Old 05-11-2004, 08:36 AM   #26
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
The general theory is that an exhaust will not cause boost creep. It is the design of the VF-39 itself that causes this. Porting the wastegate should solve boost creep issues.
Old 05-15-2004, 02:33 PM   #27
STUDAndring
Member#: 61891
04 WRX
Pearl Blue
I was wondering what is the stock downpipe's specs on a '04 WRX . So I do not replace a stock pipe with a pipe that is not anybetter.
STUDAndring is offline   Reply With Quote
Old 05-15-2004, 02:38 PM   #28
supermarkus
Member#: 6971
2008 WRX STi
SSM
They're the same as an 02-03 downpipe as far as I can tell. All of the above info applies to the 04 models.
supermarkus is offline   Reply With Quote
Old 07-20-2004, 06:06 PM   #29
rukkie
Member#: 57833
2012 STi Hatch
I'm having a hard time understand how/why the stock downpipe covers the waste gate section, while the other designs all merge the waste gate exaust into the pipe somewhere? So does the stock turbo dump anything into the waste gate at all? If so, why is the stock DP waste gate section covered?
rukkie is offline   Reply With Quote
Old 07-20-2004, 06:09 PM   #30
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
With the stocker, the gasses from the wastegate slam right into the flat part of the DP flange, where it meets up with the turbo. Then the gasses have to make a 90 degree turn, right into the main portion of the DP. This causes turbulence.
snvin is offline   Reply With Quote
Old 08-29-2004, 08:44 PM   #31
TX007
Member#: 67624
2013 WRX
Thumbs up
WOW...THANKS for all the info. Just bought an HKS DP and was searching for some more info. You wrapped it up and then some!!!
TX007 is offline   Reply With Quote
Old 08-30-2004, 08:52 AM   #32
Oztek Motorsports
Member#: 25170
1991 Galant VR4
Nile Black
Boost creep is a caused by the wastegate not allowing enough exhaust gasses to pass thru it. When you increase the flow of the exhaust by changing it, you run into the problem of the stock wastegate not being able to by-pass the extra flow. Thus you get boost creep. It's a purely mechanical/flow problem. It doesn't have anything to do with boost controllers, etc.
Porting, or increasing the size of, the wastegate will allow more exhaust to pass thru the gate. This will solve the creap problems.
Oztek Motorsports is offline   Reply With Quote
Old 08-31-2004, 04:04 PM   #33
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Is it true that divorced downpipes also prevent boost creep?
WRXRallyBlue is offline   Reply With Quote
Old 08-31-2004, 04:06 PM   #34
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Nope.
Old 08-31-2004, 04:30 PM   #35
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Thanks, and I like your title
Old 09-14-2004, 05:01 PM   #36
midgettosser1
Member#: 58295
what horsepower gains are u lookin at between a short dp and a dp that eliminates the third cat? assuming only mod is a catback at the moment.
midgettosser1 is offline   Reply With Quote
Old 09-14-2004, 08:54 PM   #37
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
No one really knows. Best guesstimate I have heard is 5HP per cat, so no cat + longer/bigger pipe = 7HP on my GuessDynoŽ vs. a short catless downpipe.
Old 10-07-2004, 10:03 PM   #38
billzebub
Member#: 40248
2003 WRX
Midnight Pearl (black)
bumping for the non-searching types.
billzebub is offline   Reply With Quote
Old 10-12-2004, 06:29 PM   #39
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
bump
WRX8XB is offline   Reply With Quote
Old 10-25-2004, 01:34 AM   #40
flyhi4af
Member#: 51968
Question Wastegate porting
"Porting, or increasing the size of, the wastegate will allow more exhaust to pass thru the gate. This will solve the creap problems."
Does anyone know what the stock diameter is and to what dimensions the gate should be ported to? Can this be done with the exhaust pieces removed and leaving the turbo attached to the car? My assumption is I should probably remove the turbo but it would save time if I didn't have to. Are there any gotchas to doing this myself using a Dremel or drill? Or should I have a machine shop do it using a heavy drill press?
Thanks
flyhi4af is offline   Reply With Quote
Old 10-25-2004, 06:22 AM   #41
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You will have to search for your answer please as this thread is about downpipes. Search hard as wastegate porting is both a science and an art and isn't as simple as boring out a hole.
Old 11-19-2004, 04:50 AM   #42
hey1
Member#: 72106
2002 Impreza WRXagon
Platinum Silver Metallic
Question
So is that turbulence cause by the gasses from the wastegate the important part? or is the seperation of the exhaust gas and the waste gas important?
If so, then wouldn't stock be better than the bellmouth, while the divorced be more efficient than stock?
This concern of mine postpone my decision on helix downpipe.
hey1 is offline   Reply With Quote
Old 11-19-2004, 10:12 AM   #43
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
You are thinking too much about this. The stock design is crap, and the bellmouth = divorced performance. The turbulence is the bad part, not the seperation of gases.
mbiker97 is offline   Reply With Quote
Old 11-19-2004, 03:51 PM   #44
hey1
Member#: 72106
Well.. I don't want to sound all gullable, but according to the original post of this FAQ, "The thought process is that the greater the separation there is between the wastegate gases and exhaust gases, the smoother the overall exhaust flow."
So in some way, one should be more efficient than another downpipe. If the turbulance really is that bad part, then perhaps the divorced flange is better because there must be an important reason why they have a design to separate the two distinct gasses to begin with. So is there anyone that has experiences with both bell mouth and divorced downpipe before?
Old 11-19-2004, 05:56 PM   #45
WRX8XB
Member#: 45323
Search, this isn't a new topic
Drew
Old 11-19-2004, 06:11 PM   #46
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
Different tuners have different theories regarding this.
Some say divorced is better, some prefer bellmouth. Both are good.
Personally, I have a divorced DP (Bosal), and I have experienced no issues with it whatsoever -- but I am running the divorced design because I wanted a 'short' DP that would allow me to use the stock 3rd cat, and most 'short' DPs are divorced/twin dump.
Old 11-19-2004, 10:03 PM   #47
hey1
Member#: 72106
Drew
I did, else I would've started a new thread.
Old 11-20-2004, 04:26 AM   #48
.RYAN
Member#: 69463
08 Daily - Legacy
Does having a DP cause flames or just removing the cats?
.RYAN is offline   Reply With Quote
Old 11-20-2004, 07:28 AM   #49
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
No cats causes flames, but 99% of the time you will be flame free unless you have a bad tune or a 100% atmospheric BOV.
Old 11-21-2004, 02:47 AM   #50
.RYAN
Member#: 69463
08 Daily - Legacy
Does anyone or any tuner have proof of a divorced/twin dump being better then a bellmouth or the other way around?
Im looking to get the RSR DP...to mate to the RSR catback.
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 302 05-20-2016 01:09 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 110 07-02-2015 11:25 PM
Turbo Timer FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 88 02-02-2015 10:10 PM
