Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 08-21-2008, 03:56 PM   #101
viper74656
Member#: 84758
'04 WRB WRX
Originally Posted by JoeSUBARU View Post
Cobb Stage 2 with an Intake? Is that ok? I thought you needed a stock intake.
....Do you need to get a tune when using a DownPipe?
According to Cobb there are 2 intakes you can use with OTS maps, the Cobb intake and the SPT.
And yes, you need tuning when using a downpipe. If you don't you are risking serious engine damage. The 04+ WRX factory ECU/tune just can't handle it.
viper74656 is offline   Reply With Quote
Old 08-21-2008, 04:01 PM   #102
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
^ Hey thanks viper !!
JoeSUBARU is offline   Reply With Quote
Old 09-03-2008, 12:03 PM   #103
pjung1
Member#: 180397
2004 wrx
Answered all my questions awesome writeup
pjung1 is offline   Reply With Quote
Old 09-12-2008, 02:39 PM   #104
BaNaNaS
Member#: 171902
2004 WRX Sport Wagon
PSM - Stg 2
which down pipes will bolt up to the stock catback? besides cobb.
BaNaNaS is offline   Reply With Quote
Old 09-12-2008, 03:05 PM   #105
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
2008 Blue Kawi ZX-10R
Most, if not all, will bolt right up.
ammo0000 is offline   Reply With Quote
Old 09-12-2008, 04:00 PM   #106
ringe
Member#: 49998
2007 WRX CT Stg 2
The COBB works best because it tapers down to use a donut style OEM gasket. Others will sort of work if you use a flat gasket and new bolts to clamp the lip of the catback to the larger diameter aftermarket pipe, but that may not seal as intended. You can find an adapter on Ebay and probably elsewhere...just do a search for 3" to 2.5" adapters.
ringe is offline   Reply With Quote
Old 12-30-2008, 09:57 PM   #107
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
nice review man...this thread is 4 years old! lol
BlackJavaPearl04 is offline   Reply With Quote
Old 03-09-2009, 11:48 PM   #108
an09wrx
Member#: 200929
2009 Legacy
Charcoal gray
Is it ok to reuse the donut gasket?
an09wrx is offline   Reply With Quote
Old 03-24-2009, 09:51 PM   #109
ouchMonkey
Member#: 206600
2004 sti
Default newbie
thanks again, very helpful.
ouchMonkey is offline   Reply With Quote
Old 03-25-2009, 06:28 PM   #110
masemac
Member#: 131676
2005 sti
CGM
so according to this write-up i dont need em to run catless dp on my 06 sti?!?!? or am i reading ths wrong?
Do I need engine management with a downpipe? For 02/03 WRX and STI users, no. For 04+ WRX users, it's pretty much a requirement as the open loop/closed loop fueling issue mandated by the EPA causes long term reliability problems with using a downpipe and no tuning. For STI users, the STI was the one exception manufacturers are allowed to have, but it's a wise move regardless as the STI and 06+ WRX users have a good chance of boost creep occuring with downpipe use. Tuning can ease this issue, but the cause/effect/cure of boost creep can be researched via this link.
masemac is offline   Reply With Quote
Old 04-06-2009, 01:25 AM   #111
beedee
Member#: 124727
helpful info, thanks for taking the time to do this!
beedee is offline   Reply With Quote
Old 04-09-2009, 02:46 AM   #112
skp2mylou1
Member#: 189858
2008 WRX
SILVER
the real question is,
i have an spt catback would there be any issue if i put this downpipe???
http://cgi.ebay.com/ebaymotors/HKS-E...Q5fAccessories
skp2mylou1 is offline   Reply With Quote
Old 04-09-2009, 09:14 AM   #113
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
This is not the eBay support forum, ASK THE SELLER!
Old 04-09-2009, 03:46 PM   #114
chitownrida
Member#: 190856
05 STi
extremely informative. i have total confidence in installing my dp now
chitownrida is offline   Reply With Quote
Old 04-15-2009, 03:26 PM   #115
scottsubarus
Member#: 5336
1992 SVX
Along with CEL light on, cruise control light flashing as well.
resistor installed, codes cleared but light comes back on after a day.
