Old 10-30-2003, 01:06 PM   #5
Craig W
Member#: 643
1999 2.5RS
WRX powered
I'd also recommend Subaru of Santa Cruz, or I-SpeedUSA in Santa Clara.
Craig W is offline   Reply With Quote
Old 10-30-2003, 05:27 PM   #6
vinster02
Member#: 7888
02 wrx
WR Blue
If you want we can just replace the starter. I'm not a shop. however I'm a very good wrench. & I understand that there are those that are not intrested in messing with that stuff. If you want a shop thats cool. There is penner automotive in Santa Rosa. They specialize in standard subaru repair. i've got their card in my truck, if you want give me a call. later, vince....(707) 280-8090
vinster02 is offline   Reply With Quote
Old 10-31-2003, 01:50 AM   #7
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
That starter is an hour job, max.
It's probably not going to be a replaceable part within the starter, so if you just get a new/used unit (i know the recycler in Rancho has a couple for $75), it's a cinch to put in.
3 bolts on top. and one that you can get to from underneath if you jack up the car a little on the crossmember. It should be a 17mm, and get a breaker bar, you'll need it
When I was having problems, it ended up just being my solenoid contacts: $5 later and a little bit of work and my car was good as new
sybir is offline   Reply With Quote
Motorsport Fabrication in Northern California SuicidalLabRat Motorsports 8 05-09-2007 04:05 AM
93 Impreza L in Northern California CatchMyDrift Private Vehicle 'For Sale' Classifieds 31 08-30-2004 12:14 PM
WTB: '00-01 RS w/ 5MT in Northern CALIFORNIA Stg2lgcy00 Private 'Wanted' Classifieds 1 02-14-2004 02:04 PM
any dirt roads in Northern California to play around on? WRooster Bay Area Impreza Club Forum -- BAIC 11 08-03-2002 02:30 AM
Who wants the best Subaru technician job in northern California?! Bruce Feinberg Bay Area Impreza Club Forum -- BAIC 15 07-24-2001 11:39 AM
