Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 05-27-2009, 09:41 AM   #126
STiLTD174
Member#: 178291
2007 Sti Ltd
UGM
Two questions?
1- So if my mechanic uses the plug in to read the code for an inspection (after DP install) I will pass right??
2- How much will a catless DP change the exhaust noise of the car?
STiLTD174 is offline   Reply With Quote
Old 11-04-2009, 03:34 AM   #127
TheDafMaster
Member#: 227514
2009 WRX
What is how how do you prevent boost spike?
TheDafMaster is offline   Reply With Quote
Old 02-08-2010, 12:36 AM   #128
bryantkalagian
Member#: 226391
01 Silverado
i have an 05 wrx, i am planning to run a catless up pipe and catless downpipe. how long is it safe to run like that with out a tune? Also, i am going with the invidia divorsed, will i need any mods with the 02 sensor or run a egt resistor? thanks alot!
bryantkalagian is offline   Reply With Quote
Old 02-10-2010, 01:23 AM   #129
myWRXisyellow
Member#: 236986
03 w r x
Sonic Yellow
this might be a dumb ? but idk. if i buy a 3in dp will it hook up stock to 03wrx or do i need to get 3in pipe? and if it installs to stock will the hp be the same or will it gain still?
thanks for the info also. helped a lot.
myWRXisyellow is offline   Reply With Quote
Old 04-06-2010, 04:11 AM   #130
AnointedDrummer
Member#: 165617
2007 4sale?STAGE2WRX
Blur of UrbanGreyMetallic
Will an Invidia dp that fits on an '06 STi fit on an '07 WRX? I looked and can't find it but really need to know ASAP. I'll keep looking, but if you know for sure, please post. Thanks much, sale pending.
AnointedDrummer is offline   Reply With Quote
Old 04-08-2010, 04:06 PM   #131
alx8283
Member#: 225024
2002 wrx
ive heard that running a catless downpipe and up pipe combo will/can cause boost spiking...is there any truth here or do i have it all wrong?
alx8283 is offline   Reply With Quote
Old 04-08-2010, 04:30 PM   #132
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You heard dead wrong. Boost spikes can be aggravated by a catless downpipe...mainly in 2.5L cars, but the CAUSE is the wastegate on the turbo NOT the downpipe.
Old 04-12-2010, 02:24 PM   #133
Penguin_02
Member#: 180460
02 WRX
sweet FAQ helped alot.
Penguin_02 is offline   Reply With Quote
Old 09-18-2010, 01:05 PM   #134
Flat4orce
Member#: 257362
right now im running a invidia 3in with the stock catback, and it seems to run fine. i went to this from a full 3in tbe, and this seems to run smoother with the incresed back pressure. the dp is heat wrapped and im running a stage 2 ots map from cobb. i would recommend this for anyone looking for a quiet but powerfull setup.
i also had a question about the heatwrap. I only wrapped the bellmouth to the first bend and coated the whole thing it the silicone paint (not sure how much that really does?). but awayways sould i wrap the rest or just leave it alone for the wet colorado winters?
Flat4orce is offline   Reply With Quote
Old 01-13-2011, 09:49 AM   #135
nick517
Member#: 268305
sweet
nick517 is offline   Reply With Quote
Old 01-13-2011, 12:56 PM   #136
cooks804
Member#: 269057
Thanks for the info.
cooks804 is offline   Reply With Quote
Old 02-19-2011, 09:46 PM   #137
02wagonrex
Member#: 270575
02 wrx wagon 4eat
wrb
so let me get this straight? i can put a cat-less dp on my 02 with no tune without negative side effects?
also looked at the links with no success on the o2 fix?
02wagonrex is offline   Reply With Quote
Old 02-19-2011, 09:57 PM   #138
McKenzie83
Member#: 207896
11 STi limited
true that...only reason the dp plays a part is the lack of backpressure from a high flow cat...but it's still on the IWG thanks to the fact that EWG is the best way to go anyways...but yup, usually with a tune you can take care of it.
McKenzie83 is offline   Reply With Quote
Old 02-19-2011, 10:00 PM   #139
McKenzie83
Member#: 207896
11 STi limited
I just wrapped my 3" dp as well...only to about 6" past the bend before it goes back towards the midpipe. I did this just to see how well it'll hold up to the weather. In the end I'll probably just get all the piping that is parallel with the ground coated ...if I wanna be a true d.i.k. and take it that far.
Old 03-21-2011, 03:42 PM   #140
jhornik
Member#: 243342
are the DP's on the 08-10 the same as on the 2011?
jhornik is offline   Reply With Quote
Old 03-21-2011, 03:44 PM   #141
dsmtweaker
Member#: 265405
2011 WRX
Yes, they are identical.
dsmtweaker is offline   Reply With Quote
Old 04-03-2011, 11:57 AM   #142
redsoxfan910
Member#: 230108
I just bought an '04 wrx...I want to put a catless down pipe on it with an exhaust and I live in CT. Will I have to put the DP on it, get it tuned...then take it off again to get emissions tested? Then redo this process everytime? I 'm confused, and new as you can see..
redsoxfan910 is offline   Reply With Quote
Old 05-08-2011, 11:33 AM   #143
jstepp5220
Member#: 207098
2006 STI
AW
Found it
jstepp5220 is offline   Reply With Quote
Old 05-08-2011, 12:06 PM   #144
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You are asking a question that is answered in the Cobb Tuning documentation available for viewing and download from the Cobb website. You need to read it and not get the answer handed to you as it is CRITICALLY important to read 1000% of the documentation. If you still can't find the answer, call Cobb.
Old 05-08-2011, 01:06 PM   #145
jstepp5220
Member#: 207098
2006 STI
AW
Yes I don't have a computer, and I can't download it from my phone going to the library tomorrow than
Old 05-18-2011, 02:12 PM   #146
gian-carlo
Member#: 124498
2002 WRB WRX
I know you talk about having to replace the bolts on an aftermarket uppipe, but nothing is said about the downpipe and exhaust. Do these bolts normally not break and hence can be reused most of the time?
GC
gian-carlo is offline   Reply With Quote
Old 07-10-2011, 01:45 AM   #147
bittner07
Member#: 287353
2002 Wrx
ok so i installed my catless dp today and my buddy is telling me that it is horrible to drive it without a tune is this true can i damage anything without getting a tune soon?
bittner07 is offline   Reply With Quote
Old 07-16-2011, 11:40 PM   #148
Stunticon
Member#: 288629
Thanxx you
Stunticon is offline   Reply With Quote
Old 10-29-2011, 02:30 PM   #149
Klammer92
Member#: 299378
Default Question
I have a question, im new to nasioc and not sure where to post my question but if someone could helo me out it would be great. i have a 2009 subaru wrx, and im looking for a throttle body spacer. if anyone knows what brand and where i could get one id appreciate it! thanks.
Klammer92 is offline   Reply With Quote
Old 11-12-2011, 06:02 PM   #150
BlackBeautysti
Member#: 299433
2008 Subaru STI
Black Paint Black Rims
Will putting downpipe will degtease ur mpg ?
BlackBeautysti is offline   Reply With Quote
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 260 05-16-2013 08:35 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 103 05-15-2013 01:15 AM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 309 04-23-2013 03:16 PM
Turbo Timer FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 84 04-17-2013 10:16 PM
Message Board Statistics All times are GMT -4. The time now is 04:55 AM.
