Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 01-25-2001, 06:14 PM   #1
bigbird
Member#: 1685
2001 2.5RS-T FMIC
WHITE
Talking Ah dude?! How do I properly check the oil level?
No, I am not a retard
I changed the oil myself, and I've added the right amount. It was just a LITTLE below the full mark (engine still a little warm). Than I checked it after a test drive, it was withing the F range. Than I check it today and its like waaaaaay above F, and I've tried taking it at different engine temps, even completely cold, warm, operating and etc. The level is never correct or the same, it goes up, it goes down, it goes sideways, splits into two colums and etc. This dipstick is driving me crazy. I know I put the right amount in, but how come this son of a biotch won't show it? I never thought I would ask this, but is my dipstick broken hahahahahahahahaha
Oh, in case it matters, its a 2001 2.5RS 5SPD , and I switched to SYNTHETIC oil 5w-30 mobil one
[This message has been edited by bigbird (edited January 25, 2001).]
bigbird is offline
Old 01-25-2001, 06:26 PM   #2
Ken
Member#: 34
2005 WRX STi
World Rally Blue
Post
Here's my stab at it:
- park on a flat spot.
- I always check it when the engine is cold.
Yes, my dipstick is sloppy as well; just try to pull it out straight. I try to look for a "V" mark on the stick, where reading is at the lowest point. Check both sides of the stick as one side could have rubbed and made it messy when you pulled it out.
Remember if you forgot to fill up the oil filter before installing it, cycle the oil around a bit after you finish dumping in the prescribed amount, before taking your reading.
Ken is offline
Old 01-25-2001, 06:29 PM   #3
dcoty
Member#: 3149
01 V7 GC/R32 sky
Post
well, if your engine was still warm, then chances are all the oil hadnt flowed back down into the resivoir from the engine, making your reading low when you checked. check your oil in the morning before starting the car and that will be an accurete reading.
-hope this helps,
Dan
dcoty is offline
Old 01-25-2001, 07:39 PM   #4
bigbird
Member#: 1685
2001 2.5RS-T FMIC
WHITE
Post
Yeah, my dipstick gets a little messy when I pull it out hehehe
Thanks, I will try it in the morning, thanks guys.
bigbird is offline
HTML code is On
how do you guys remove the oil drain tube on the head? ownnij Built Motor Discussion 14 12-10-2009 10:07 PM
Remeber always check your oil level, I didn't haha I *ALMOST* killed my engine kirbykirb Legacy Forum 6 07-18-2009 10:13 PM
How Do I Pressure Check JUST the TMIC and BPV? 2:43AM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-04-2009 05:17 PM
What's the proper way of checking your oil level? eurospek Service & Maintenance 5 11-20-2007 10:25 AM
How do you properly dynomat the doors of the WRX Goofy's WRX Car Audio, Video & Security 22 03-29-2005 04:49 PM