Catless up pipe and Cobb down pipe installed at same time 04 Forester XT Auto
scottsubarus is offline   Reply With Quote
Old 04-15-2009, 04:41 PM   #116
Colbc
Member#: 37633
2003 WRX Wagon
Scooby Blue
If it is possible, it is helpful to post the associated code for the CEL.
Does the Forester XT have a catted-up like the WRX? There could be two different CEL for your car. I don't know your answer, but I have seen a bunch of posts and read the FAQ to know that there is a DP CEL fix and a UP CEL fix (when the OEM UP is catted) and that each of these has their own associated code.
HTH
Colbc is offline   Reply With Quote
Old 04-15-2009, 04:56 PM   #117
scottsubarus
Member#: 5336
1992 SVX
Yes, had catted up pipe from factory
From doing a search on Forums P0420 sounds like the culpret, because others talk about cruise control light flashing as well, but resistor was installed and light came back on.
Old 04-15-2009, 10:30 PM   #118
scottsubarus
Member#: 5336
1992 SVX
Conermed code P0240.
Will research fixes
Old 04-15-2009, 10:55 PM   #119
Mdub
Member#: 152847
2007 WRX
the blue one
Legality aside: Cat or catless in terms of performance?
Catless seems to be a lot cheaper in general compared to high flowing cats (which is essentially a win-win for me, as I want performance at a budget).
Mdub is offline   Reply With Quote
Old 04-16-2009, 12:49 AM   #120
1stockwrx
Member#: 162365
minimal difference/s if youre on stock turbo
do you have an EM planned ahead?
1stockwrx is offline   Reply With Quote
Old 04-24-2009, 01:23 PM   #121
ezil71
Member#: 207118
2003 Wrx Wagon
For the section in your top post re: legality of downpipes.
No downpipe is ever legal to run on the street, under federal law, because it alters or moves cats. Especially true in CA.
Basically, if you are running stage 2/have replaced your downpipe (or anything before the cat) - you are breaking the law -
Some states seem to ignore the federal law, and allow passing of emissions with at least one cat (or by not doing the visual inspection and/or using the ecu to look for codes only).
As with many things, it is up to you to decide if you want to make a downpipe/emissions mod, as long as you understand you are taking a risk.
I wish Cobb/AP and exhaust vendors would mention this!
Please add something to this effect to the exhaust/engine management f.a.q.'s so that people can at least be informed when they make a choice to mod.
(flame suit on)
ezil71 is offline   Reply With Quote
Old 05-18-2009, 03:39 PM   #122
blades04
Member#: 211685
2004 WRX
blue
Could a stock dp play an issue with boost problems on a WRX with higher miles?
blades04 is offline   Reply With Quote
Old 05-22-2009, 07:04 PM   #123
11rex06
Member#: 70822
Question: is the WRX (2.0L) stock downpipe the same as the STi (2.5L) downpipe? GD bodies
11rex06 is offline   Reply With Quote
Old 05-22-2009, 07:51 PM   #124
hoffmanEstates
Member#: 122043
04 wagonier
psm
if i do a ported headers,perrin up and a full 3" TBE how long/far can my 04 last so i could make it to a tune session?
hoffmanEstates is online now   Reply With Quote
Old 05-22-2009, 09:24 PM   #125
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
The header has zero to do with it. You won't see the real gains without tuning, but it won't hurt anything.
The TBE is another story. How far CAN you drive? A long-ass ways, if you're really nice to the car and aren't climbing hills and such. But who here has enough self-control to do that all the time? That's right, nobody. If you're going to put on a downpipe and not tune it, knowing full well that you NEED to, you should expect no sympathy were something to happen. However, if you needed to drive for a few days before the tune and were going to drive like grandma, you'd have no problems.
Suffice to say it's not about time, it's about how you drive it and if you intend to put the stuff on now and wait a while to tune, just to have the parts installed, yoar doing it wrong, and if you're driving in such a way that you can identify some of the gains, you're asking for trouble. You should put them on as close to the time of the tune as possible.
Audiosavvy is offline   Reply With Quote
Turbo Timer FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 88 02-02-2015 11:10 PM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 290 12-20-2014 03:11 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 370 11-11-2014 05:51 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 108 01-25-2014 02:28 AM
