Old 10-28-2000, 04:17 PM   #1
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Question Using hand brake w/AWD???
Can this be done without screwing up the AWD system on my RS???
I'm talking about the handbrake turns on gravel/snow covered roads. It's fun in a FWD but I'm scared that if I try it in my RS it'll screw something up...
-myk
mykrrrr is offline
Old 10-28-2000, 05:13 PM   #3
Dobes
Member#: 164
2008 Exige S240
Post
Tony........you wanna field this one?
Dobes is offline
Old 10-28-2000, 09:14 PM   #4
Bankheist
Member#: 2237
2000 GC8 STi
2015 Ford Mustang GT
Thumbs up
I've done it a couple times on dry pavement at work. Always dropping the clutch... but still I think the clutch helps from blowing up the center differential... I still you could mess it up either way.
I think, not too sure on that one... someone point me in the right direction.
Bankheist is offline
Old 10-29-2000, 12:03 AM   #5
rpone605
Member#: 1669
2004 WRX Sport Wagon
Post
um goodbye center diff??? probably get away with it a few times but i wouldn't recommend it.
rpone605 is offline
Old 10-30-2000, 01:00 AM   #6
mykrrrr
Member#: 733
'16 Fiesta ST
Post
That's what I was thinking too but just thought I'd ask.
-myk
mykrrrr is offline
Old 10-30-2000, 05:25 AM   #7
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Post
The WRC Impreza automatically disengages the rear drive when the driver pulls the hand brake. Too cool!
But as they say . . . Don't try this at home boys and girls.
T-WRX is offline
Old 10-30-2000, 09:30 AM   #8
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Post
Thanks Dobes, I think...
Yes, dip the clutch and yes, your center diff wonn't like it. How long will it last, I dunno, I've done it a lot on dry pavement and it's still working. Probably not a good idea, we'll see.
Tony
Tony is offline
Old 10-30-2000, 09:38 AM   #9
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Was a passenger in an rainy autocross when someone used the handbrake a lot in a '98 2.5RS. Worked okay sometimes, not so well others. Probably just needed practice.
I can't see it working great on dry tarmac-- to hard to get sliding (hopefully) and slows you down too much when you do.
Maybe I'm wrong, or just a chicken.
ColinL is offline
Old 10-30-2000, 09:43 AM   #10
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
works great off road.. hehehehe
Subie Gal is offline
Old 10-30-2000, 09:45 AM   #11
Geezer
Member#: 915
2000 Impreza Turbo
DBM
Post
Not recommended. Whether the clutch is engaged or not, the centre diff doesn't like extreme differences in wheel speed. Remember that the centre diff just controls torque between the axles, and the clutch transmits torque from the crank to the prop/driveshaft/transfer gear etc.
The rally cars employ all sorts of trick electronics to achieve the ability to handbrake the car, and the 'box potetnially only has to last one rally before a rebuild. Your precious bit of kit is designed to last about 60,000 miles without use of the handgrake though!
Geezer
Geezer is offline
Old 10-30-2000, 10:01 AM   #12
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
yeah but those of us w/auto's.. i hear it won't hurt our diff's "as bad" as you manual guys... and... well it takes 21 days to form a habit... believe me the habit is formed!
i have to have my ebrake adjusted continually!!!
j.
Old 10-30-2000, 10:59 AM   #13
Gambit
Member#: 102
Thumbs down
You'll not only wreck your diff, your center VC will get busted too. You're basically locking the rear wheels thus causing a drastic change for the VC to change accordingly. However since our AWD works with liquid it is not as bad as say doing it the same with a Torsen diff. Those mechanical center differential will blow up. Too much strain in too little time for change. bad bad bad. A car that is setup properly should not require hand brake to assist in turns. Or driven properly for that matter. U're just hurting the car. FWD has no rear differential therefore it's ok to use the handbrake technique.
Gambit is offline
Old 10-30-2000, 11:30 AM   #14
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Post
Yes, it is almost never faster to navigate a turn with the handbrake. I use it as a last-ditch maneuver if I overcook a corner and then it's usually faster than grinding to a near halt and turning the car around. I did win an autox by using the handbrake on my fastest run to make a hairpin at the finish. Also I can remember a 180 pivot cone that rewarded handbraking but I clipped cones elsewhere in that run, it would've been 2/10ths faster. Those are the exceptions not the run though.
Tony
[This message has been edited by Tony (edited October 30, 2000).]
Tony is offline
Old 10-30-2000, 12:06 PM   #15
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
ok i see...
well it's so much fun tho!!
but you guys are right - i really don't NEED to do it... just choose to do so. I see your point though. It is harder to come out of the corner tho after e-braking... i will have to relearn myself - break (no pun intended) that nasty habit.
thanks guys.
j.
Old 10-30-2000, 04:17 PM   #16
#522
Member#: 2185
Post
I'm glad i've only done this a few times at less than 20 mph in the dirt. After I did it, it just felt wrong, so I stopped. I figured front wheels = 20mph, Rear= 0, center diff =
Good thing, now that I read this, it just confirms what I thought.
#522 is offline
HTML code is On
wtb hand brake cable for 93-01 for rear disc brakes 2slofouru Private 'Wanted' Classifieds 3 07-17-2006 12:55 AM
AWD vs. Hand-brake Mothra Transmission (AT/MT) & Driveline 5 05-16-2002 05:44 PM
('93-'01) Busted Hand Brake In My Legacy Outback SubaruLover Impreza Forum 5 06-14-2001 01:17 AM
Help.....Busted Hand Brake In My Legacy Outback SubaruLover Legacy Forum 1 06-13-2001 08:19 AM
('93-'01) How do you adjust the hand brake? 2yLiTe Impreza Forum 3 06-11-2001 07:50 AM
